View Full Version : LS1 Based Engine Tech
- LS1/LS6 intake
- grease in tb by blade...
- help with codes
- rocker and lifter noise.......
- ls1 --> ls2<---
- Dyno So Low Its Pathetic!!!!
- What cam shaft?
- Why are my dyno #'s so low??
- No *check engine* light. Any schematic guru's here?
- Engine swap question
- oil catch can location?
- 9/97 engine with center valve cover bolts??
- Valve cover gaskets... One last question
- Cylinder miss fire
- removing the oil pan.....?
- I think I need a good motor mount, non polyurathane
- I am a LS1 owner all!!
- need cam advice...
- Leaving it in ONE in an A4 2.73 LS1
- Noises after FAST install...
- Does anyone know where to get the crane 227 for less than $360?
- How to lengthen throttle cable for new TB???
- Lsx ????
- 243 or Dart 205s with f13?
- Where is all the LS1 people at??
- Small cam install: Need a tune ?
- MAP sensor and FAST intake....?'s
- I need some recommendations/help
- Exhaust
- All tore apart!!
- Sould i get my TB ported?
- Question about knock sensor?
- Loss of bottom end!?
- Should I Buy.............?
- milling stock heads...how much gain
- Pictures of ABS delete kit on 2000 SS
- Cams???
- High Mileage LS1
- which bottom ends on an LS1
- High idle....
- Replace intake gaskets...or not?
- Ls1 milage question
- SLP loudmouth question.
- LS1 Engine Swap Success Stories?
- Problem after header install???
- I will get laughed at for this, but, headers important?
- LT1 problems as opposed to LS1's ??
- For those who have installed a FAST intake....???'s
- Oil pressure gauge
- Clanking noise?
- whats the difference: Hooker Comp Vs. Super Comp??
- Aftermarket Tach in 98 trans am
- ...And on the 8th plug he said...
- Can you make an LS1 as fun down low as the LT1's?
- What is that
- ls1 tornado
- IF you Plan on doing water temp gauge
- Magnaflow 3" tips vs stock Z28 tips
- just curious
- tornado
- need tuner in Iowa
- Sudden surge/lag in power...
- bad ping after mod install
- DTC P0171 Fuel Trim System Lean Bank 1 and P0174
- What did YOU run with full exhuast?
- Car Wont Start
- Power Giving HEADERS
- a little help please
- MAP sensor location???
- FAST intake/TB questions...
- Is this a streetable cam for an LS 5.3?
- shopping for y-pipe and cats
- Problem with Ported heads
- Stock lift on LS1 springs ???
- 98 electronics
- Temp gauge not right on 00 TA. Ideas??
- question about superchips tuner
- LS1 Engine oil Analysis
- Lunati cams
- 3rd to 4th gear
- LONG longtubes?
- O2 Sensor Simulators
- any suggestions?
- have 383 need to change exhaust again...Which one?
- problem with dual cutouts
- New Owner
- Ngk Tr55
- Should I buy QTP long tube headers if i get a turbo system?
- Cam question
- Well i never thought it would happen...
- Ls1 spark plugs?
- AC DELCO O2 SENSOR AFS 141... good to use?
- thermostat
- how much abuse can the stock block take?
- Oil
- !EGR...!AIR Question..
- Valvetrain Geometry?
- Throwin a code, help please!
- How can i tell if my motor is an ls1
- Mangnaflow cat-back - Installation suggestions please!
- Help with water pump install??
- LS1 running hot,
- ported tb
- Few LSx Truck Questions
- no low end
- pro 5.0 shifter questions
- LS1 short or longblock
- Belt squeek!
- What could go wrong in a bad head and cam install?
- ls2 intake question
- Exhaust upgrade for SS
- low oil light question
- Anyone have pics of a K&N FIPK installed?
- spark plug question...
- dissappointed in lt header+borla catback sound
- C5R Heads and a GOOD CAM!!
- will a stock ls1 hold it
- Strange throttle response??
- How fast could it go?
- LS7 in an f-body
- p1416, hard to start Z28
- Crane Firewire plug wires
- Could these problems be related?
- Oil Pressure Question LS1
- ls6 heads???
- Patriot performance billet cams
- who sells
- Cold/Open loop missfire... need new plugs??
- help
- Just bought a SS - Hows the Ram Air work?
- 02 ss oil pump ? pressure???? please help quick
- water pump ac delco/bosch???
- annoying ticking/clicking noise
- max cam lift for stock lifters and springs
- How Do I Reach My Goal?
- Starting problem after fuel pump swap
- Whining Sound at Startup...
- heads/cam swap gone wrong
- dyno question
- Delco Iridium plug gap questions
- Bent rod or collapsed lifter? (clicking)
- way too much fuel
- Pics of a 2000 LS1 A.I.R. System
- relay for high speed fan ticking?
- CAM help?
- ls1 exhaust temp
- cylinder misfire
- ??about lifters. Not the what is this noise thread
- Block tolerence
- LS1 Valve tap
- SLP Upgrade Kit?
- What could this car do?
- pacesetter question
- O2 sensors malfunction
- Magic Stick 3 or 4?
- H/C/I package with 2.73 gears?
- fuel pump install ?
- 5.3L truck V8 vs 5.7L LS1
- Eating o2 sensors
- Futral?????
- 12 LSx intakes/tb variations tested on engine dyno
- 408 Knocking thats comes and goes
- Tornado fuel saver?
- smoke from exhaust...
- oil pressure
- Hello, Loud Hissing Noise Temporary
- Pacesetter's or SLP Long tubes
- catback install question
- MAF Translator and Timing tuner
- Water Temp gauge
- Rear O2 sensors
- Oil pressure gauge pinned?
- 382ci power potential
- NEED HELP ASAP...Intake Install Problem (PICS)
- Signs of a blown head gasket?
- $5k to invest in my car and no shops around
- Slp Lid
- russlo
- Long tubes/offroad y pipe...can I drive without rear o2s and o2 simms for a little
- Did the GMMG ZL1 cars have cats?
- what size band clamps??
- Track times
- Management
- in addition to whining noise on stock??!?!?!?
- filter question
- Info On Ws6
- whining, whinding sound
- Stock exhaust size
- engine prob help
- running lean?
- Oil Change Light
- True Duals install sound like a PITA!
- what the hell??
- a few Qs
- nervously bought a used compressor
- how to tell....
- ? about heads/valvetrain
- TEmp gauge hitting 250F...
- Exhaust Question
- Porting FAST INTAKE
- Quick!! Exhaust Question
- plugs, ls1 ?
- Wanna maybe save $80? LS1 idler pulleys.
- LS1 Timming Pickup?
- more cam ?'s
- Porting 5.3L heads, questions on exhaust port...
- need help!!
- LS1 a/c compressor and alternator in LT1?
- Are Edelbrock Tes Shorties Worth The Hp Gain??
- Redline's Performance Package or Tony Mamo's AFR set up..which one?
- Help needed ASAP, car on side of road
- stock cam specs on c6's??? NOT Z06
- 98 LS1 into 95 Formula info needed
- How was the coating on your Pacesetter LT's?
- installing Harland Sharp rocker arms
- electric water pumps???
- 2000 Camaro Z28
- AIR and EGR block off plates
- backfire/bad gas mileage
- Intake manifolds
- Anyone want to hear GMMG & Kooks LT's (catted-Y) on an LS1? 8 sweet clips within:
- Electric water pump
- Ls1-450 horse?
- Another 'What will it run' thread......
- time for upgrades
- So the exhaust it taken care of....help me pick a cam/accessories
- Edelbrock long tube headers for $365 ?
- LT install?
- Typhoon intake?
- Vapor Lock symptoms?! Need help (long post- ongoing saga)
- Looking at 98 Trans Am A4, have question
- If I get Long Tube Headers...
- What is the best exhaust
- on my way
- O2 Hell, please help
- cutout?
- Thermostat & AutoTap
- cam help
- SLP air lid problem
- Pacesetter LT install....how long for the 02 extensions
- ooooooh F13 I'm excited.
- magnaflow sound like straight piped chev pickups?
- What can cause LS1 Cam Retainer Plate Wear?
- hotcam on a stock z28 w/ a catback only?
- underdrive pulleys
- VRE Project 02SilverZ Update
- fuel pump
- Y-pipe, Does 2000+ fit 1999
- 'De-screening' MAF
- air pump removal question
