axles
Old Nov 25, 2006 | 09:54 AM
morgan's Avatar
Question axles
Hello,
I was wondering if any could tell me why the axles of my 97 z28 keep wanting to come out:confused. I have replace the c-clips twice in the rearend and i still notice the rotor hitting the brake bracket
Old Nov 25, 2006 | 01:03 PM
morgan's Avatar
Question axles
Originally Posted by morgan
Hello,
I was wondering if any one could tell me why the axles of my 97 z28 keep wanting to come out. I have replaced the c-clips twice in the rearend and i still notice the rotor hitting the inside of the brake bracket
Old Nov 25, 2006 | 03:56 PM
jay_lt4's Avatar
i had this problem when i rebuilt a friends rear end in a 95 camaro z28 with traction control, the new axles i put in were a little longer and rubbed the brack caliper bracket just slightly, i just ground on the caliper brackets a little and it was fine
this was a 95 z28 vert, and it was the first time i saw 4 channel abs/traction control on this year car stock
Old Nov 26, 2006 | 03:40 PM
morgan's Avatar
Question axles
Thanks for the idea but the c-clips are constantly falling out, evey time i open the rearend the are sitting in the bottomof it, and if you remove the brake bracket the axles just slide right out of the housing. i beleive the axles are bent and that is why the clips keep coming out, should I just try replacing the axles to see if that is the problem or is the whole rearend going to have be replaced
Old Nov 26, 2006 | 07:23 PM
jay_lt4's Avatar
i would check the side gears, there should be no way the c clip can fall out unless the side gears are worn bad and causing too much clearance between the c-clip groove and the pin
i have seen this happen on a 8.5" rear end, it kept spitting out the c-clips then the guy took the carrier out and checked the side gears and found the gears were worn so bad on the back side that the clearance opened up enough for the clips to fall out
Old Nov 26, 2006 | 08:06 PM
morgan's Avatar
axles
thanks jay lt4 you have been the first person to point me in the right direction
2QUIK6
Sep 17, 2016 02:31 PM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
force10
Jul 30, 2015 04:56 PM
realistyc
Jul 28, 2015 07:32 PM
