View Full Version : LS1 Based Engine Tech
- Help, Help, Please...................
- SLP Longtubes>Clean or Leave it
- Programers
- 02' Z28 priceing
- LT1/LS1 6 speed/gears????
- pro 5.0 + LSS input.
- Need help fast boys, Thermostat related!!!
- Poll....Hooker LT's or SLP LT??
- A4 ? Mine slips in 1st & 2nd, but not 3rd and OD...
- how much did you pay for '02 ss
- Rotors, good aftermarket ones?
- Digital HP/TQ meters--worth it?
- SLP Loudmouth Installation?
- 02 sensor/header question
- How do I replace the turn signal lens?
- '01, '02 Z28 stock exhaust poll
- Choices, Choices, Choices...
- Temp sending unit on head. . . ?
- Would this be possible (A4 question)
- Hooker cat-back
- 17x10 Inch Wheels!!!
- LS1 Throttle Body Spacer
- help
- Intake selection
- Pro 5.0 Shihter Problem
- Check Engine light
- how can i found out how many 4th gens were made in a certain year?
- How much louder is Borla w/ no plate vs. loudmouth exhaust?
- Licence Plate frame
- anyone have ls6 headflow data?
- Power Programmer
- 2002 Z28 with Stock FLAT H-Pipe??
- WEIRD!!!!!!!! HELP!!!!!!!! Please read...
- Programmer?
- Detailed instructions needed on how to remove the low coolant sensor !
- Color
- Would "salad shooters" fit on an LS1?
- Lowering Question
- friend agravating me.....
- pinion seal part #
- WS6 Rims Question
- free ram air HP
- how much gear whine is normal?
- Do LS1's Have Forged Internals?
- Lowering questions
- Y pipe hitting floor board
- cat back opnion--?
- tranny mount?
- Gains from aluminum driveshaft
- Horsepower calculator
- gauge faces
- SLP loudmouth vs Flowmaster
- Are GeForce 315s too much rubber for slightly modded SS?
- Can I adjust my Clutch?
- Bad torque converter or not ?
- Guys, I need help!
- Gauge Cluster doesnt work
- Skip Shift Elimination
- Thoughts on Headers
- Loudmouth smog question
- Help dash gauge lights and radio light inop!!
- My LS1 vs my twins LT1
- LS1 brakes larger than LT1s??
- horsepower & 1/4 mile times?
- Buying a set of 9.5's in front and 10.5's out back, anything I should look for??
- What did your LS1 F-body dyno STOCK
- 10.5" Tires on stock rear, should I worry?
- High flow cat
- Do LS1s have hardened pushrods like LT1s???
- 98Z O2 sensor question
- Need solenoid for 4L60E Transmission.
- 1 le alum DS ?
- New Exhaust/Old Exhaust
- slp level one suspension package
- Who has a K&N Ls1 setup?
- Idling at 1100...Isn't that too high?
- ABS Light
- car door hit!! ugh!
- Any LS1 Gotchas?
- Buying a 1998/99 Formula/TA
- Engine Rebuild? or Not
- Where to from here?
- Steering Wheel Problems?
- running symptoms of bent rods?
- DiabloSport Predator: Results of Customers' Cars!
- Does anyone have sound clips of an SLP LM or Flowmaster exhaust system?
- Cold Weather = Wont Go Into Gear In Morning?
- PLEASE READ Driveshaft loop, and Torque arm recommendations...
- Some help
- best springs and shocks...
- Speed limiter!!
- Headers
- V-Force muffler?
- changing spark plugs
- Clutch Sticking
- Put my T/A on the rollers today
- How Low Can You Go?
- Water Temp?
- More problems w/ new car...
- air fuel ratio gauge hookup?
- Problems with new SS
- Twin Turbo Kits?
- Quick Tail light question
- '03 F-Body Question
- A Question concerning "shorty headers"
- Caliper Pins won't come out on front
- Thunder Shootout
- free little mods?
- shifter vibe
- 2001 Z28 title
- turbo vs. supercharger
- Servo Piston???
- Suspension Question for 2002 5.3 LS1 Tahoe
- why does my LS1 have less torque than everyonelse's
- Brand New Ss Break In
- LS6 on 2000,
- input on aftermarket shifter?
- CARB legal cams for LS1s??
- What is shift extension?
- Subtle 'click' in steering wheel movement
- Mice love it.
- Need Suggestions quick!!
- whats a shiftkit? please tell me
- M6 problem, yes again!!
- widest tires?
- Help Which Winter Mod List Do I Go With?
- Any tips or suggestions
- Polishing a GMMG.....ya or na?
- I just received my LSI Motorsports Lid (HELP)......
- spark plugs
- Tranny question, again.
- A4 to T56
- Exhaust Question!!!
- long tube headers
- Just installed wires... OK with no heat shields?
- SS Title question
- A little depressed.............
- 225/50-17 ok for snow tire size?
- HELP installing longtubes 99
- To sell my LT1? LS1 q's inside:(long)
- Hypertech 160 or 180 thermostat
- Tired Out
- bought 2000 SS!
- Shocks Question
- BTW: Track and Dyno
- skip shift
- Torque arm HELP!!!!!!!!
- Just finished FLP Header install, something interesting happened...
- got a question of the ss spoiler
- bored
- master cylinder question
- Service BiLL
- exhaust pipe
- need help asap
- MTI Webpage
- Cruise Control
- Need help with SLP Longtubes
- Oil
- 2000 SS suspension
- SOLD MY CAR need help quick!!
- Suspension question..
- Tires and Chicago weather
- Exhaust
- Engine air
- LS1 Gm 1998 service manual for sale
- Just installed Magnaflow Catback
- Need help! Bought new SS and I have old parts
- dynojet
- windsheild wiper @ high speeds
- where can i find the new bolt for the asp crank pulley?
- Need HELP, Loud noise coming from the rear of the car!
- 98 up parking brake setup
- How much would you pay for this car.
- Fixin to install new wires and plugs.. Questions
- Z hood
- Oil Changes
- 4L60E upgrade questions.
- Please respond
- dynomax catback..
- Yank or Vigilante
- Lid - Wife says Wow
- just bought a 2000 ss!
- Attn diablo....
- Oxgen Code
- need 2 write a persuasive report on lt1 and ls1..any info would help
- New toy.......
- Bleeding Brakes
- i really need ur guys help..please read
- SES light.......helpppp
- new 1/4 mile times..
- picking up '00 T/A today!!!
- Induction lid question
- ? for people w/ t-tops or leather seats.....
- 98 trans am wont start
- shift kit for A4
- Please help about my clutch!!
- Engine Running Temperature
- Convertibles..how much slower are they?
- sound clip of my exhaust
- Oil pump installation help?
- Drive shaft safety loop with FLP Long tubes, problems?
- missed 4th gear
- Quick question...
- what kind of clutch?
- Bought new SS, can I sawp my parts?
- New Car Power Loss...
- Two air/fuel ratio gauges?
- brakes
- 1999 SS Owners Manual
- High Flow Cats???
- Unbolting exhaust for track?? need asap
- Owd to the LS1, got mine back today!!
- Aftermarket shifters: worth it?
- Anyone get plug #8 from bottom?
- GM Technical Bulletins
- Free ram air mod.. Anybody done it?
- Problems w/ new car...
- PCV Mod
- 99 Z won't start
- Hooker Headers Install. Any help appreciated!
- Borla exhaust
- Your opinions on upgrades
- SS Owners and those with SS Dood/SpoilerPlease Chime in!
- Noise in a Turn
- LS1 rear oil seal
- some advice please....
- gmmg catback equivalent?>
- How do I get the grille on the ss hood off?
- Please help!!! car wont start
- ET Streets tire question.. HELP!
- thinkin of a blower
- Fuel Injectors-question?
- Good deal for ss?
- Cheapest place to buy Procharger?
- Exhaust
- HELP!!!! FLP header install w/slp Bolton Sub Frames problem
- Anyboby have a problem with a factory alarm?
- ls1 w/ true dual
- leaking driveline
- SES problem with MAF. (running lean)
- Thoughts on sound from SLP LT's, etc.
- Gutting my cats today....
- LS! Engine Idle
- How much total horsepower will i have?
- 17x 11 rubbing inside of wheel well
- going to look at '00 T/A today !!!
- ABS INOP light/LOW TRAC light
- Raptor Hood: Do I Still Have Ram-air?
- Whisper Lid.....
- car smells bad inside after getting on it...
