used low mileage ls1 price range
Old Jan 3, 2005 | 10:14 PM
terrible 1's Avatar
i found a place called schrams and all they have are gm parts. i noticed they had lots of complete ls1 motors w/ computer. i was just wondering what i should expect to pay for one with maybe 20,000-40,000 miles on it. i want to do a swap with my lt1.
Old Jan 3, 2005 | 11:24 PM
anasazi's Avatar
Re: used low mileage ls1 price range
why?
you'd have to replace just about everything ... much easier and cheaper to build your LT1
spend much much less money by building your LT1 instead of swapping to an LS1 and spank LS1's around all day long
Old Jan 4, 2005 | 05:01 PM
terrible 1's Avatar
i got 130000 on it, i figured id get a new motor soon. what EXACTLY would i have to replace? im just curious.
Old Jan 4, 2005 | 05:28 PM
anasazi's Avatar
do a search, but off the top of my head:
engine
tranny
k-member
A/C
computer
fuel lines
?fuel pump?
?radiator?
dashboard
Old Jan 4, 2005 | 06:05 PM
SFB767's Avatar
tranny
dashboard
Neither trans. offered with an LT1 won't bolt up to an LS1?
Why does the dashboard need to be replaced, does the LS1 sit further back in the bay than the LT1 does?
Old Jan 4, 2005 | 06:07 PM
anasazi's Avatar
if it was a 1997 car then it might work, but the guages are all different IIRC.
the tranny bellhousing is different, bolts up differently.
Old Jan 4, 2005 | 07:11 PM
TA Jack's Avatar
LT1s make good boat anchors. Schramms are expensive. Ive seen 20-40k mile LS1s complete with motor, trans, computer and all wiring for $3000-$3500.
Old Jan 5, 2005 | 08:16 PM
Kataklysm's Avatar
Or you could spend 4k and build the LT1 and have 0 miles compared to a used engine. LT1s are not just boat anchors either. Anyone who isn't Kataklysm knows they are great engines.
Old Jan 9, 2005 | 01:35 AM
Bersaglieri's Avatar
Rebuild the LT1, youll be better off.
-Dustin-
Old Jan 9, 2005 | 10:48 AM
lt1camaroman93's Avatar
I have seen several 383 shot blocks floating around in the for sale area for around $2500. Send your heads of to get them ported, get a cam, injectors and tunning. You will probralby end up right around the same price. I have also heard that the ls1 is a taller engine and won't quite clear under the stock hood of an lt1 car. I am not 100% sure on that so you may want to do a little research.
Old Jan 9, 2005 | 12:31 PM
Need4Camaro's Avatar
From what I've seen, or atleast thought... LT1's and LS1's have roughly the same power potential...LS1's are just generally closer to it stock for stock...
Old Jan 9, 2005 | 01:03 PM
Kurt Crosbie's Avatar
From what I understand, the big power difference between the LS1 and LT1 are the heads. LS1 heads have much more cfm stock. The best thing you could do is get some AFR 220's and port the hell out of them. There is much more available to make the LT1s fast. Namely the SB2 heads. But they are rather expensive.
A few other things...
The LT1 is a 2-bolt main (in case you don't know, that means each main cap is held on by 2 bolts). The LS1's come as 4-bolt mains (I think). In this sense, the LS1 block can handle more power. But if you're not putting a supercharger on it, I wouldn't worry. The 2-bolt should be good enough for about 450rwhp (which is around what you will be making with some AFR220's and the right cam). If you wanted to put more power down in the LT1, just put some splayed 4-bolt caps on it. Another thing with the lt1 is that the pistons are lighter. In this sense, it can handle rpms better than the ls1.
If you were lucky enough to get an LT4, I believe they have 4-bolt mains.
Bottom line, either way (ls1 or lt1), you'll be making the same horsepower $ for $.
Old Jan 9, 2005 | 01:33 PM
Munson's Avatar
ls1's make good boat anchors just build up your lt1
Old Jan 9, 2005 | 01:39 PM
DrewSG's Avatar
I thought LS1's had a 6 bolt main?
Old Jan 9, 2005 | 03:21 PM
They probably do. My understanding was that the LS6 had a 6-bolt and the LS1 had a 4-bolt, but I'm probably wrong.
