LS2 Intake or LS6?
Old Jan 26, 2005 | 01:21 PM
ShowandGo's Avatar
LS2 Intake or LS6?
heres what I got.1998 Z28 TSP 231/237 cam stage 2 heads 125 shot 42 lb injectors 4400 stall ported tb and maf air lid what intake should i go with?
Old Jan 26, 2005 | 01:43 PM
LT-14me's Avatar
Re: LS2 Intake or LS6?
Would an LS2 intake even bolt up? I know they are gen iv motors so i would assume some stuff has changed like you cant bolt an lt1 intake onto an ls1.
Old Jan 26, 2005 | 01:50 PM
stik6shift93's Avatar
They fit, you need spacers for the fuel rails i believe and you need to use ls1 injectors.
Old Jan 26, 2005 | 02:13 PM
Greed4Speed's Avatar
TB won't work unless you have drive-by-wire
Old Jan 26, 2005 | 04:14 PM
Do a search on ls1tech.com in the ls2 section some guy there did it. The ls2 intake is a 3 piece intake, pieces don't line up perfectly so a little finish porting is required to smooth things up in the intake ports.
Old Jan 29, 2005 | 05:27 AM
BirchMan98z's Avatar
Builders commonly use the ls6 intake on engines as large as 427. It's a top notch piece, and a cheap mod.
Old Jan 29, 2005 | 08:14 AM
anasazi's Avatar
everything is relative ...
can't find one used for less than 300 bucks
Old Jan 29, 2005 | 09:13 AM
Antz97ZNJ's Avatar
http://ls1tech.com/forums/showthread.php?t=265529
R@mpage
Apr 20, 2015 10:02 AM
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
