PDA
View Full Version : LS1 Based Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57 58 59 60 61 62 63 64 65 66 67 68
  1. Car breaking up at high RPM's? (Sorry bout repost, had errors on first)
  2. Looking for a SS Camaro 98 or above
  3. Don't be afraid to change your plugs!!
  4. Limited Slip additive in M6???
  5. Just Got An '02 Z28...
  6. Changing thermostat
  7. curious about weight on 02 Z28
  8. Auburn differential
  9. Stealth Air Box?
  10. Is there ANY way to find out my build number?
  11. skip shift
  12. LS1 to LS6 question
  13. suspension questions
  14. Any shops in Minneapolis/St. Paul or Omaha specialize in LS1s?
  15. Bad Mods
  16. Exhaust Please Read...
  17. Are my syncros hurting?
  18. Who has a August 2002 build f-body?
  19. Cheap Induction mods
  20. Power ProgrammerHPP3 Help
  21. Just got a 00' SS! Now what mods?
  22. Any ID#'s on 02 Z06 Cam?
  23. How much does a Cam cost
  24. Hooker equal length headers
  25. Descreened MAF w/ MAFT?
  26. 60hp w/throttle vs 100shot n20
  27. Catalytic Converter
  28. transmission
  29. Synthetic ATF in M6
  30. induction suggestions
  31. skip shift
  32. weight gain vs losted pick up
  33. Holly Power Sold sold out.... Donald okay?
  34. Factory LS1 throttle body size
  35. SS Tire Pressure, Factory Spec?
  36. Is my WS6 SLOW, OK, Quick, ?
  37. Are BMR subframe connectors good?
  38. Best pair of mufflers; Dual guys help :)
  39. 2002 Z28
  40. i installed a SLP airbox lid today....
  41. How easy is it to get 400 hp from these motors?
  42. Need help please. Looking into an engine swap.
  43. DiabloSport Predator Settings Question
  44. rocker arms
  45. Just got my loudmouth
  46. will stock corvette rims fit the 2000 camaro
  47. Cats ???????
  48. valve sizes?
  49. Door hinges
  50. Eagle F1 GS-D3 vs. Firehawk SZ50's
  51. rear end fluid change
  52. 99 SS How much it worth?
  53. Install University "Rear Hatch Release: Fix #2" REALLY WORKS!!!
  54. Another Satisfied Dynomouth Owner
  55. A4 WOT Kickdown @ 70MPH - ever hear a "gurgling" sound ?
  56. tranny service
  57. how much for labor on heads and cam???
  58. which heads???? stage 2 abs speed or 6.0 L
  59. WHich cam....comp or thunder
  60. do c5 rotors/calipers fit a ls1 z?
  61. Vibration at 70 and higher
  62. 2002 35th Anniversary Z28
  63. Rearend help please!!!
  64. LS1 headlight harness??conversion? help!
  65. FTRA or whisper Ram air?
  66. Oil Change for LS1s
  67. Ram Air
  68. What shocks should I get?
  69. Weld in Subframe Connectors Installed!!!!!
  70. Question about my a/f ratio and dyno
  71. High rise ram air
  72. Attention Everyone, READ ME
  73. MSD 6SL question
  74. Gear Question Please Read!!!
  75. Good deal on the Magna Flow catback
  76. Which intake system?
  77. Why are the fog lights on the LS1 cars so dim?
  78. differences between ws6 and t/a?
  79. t tops
  80. Need wire diagram for convertible switch>>
  81. Air/Fuel ratio tuning..
  82. SLP Quad Tips & Fascia on an '01 ?
  83. coverting my z to ram-air
  84. ? About Replacing an LS1 with Another
  85. Winter Mods
  86. LS1 Hot Cam
  87. Which heads?????
  88. LS1Tech vs. LT1Tech~ LT1 owners more loyal?
  89. mustang gurus
  90. Vin
  91. Hp Ratings 99-03 Z28 + SS
  92. Anyone descreen their MAF and want to give me the screen??
  93. Anyone hear this or notice?
  94. Shop in So. FL to do subframe install at a good price?
  95. Grinding in reverse Gear.......
  96. Front Brake Rotor Q?Q?Q?'s
  97. Front Brake Rotor Q?Q?Q?'s
  98. Important Piston Issue
  99. Question on Zo6 clutch?
  100. Importing European Camaro in Canada.
  101. speedo and tires ?
  102. Best Heads and Cam for an LS1
  103. LS1 vs LT1
  104. Warranty Question
  105. My 80 TA vs My 99 TA
  106. Creaking from the rear suspension
  107. is my red line higher??
  108. how do you jack up your car with that rock gaurd thing in the way?
  109. ss grille info
  110. T56 Fluid
  111. Which LS1
  112. Fuel Mileage
  113. Clutch sticking when car cold
  114. How do you know if you have a bent rod???
  115. Clucth help !!!
  116. auto tranny question
  117. What to do???
  118. Added a few new mods to my LS1 page...
  119. weight difference between the Holley...
  120. Please help me figure out this noise/vibration!!!
  121. escaping GM's diagnostic computer check's
  122. cams
  123. K&N FIPK, is it worth the $
  124. piston slap?
  125. Hurst Comp M6 shifter
  126. Did a full synthetic oil change and dyno!
  127. O2 (oxygen) sensors..
  128. knock question
  129. cars runs better after resetting pcm and burnt smell?
  130. Heating question:
  131. gauges?? why wont they work on my 00
  132. How many miles on synthetic oil???
  133. t-56 tranny
  134. cut-outs, where and what size?
  135. Help!! Low Oil Light on '02
  136. Traction Control Q's
  137. 12 Bolt Rear Questions
  138. Donaldson vs K&N
  139. Which is faster? Please Explain!
  140. If you have Long Tubes and no cats get in here please>>>>
  141. Cat-Back True Dual Question...
  142. SLP LT'S finally in!! But..
  143. Need some good advice
  144. Would 245/45/16 work with the stock rims if I....
  145. Bent K-member??
  146. What's the easiest way to reset your PCM?
  147. Major differences in Z28/SS
  148. oil change with headers
  149. HP gain from pullies?
  150. 6 speed
  151. Cup Holder Mod
  152. CD Changer Adaptor?
  153. Wheel ramps that fit under a 98+ T/A???
  154. newbie with question
  155. FRA and factory Ram Air ... WS6
  156. So uh...about those Jet-Hot Headers. Anyone got them yet?
  157. Air Pump Removal
  158. Descreened MAF vs. aftermarket MAF ends - do the MAF ends offer more flow ?
  159. Any of you descreening the MAF?
  160. Weird Problem
  161. Hooker Headers/Corsa install probelm...
  162. Stock LS1 &LT1 valve size?
  163. I shouldn't have to ask this, but I am.........RE: tire size
  164. Mobil-1 oil filters and free ram air?
  165. Ideas for taking care of Pro 5.0 noise
  166. what spark plugs come with the LS1 from the factory?
  167. just installed plugs
  168. C5 power under-rated like F-body???
  169. And The Winner Of The Free Comps Cams Cam Is....
  170. Where is the air bag sensor?
  171. Cat-Back Prices
  172. 10W-30 in LS1's?
  173. BMR vs Spohn vs ???
  174. Random tech ypipe for Mac headers
  175. Dumb headlight question
  176. New Guy here saying Hi!
  177. 13.3? for almost stock?
  178. correct weight
  179. Need help on WEIGHT REDUCTION!!!
  180. Speedometer problem
  181. CLUTCH went out... What do you know about SPEC STAGE 3 ???
  182. expected hp gains from cut out?
  183. Installed SLP Loudmouth now have shifting problems
  184. what MPG can i expect from an A4?
  185. 02 LS6 and stock LS1 cam specs
  186. how durable are the A4's in an LS1?
  187. MO6 vs. A4 any chance for the M06??
  188. Oil out of Cut-out?
  189. will fipk work well with ss hood???
  190. Exhaust Types
  191. Z-28 info
  192. Finally found out 99 ls1 injectors will work on 3.8 need help on fuel pressure
  193. Corsa Exhaust
  194. People who are 21 to 27 how much are u paying for insurance for your LS1
  195. Newbie here, any advise
  196. Where to place cut-outs on true dual X-pipe setup?
  197. Bad Code
  198. 160 Thermostat
  199. A new ls1 site. www.ls1camaro.net
  200. quick help me in here...swapping sprins but....
  201. maybe a dumb question
  202. Hpa Sfc's
  203. Guages wont work!
  204. spinning one wheel
  205. spinning one tire help!!!!!
  206. Rear Clunk
  207. Yet another clutch ? please help
  208. A couple hypertech questions
  209. What size bullet?
  210. Question about cleaning engine compartment?
  211. Will these mods get me where I want to be.
  212. A4 clunking sound
  213. Driveshaft?????
  214. Whats the difference in..
  215. Removing the muffler
  216. strange new sounds from the trany... help!!
  217. time for another oil wieght thread.
  218. Another Clutch question..
  219. ***robvas******
  220. LS6 Intake?
  221. installing a b&m shifter
  222. Buying LT Headers which ones?
  223. FYI: a "cure" for the LS1 piston slap??
  224. rough idle and error code...
  225. need to know about LS1
  226. Lost T-top at 70 mph
  227. A little help please>>>>>>
  228. pro/con for y pipe?
  229. This Is A Big Help!!!!!
  230. 8pt roll cage for 200 shipped......
  231. 11.99 need roll cage?
  232. Can someone tell me how to attach a picture to post?
  233. digital gauges in gauge pod.......
  234. SLP Y-Pipe
  235. Change to Synthetic
  236. '02 exhaust suggestions
  237. To late to run Royal purple in the rear end?
  238. Good Sites To Order From
  239. Bad Clutch??
  240. NEW??just got pro 5.0 need experience
  241. Torque Converters
  242. Hypertech Question HELP!!!!!
  243. install of front springs.....
  244. How low should I go w/18s?
  245. ASAP...doin slp fan switch install.......
  246. Cam input
  247. '99 C5 rims on 99 Z28
  248. Double Roller Timing Chain
  249. changing the fuel filter...
  250. Anyone put 4.10 gears in a 98-02 NON SS or WS6 Fbody?
