View Full Version : LS1 Based Engine Tech
- Happy Valentines from HPE
- Low RPM Misfire / Stutter
- DRL / Blinker Doesn't Work
- LS1 Valve Covers
- Anyone tried to add adjustable stops to their factory Hurst?
- Clicking noise coming from under console area......
- 160f Thermostat
- what size cam and......
- Underdrive Pulley Safe?
- EGR problem
- LS1 problem
- Which exhaust setup?
- Bbk Ls1 Intake Manifold?
- Kooks Catted Y pipe?
- Need Experienced Advice
- Supertrapp
- Safe to use synthetic on a high mileage LS1?
- Idle + Running Problems
- SLP Lid VS FIPK??
- Nasty noise from rear suspension
- Why exactly do you guys change the "Lid"
- 52mm throttle body
- Service engine light flashing?
- Manual valve body
- Valve cover leaking
- LS2 Intake or LS6?
- How do you make the temp gauge functional on 99+ cars.
- exhaust and oil
- Oil change light on during recent freeze
- pissing power steering fluid
- Miss under load
- large cam question
- True Duals
- what next
- FM14 Cam - Video
- Dyno Locations in S IL or N WI
- Couple Questions?
- Service Vehicle Light - NOT SES
- Too loud?
- Need help!!! Leak!
- Question about Pacesetters
- oilpan
- Egr And Air Pump Removal
- Engine balancer/pulley
- Stripped bolt
- Engine balancing question.
- Simple ? for you experts
- oil changing
- Realistically... whats right?
- Jet hot headers
- Traction control and ABS HELP
- LS6 springs w/ aftermarket cam???
- How much horsepower do i have?
- 130 mph rattling
- SLP 85mm MAF on a 2000 SS A4???
- How much air pressure to change springs?
- 53 degrees, low humidity, 14.2's @ 99mph ...
- Need help!! Which tires??
- MAF question
- $500 What Mod??? HELP!!!!!
- would it be up to par with a ws6?
- How will this Trans Am compare?
- Mac Headers And Y-pipe??
- How can i get to the map sensor?
- *NEW* Mail order LS1 tuning by HPE
- LSX intake
- SLP Loudmouth vs GMMG
- Replaced LM resonator with an 18" chambered muffler...
- I need more low end torque.....
- V6 to V8 engine swap
- decarboning engine
- Upgrading fuel injectors
- CAm install done.. car shoot to redline on startup. *VIDEO*
- Some problems
- LS1 problems
- hypertech programmer
- How do I get to the Spark Plugs!??
- Ls1 Edit
- A few LS1 questions:
- o2 sensor millivolt range....
- LS1 Ticking
- LS1 on spray?
- Number 5 cylinder misfire
- Holley LS1 intake manifold?
- questions about getting a dual exhaust
- Dealership dilema
- Quick Post: SLPInstall?
- den in my new hooker cat-back?
- I Want 400hp!!!
- broke a sensor while removing intake... please help
- Piston Slap update
- can you do the fra on a ram air trans am? and skip shift problem
- my 00 trans am was totalled i just picked up a 02 ws6 convertible :)
- New times!
- (VERY) Noisy Belt
- Low Oil Light
- Help
- Ported MAF ends...gians?
- Before/After Dyno #'s Track times
- Some insight please
- After head swap, oil pressure gauge shows ZERO HELP
- LS1 valve weight
- stock 99+ tank, can you plumb it for sump style??
- Newbie Question
- LS1 Heads
- t-rex cam anyone?
- high mileage ls1
- Has This Happen To Anyone Else!!!!!
- stock LS1 RWHP?
- WHAT THE HELL, why is my car surging so much now?
- O2 simulator question
- FS: 1.6 Roller Rocker Arms
- Z06 upgrade kit available?
- swapping computers
- Y Pipe or X Pipe
- I got my heads!!!
- Air/Fuel Gauges Question..
- Does the 35th anniversary z28 have 35 more hp than the regular z?
- how does the air pump not affect O2 readings?
- y-pipe for jethot longtubes
- SES Light on...Map Sensor
- Trouble with longtubes hitting under car...
- Newbie here looking for help!
- Check Engine Light/ Gas tank pressure???
- LS1 Low Idle
- Gen IV LS2 Question?
- why no programmers for 98's?
- O2 sensors/wires (possibly burnt wires?).......can i do this?
- Squeaking noise from under hood
- 228/228 cam on my car with my current mods .
- Possible to get 450-500hp with heads, cam and my current combo?
- G1 vs. TORQUER CAM
- 30k
- used low mileage ls1 price range
- cats or no cats
- Camshaft Help
- LS6 "CNC" heads+LS1 hot cam?
- SICK of loudmouth with headers....HELP!!!
- How well do you know your stuff? Valvetrain tech questions...
- 02 Ta?
- Do all MTI Stage 2 heads look like this?
- Engine codes
- Jump starting car
- ls1 or ls6 block
- K&N Air Intake (FIPK)
- For those who think custom cams are best... please explain why!
- 3 Problems in One Day
- LS1 engine tick
- Need a part number, please
- SSRA vs. SLP Ram Air
- MAC Headers?
- Comparing LS1 Fuel Injectors@Fuel Pressure Rates. Please see inside.
- Answers to why "X" LS1 car smokes "X" LS1 car in here...
- Head and intake manifold question
- Has Anyone Ever Seen This Done?
- Help! Breather for new intake system??
- Factory Freak?
- LS1 large cam Throttle body mods?
- All you guys who have a lot of miles on LS1
- oil cooler?
- Tips for header install
- 6.0 vs 5.3 heads?
- simple question
- My sad story...PART II
- Are these headers any good?
- Cammed...Do I need a TB???
- Magnaflow catback
- LS6 intake install ??
- Are LS1 and LT1 injectors the same?
- nasty shake at the stop light
- exhaust cutout question....
- 5.3 liter heads ...who is using these ?
- Finally!!
- Kooks Longtubes In!
- Great site for you GM shade mechanics
- modded ss or z28
- Shaking Noise
- Update on LS1 Massive oil leak
- 1.8rr on the LS6 camshaft?
- Comp Cams: Best Customer Service hands down!
- Anyone running AFR 205 heads?
- Choices for replacement idler pulleys?
- a quick answer to "which exhaust"
- air induction
- Edelbrock LS1 Victor Race Headers?
- upgrading to LS1 question...
- Cylinder heads
- Dyno #'s from yesterday...
- Which Plugs and Wires??
- What Headers?
- Starting
- LS1 Edit Software ???
- Help with my LS1
- 63K on factory spark plugs. Time for a change?
- Head gaskets for boost
- WS6 Opinions Please.
- iridium or copper
- '99 WS6 first mods
- How do I install Corvette fuel rail covers?
- Are gen 3 LS1 engine gaskets reusable?
- SLP loudmouth with gutted cats...humor me
- what do these GM vehicle inquiry entries mean?
- Dyno'd the SS - Lid, LTs, Cutout
- What the problem is ?
- For owners of SLP LT's
- Chance to buy brand new MACs w/ ORY for $320 shipped...
- How bad are SLP Headers Clearence ?
- comp r lifters
- Piston Slap Question.
- Scheduled Maintence
- 3rd gen exhaust on a LS1
- Fun Fun Fun.. Header install ongoing
- will camaro exhaust fit on a trans am
- Fan Temps
- Official LS7/ Z06 Pics
- Cut out Question?
- Mac Headers with offroad Y-pipe
- Full Exhaust Question Texas Speed Duals?
- Where can I find???
- Dyno results with and w/o air filter
- Car Starts, The Dies, Then Wont Start
- car wont start help!!!
- Should I switch my exhaust?
- True duals came in...
- Dual Exhaust
- forged pistons for stock bore ls6
- lt1 ls1 parts?????
- Code P1416 on my car. I did a search, and the only hit comes up in the LT1 section.
- When do you do your first tune up?
- How do you like your Flow Tech LT's?
- Full lenth headers & Borla, CUTOUT vs. open BORLA
- Building a new LS1
- Runing lean stock ls1
- TSP catted Y question
- Which should be next!?!?
- Rev Limiter
- SES Light, P0404, P0153, P0155, P0135
- Are the LS1/LS6 block's rebuildable?
- won't start, gas smell in engine compartment
- MSD Digital 6......should i put it on
- How do Corvette fuel rail covers fit on a 02 Z28? HELP!!!
- what are the best headers?
- Headers...again
- R1 cam
- cutout came in! *PICS*
- 1998 SS w/ big oil leak
- Doing A4 to M6 Conversion. Couple Small Questions
- Car wont Start!
- Ses
