broke a sensor while removing intake... please help
Old Jan 14, 2005 | 07:52 PM
SUPERSPORTBOY2's Avatar
i took my intake off my car tonite... it was a lot harder that i planned. i busted off the sensor that screws into the block. it is closest to the drivers side. there are 2 right next to each other. i got the threaded part out ithe block so everything is cool but i would like to know how much a new one is and which sensor it was. thank you in advance.
Old Jan 15, 2005 | 09:59 AM
teke184's Avatar
Re: broke a sensor while removing intake... please help
is it the one by the front exhaust port? cause that's the engine temp sensor.
you could probably drive without it for a while, may interfere with the fans coming on, but if you stay out of traffic you should be ok
Old Jan 15, 2005 | 03:40 PM
SSactionLs1's Avatar
is it a large cylinder? if so its the oil pressure sender. its common to break. Cost me 25 bucks at a local autoparts store.
Old Jan 15, 2005 | 04:43 PM
orangeapeel's Avatar
It is not on the driver side head is it? you know that the LS1 has a "couple" sensors.
Old Jan 16, 2005 | 01:26 AM
Beast96Z's Avatar
It's the oil pressure sensor. Most everyone breaks it on there first intake removal. A new one will rob you for about $50.
Old Jan 16, 2005 | 08:35 AM
i should have been more clear. back of intake the cylinder shape one. looks like the oil sender. thanks for the replys.
Old Jan 16, 2005 | 09:44 AM
Demon SS's Avatar
it is the oil pressure sensor and even with as many intakes and heads that we have removed I always keep a spare one in the tool box as those &^%^#$ things are easy to break. the sensor is like 25-30 bucks and a socket for them is like 5-6 buck at your local A-zone.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
BigWil
Mar 29, 2015 12:24 PM
sscott
Jan 17, 2015 04:30 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Queens94z28
Dec 20, 2014 09:11 PM
