View Full Version : LS1 Based Engine Tech
- Some help with my LS1
- Spark Plug Socket
- Full bolt on's
- SES light code P0420
- Idler pulley
- $1500-1800
- Which LT Headers should I get? HP?
- car is burning a quart of oil every month?
- What Plate Do You Use On Your Borla Exhaust?
- 6.0L shortblock
- Got a new LS1~!
- Help for the illiterate???
- 2 02 Sensors in 4 weeks
- What is the best emissions legal way to get 500hp excluding blowers and NOS?
- header problem
- Broken AC line????.....
- Getting Closer
- knock sensor code question
- ls6 part advice
- Cooling Fans On Temp?
- everyone with poly motor mounts in their ls1 please reply
- Z06 maf
- LS1 Basic mods
- Alternator
- $70 supercharge???
- Slack on LS1 timing chain????????
- LS2 intake!!!
- 6.0 liter or LS1 into IROC?
- which header and catback combo would u recommend
- x-pipe question
- Bent Pushrods?
- Is this a good trade??
- Should I do this if i get a 02 LS1???
- Raise the CR
- Question for LS1/M6 drivers
- Ses
- LS1 guys with 373 gears, at 45 mph at WOT you still get that screaming performace?
- Engine probs from redlining?
- What size cut-out on stock exchaust
- is it possible that my tps voltage is low, causing my trans not to downshift at WOT?
- Need help!
- tps voltage at WOT, what should the voltage be?
- Looking For Writer For Major Car Magazine...
- What is SSRA
- horsepower estimates
- do you have to upgrade the trans filter when using the deep trans pan for the LS1's?
- so is my block cracked?
- How can I reach 12's?
- how much HP?
- TC and Shorty headers
- Small cats?
- car feels sluggish after longtube install plus tick tick tick noise
- Mocked up the motor tonight
- Off road y pipe....
- Lost 4 MPH in a week! Any help is appreciated!!
- nitto drags/muffler
- can use some LS1 guidance...
- 30-45sec delay before misfires
- Locktight the rocker arm studs???? ASAP
- need help with 02 TA
- help need mods fast!
- hedman long tubes and exhaust
- K&N Filter Oil?
- K&N Filter oil?
- 180 stat
- Piston Slap?
- Is this possible?
- New Heads/Cam to be installed next weekend
- Rod length
- camshaft ques...
- M1 Oil Filter
- anyone uses the deep trans pan for their Ls1's, if so how many total quarts to use?
- engine oil / gasoline scent????????????
- how to change lifters
- new 180 sat. need fans to come on at 180?
- whining??
- Problem Areas
- Can't clear SES light
- Cold-Air Induction Package
- Noise
- LS6 Cam
- changing valve springs...how to tell when piston is at it's top position
- LS-1's Do's & Don'ts
- would the gm dealership replace my oil pan gasket under warranty?
- engine knocking?
- whoa
- help!! trans mount problem
- 2002 Camaro vs 35th anniversery?
- Hooker Super Competition Headers
- prothane trans mount is to big for the 00 Ls1 camaro?
- need experienced header feedback
- Baffle Removal on WS.6
- Window motor install
- Difference between each year?
- Rear
- Which MAF is the best?
- Buying a 98 SS.
- Any install tips
- What mod to do next?
- K&N Cleaning Question?
- Aftermarket accessory switch mounting options
- Another Header Question
- Check out these prices...
- Need opinions on cam
- 1000+ hp
- Car won't start
- looking to make more power
- SSRA or SLP cold air-induc.
- ls6 heads/cam/intake worth $1k??
- Y pipe fitment
- got a question...
- ls1 making strange sound
- what is the deal with msd 8.5mm wire hard on ls1 coil pack???
- MAC Header questions for my 2000 Z28
- Car Confused?? Please Advise... :(
- 3rd gear, A4
- y-pipe question
- My T/A did something weird yesterday...
- K&N Filters bad for ls1's???
- A Peak Inside The Engine Of The APE Shop Car
- Can LTs be Connected to Y-Pipe?
- rough runing LS1
- feul pressure regulator
- cheapest place for o2's
- Ordered Headers Yesterday...Couple Questions
- free LS1 mods?
- LS1 Exhaust Pipe Sizing
- cutout location
- t-rex cam questions
- ported maf
- pinging??
- Cutout and flowmaster
- QTP Headers are in!!!
- what is specific about 97/98 heads?
- questions about LS1
- Engine overheating...
- cam a tooth off?
- What to look for when buying an '01 or '02
- SLP Dual/ Dual on 2000 SS with restrictor?
- cold-air induction
- Most disappointing modded ls1 I've seen
- Looking forward on buying an LS1, A4 or M6?!!?
- Thermostat
- whats the prob?
- Problem with my LS1 Formula :(
- What kind of lid?
- Forged rotating assemblies noisier?
- LS6 in a S10 ?
- when using band clamps for y pipe/header install should i use alum. foil?
- ZL402 6.0L motor
- Will a direct aif flow lid for a 2000 work for a 98?
- *PICS* of MTI Clear lid
- Whos cammin?
- What mods should I do first with a stock '99 TA
- LS1 Mods
- Wondering about Cold Air Intake??
- another damn header question
- New Best - 13.3 @ 109.7
- 6.0 iron block vs 5.3 aluminum block
- build your own CAI?
- looking to get headers
- 1st To 4th Skip Shift
- LS1 Bare Block for $300, Good Price?
- mac mid length cats any good, are they pretty freeflowing.
- Running Rich???
- stock 00z28 track times
- Have a Local Yokel Resleeve My LS1?
- wondering what track time i can expect...
- this is a stupid question but....
- Anyone running the Spintech Catback?
- Rev limiter
- To Much Coolant In Resevoir, How to Drain.
- cold air induction kit?
- What cam is this Lunati????
- Need to know ASAP, and none of the ls1 forums have been ANY help...
- 02 sims for off road Y pipe
- Race-Prep 91 octane 434 auto C5 makes 530 RWHP!!
- mac headers and off road y-pipe?
- Tape Around Lid
- A/c Delete
- Just had oil change
- stock LS1 valve stem diameter?
- Help with cutout ?
- lt1 guy looking to upgrade to ls1 some Qs
- NEED HELP on cam selection...
- anybody have # or no store that sells updated PCV
- cats
- How can 422 CID Be an LS1?
- Charge is fine when I start it; drops into yellow when e-brake is released
- Just installed alternator; now low idle and low charge
- torque?
- Squeal when a/c clutch engages; stops when disengages
- LS1 hot cam vs. LS6 cam
- How many ponies do I have?
- headers
- Pacesetter vs Flowtech
- LS1 32/37lb Injector Sale
- police packaged LS1
- Nov Chevy Hi Perf LS1 tests
- How am I doing?
- rattling exhaust
- BG ram air kit
- How much will gears knock off in the 1/4?
- how to tune engine with Predator if i can monitor O2s
- Canaries under the hood at cold start
- Spark plugs
- Lunati vs hotcam vs custom grind
- Can the GM dealer do this to the computer?
- Should i mod my high mile SS?
- Michigan People
- Duals are on. PICS
- Newbie question ...
- Weird idle problem yesterday, questions, possible map sens?
- The New Guy
- 160 Thermostat
- True Dual on my TA question.
- buying an ls6 block, few questions
- How do you gain HP/TQ from a pulley?
- Sealing air lid with electrical tape?
- Poor performing Heads cam car, need help! Long post
- Ported my tb and now it wistles
- couple quick PVC questions
- will o2 sensor affect hp?
- What do you guys mean by "Free Mods"??
- Air Boxe lids
- My f*#@$ing flowmaster fell off!!!!!!!
- I didn't want to have to ask...
- need ls1 radiator support picture!with airlid off!HELP PLEASE
- Header Question
- rattling sound when going into gear?
- ls6 cam installed
- How much can it handle?
- fuel filter worries
- Wheel hop?
- How well does Hooker Cat Back flow?
- Engine Seems Loose in Bay
- drove a 1998 vette, why does it acclerate diffent from my 99 Z28
- Squeak Squeak ... not the tensioner
- ls1 to ls6
- Car Redlines Too Easily With New Exhaust
- Why get an ignition? + one other ?
- electric cut-outs
- Clearance issues with milled heads/cam ?
- amount of psi?
- Electric water pump worth the $$$
- What headers for lowered T/A?
- AP Engineering - groundbreaking news! Guaranteed engine delivery times!
- low dyno numbers
- 2001: Light squeal from front of engine
- I want my WS6 to beat my 03 Cobra...
