Auburn posi's
Old Dec 2, 2006 | 09:25 AM
Z-RATED94's Avatar
Auburn posi's
Anyone have some knowledge on whether or not the Auburn pro series posi is a decent unit? It's what I wound up going with because of a special offer and the fact that the stock one was making some strange noises. Do you think it will hold up for a while even if I add a 100shot of juice to what I already have? (370 RWHP).
Old Dec 12, 2006 | 11:08 AM
Z-RATED94's Avatar
Anybody?
Old Dec 12, 2006 | 11:16 AM
byrons1502's Avatar
not a bad unit that holds ok the problem is that once they go bad they are not rebuil;dable. auburn does a buy back and sells you a new one for i think $150 or $250. give them a call
Old Dec 12, 2006 | 12:38 PM
01Z's Avatar
01Z
I thought the pro series was the ordinary auburn cone with an extended warranty but maybe not. What byrons1502 is referring to is the D-REX program. If you want to learn more about it see this:
http://www.auburngear.com/aftermarket/drex/
If you want to learn more about your differential go here:
http://www.auburngear.com/aftermarket/faq/
Old Dec 12, 2006 | 03:49 PM
The Engineer's Avatar
The standard Auburn is the original factory posi unit (clutch-cone design) that comes in the GM 10 bolt rear-ends. The Auburn Pro Series is a "slight" performance upgrade for the 10 bolts and has the free rebuild from Auburn. The standard unit does not have the free rebuild from Auburn.
WD
http://www.cardomain.com/ride/2189634
Old Dec 12, 2006 | 09:36 PM
Z-RATED94's Avatar
Thanks guys.
vwb11356
Jul 22, 2015 06:51 PM
Jul 17, 2015 02:47 PM
mrwz28
Jul 8, 2015 09:11 PM
LVZ2881
Sep 2, 2002 12:35 PM
