PDA
View Full Version : LS1 Based Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
  1. SSRA blocking transcooler
  2. lifters knocking after cam install..help!!
  3. ws6 exhaust options
  4. Anybody running Stg2Heads w/single springs?
  5. Exhaust flange dimensions on LS1
  6. SS VS. WS6 comparision
  7. Anyone have a Link To Ls1 Pacesetter LTs
  8. Sqweaky Belt
  9. Head Questions...
  10. Header install tuning?
  11. How much HP does the LS1 HC add ?
  12. Please help me guys my alarm is going crazy!!!!!
  13. LS1 in a first generation Camaro?
  14. I need pics of your cutouts
  15. Free Ported MAF?
  16. will ls1 k-member fit on 97lt1
  17. help with cutouts
  18. Car missed a shift and over-revved....what should I check for posible damage?
  19. Upgrading the brakes........anyone upgrade yet?
  20. guys with 99 to 00 Ls1 camaros and trans am what are u running stock in the 1/4 mile?
  21. LS1 runs out of gas, what next?
  22. those with true duals
  23. new ls1 headres
  24. ls1 really bad gas milage help
  25. cutouts on true duals
  26. randoms
  27. LS1 ,12's on sreet tires ?
  28. rocker arm clearance
  29. True Duals or Single?
  30. gutted cats or o2 sims?
  31. bolt on mods
  32. Intake choices (not manifold)
  33. Need help to finish project...
  34. How to remove back, backrest
  35. Air Box Base
  36. Impressive Times last night...
  37. h pipe, x pipe or y pipe
  38. Audible Detonation, What Can I Do?
  39. Where to get a good 250-300 AMP Alternator?
  40. x-pipe
  41. SLP header package (ppl with package)
  42. T BYRNE Motorsports is now carrying the SuperMaxx header package!
  43. throttle body bump stop mod
  44. How much power til my rear end goes?
  45. EGR Valve problem...
  46. What do i need to run 12's
  47. Do I need to upgrade my light wires for 80W and 100W krypton bulbs?
  48. Hyd lifter cleaner
  49. SLP Headers
  50. wouldn't start-why?
  51. Z06 vette mufflers on a Z?
  52. Bullet Mufflers
  53. Are the exhaust tips on an SLP Loudmouth prewelded?
  54. Quick Question For you guys...
  55. Finally bought the ls1sounds.com domain name!
  56. Hypertech power programer question ???
  57. Redline CFSC
  58. a slight bump
  59. Minimal Brake Dust. Which pad?
  60. Whats your opinion on cold temp thermostat ?
  61. Source for V-Flanges/Clambs
  62. gm ls1 hotcam
  63. new edit software
  64. Next mod
  65. Is This Possible?
  66. SLP's 345 HP wonder
  67. Pace Setter LTs
  68. how many miles on your ls1's
  69. Will an LS1 accept a S/C better than an LT1?
  70. engine missing!!!!!!!!!
  71. uhhh 02 sim frustration
  72. Torque arm install
  73. unplug Low Coolant Sensor...trip SES?
  74. Spohn TQ Arm, lowered car, clearence?
  75. Placement of Electronic Cutout Switch?
  76. egr removal...require imediate tune?
  77. just ordered my hookers!!!
  78. SLP 1.85rr + LS6 intake = 25hp @ the wheels?
  79. Does anyone make a head and cam kit that puts out 500+?
  80. The dual Exhaust thread.... over the axle... with pics!!
  81. What do you think of these 2 timing chains?
  82. Do I really need to spend $150 on an oil pump?
  83. How hard is it to install an LS1 in a 95 Z-28 Auto, Convertible?
  84. ScanMaster....worth it?
  85. engine- DEAR GOD PLEASE HELP ME!!!
  86. Suggestions on first few mods to LS1?
  87. Questions on LS1 problems
  88. How Are Delco Plugs?
  89. flowmaster
  90. when will the AFR heads be available for the LS1?
  91. If I do a cam and full exhaust, should I change injectors?
  92. SFC for convertibles and SLP Level 1 suspension pkg
  93. chilton vs. haynes whats better?
  94. TA Headlights
  95. Porting LS1 heads???Magazine Articles?
  96. What PushRods To Get??
  97. am i reading this correctly?....
  98. urgent caliper bolt question
  99. Selling LT1 to buy a LS1 Z28/SS, what is best/diffence in the years?
  100. b&m short shifter
  101. looking 4 Hooker Aero Chamer sound clip on LS1
  102. LS2 parts interchangability... who's got the inside info?
  103. weigh in here
  104. !! Push Rod Madness !!
  105. New to LS1's, mod tips?
  106. max capability of stock valve springs?
  107. Tach Install
  108. LS1 elect. WP....any reviews?
  109. ...loose...seat.....good reason to change out....
  110. if you have DMS and BILSTEIN HD NON-REVALVED please come in
  111. Tires, tires, tires
  112. Headers
  113. installed corsa exhaust
  114. Loud Bushing
  115. will stock LS1 heads fit a 93 350 TBi engine?
  116. GM's LS1 Hot Cam Kit
  117. Steering wheel vibration?
  118. A couple Q's to improve upper RPM durability
  119. Got A Tick In My 99
  120. Just put a cutout on my car! My impressions and advice....
  121. best brakes?
  122. Best spark plugs for my BABY?
  123. Poly motor mounts and trans mount
  124. suspension
  125. noisey bushings??
  126. 6.0L LS1 .030 Piston
  127. Muffler People Inside Please! NOW!
  128. dumb ttops question
  129. magnaflow catback people inside
  130. Altenator installation
  131. Looking At Getting Some Pacesetter LT and y-pipe.
  132. Anyone got any chrome ta wheels
  133. ball joint question
  134. Thinking of buying an LS1 car.
  135. SS ram air hood
  136. V-6 to ls1 swap
  137. Wireing question. Would like to install a trunk light.
  138. Steve, meet Guardrail...
  139. is it possible to use a VIN to see if a 98 camaro is a SS?
  140. low coolant light - bad sensor like the lt1s?
  141. throttle body opinions
  142. Car wont start.....help
  143. problem with ls1 Main stud kit
  144. Input on hugger orange ss
  145. Just installed LT Pacesetters/ORYP....
  146. SLP's 485HP heads and cam.
  147. rare color
  148. Anyone dyno their car recently??
  149. LT's, need advice for cali f body
  150. Water pump gaskets
  151. Pricing question
  152. Wipers wont go down???
  153. getting into rev limiter
  154. What gains should I expect?
  155. Worst LS1 dyno ever?
  156. Stock Dyno Numbers Seem Real Good
  157. 01-02 slave cylinder?
  158. Shorty Headers
  159. k&n fipk and bellows
  160. Turn signals stop working???
  161. Cam Questions
  162. Exhaust question?
  163. ram air & hood latch
  164. What would you do??? '98-'99 or '01-'02
  165. Borla exhaust
  166. 99 Camaro Z28 Monsoon door speaker replacement ?
  167. Bolt on vs weld in sfc
  168. gas mileage
  169. Headers: SLP vs. Hooker
  170. Ss & Z28
  171. CAM install write up.
  172. Who has pacesetters?
  173. anyone put on their own springs?
  174. Help!!! Where is the Control board???
  175. Final Decison...LS1 owns all.
  176. exhaust leak at Y-pipe/collector help
  177. Switch
  178. spring failure
  179. Broken Manifold Stud!! HELP!!
  180. 427/78mm LSX test
  181. oops I arched the battery!
  182. Motorvator Throttle Body Spacer
  183. my z28 is fine
  184. INstalling ls6 cam what other parts ?
  185. Oiling Holley/K&N filter?
  186. whitish color smoke
  187. what set of headers for...
  188. hooker headers LTs on a A4
  189. Muff I mean Mufflers
  190. Anyone take out their 4.10's to put in a 3.73 or even the stock gear in...
  191. Ride quality....and why it sucks...
  192. Bad idle?
  193. Idle quality
  194. Whats the most HP out of an LS1?
  195. What are LS1's supposed to weigh?
  196. Double checking what I was told about installing cutout.
  197. New mods... Cam Specs
  198. parking brake in the way of power source
  199. Removing EGR, what to plug intake with?
  200. Just bought some Hooker LT's, what else do I need?
  201. LSX intakes are out!
  202. Ls-1..same?
  203. ASR (traction control) noises
  204. pinging and major kr
  205. How do I get the headliner out??? (T-top)
  206. Used car, New motor
  207. Putting 98 speakers in an 02
  208. people with a hotcam in CA can it pass emissions?
  209. Stock rocker studs for high lift came?
  210. Want a g5x2 grind, but not the $500 price...
  211. Anyone have DMS springs and Hooker LT's?
  212. Fog lamp question.
  213. Battery Corrosion
  214. different sized wheels?? good or bad idea
  215. is it possible?
  216. Air Box Base Interchange???
  217. Headers?
  218. What Next
  219. Gapping of TR55 Spark Plugs
  220. Rough Start!?
  221. Will 1999 Z28 Camaro Gauge cluster work on a 1998 Z28 Camaro?
  222. exhaust????????
  223. How many LS1's went 12's bone stock?
  224. SLP underdrive pulley
  225. squeaking powersteering cold start up?
  226. Any Oil Leaks On 100k +
  227. lights dim
  228. GM B4C police brochure
  229. Shift light wiring
  230. 60-0 Braking Distance
  231. Manual Fan Switches
  232. intermitant rough idle, no ses or idle flucuation
  233. damn brakes man!!!
  234. first 1/4 time
  235. anoying noise when ac/heater is on
  236. Still need more exhaust clips and info!
  237. Applied or Random Exhaust?
  238. Not exactly good but...new best
  239. how do you disable auto headlights on 99 gmc trucks?
  240. space
  241. How to change signal bulb on TA???
  242. Clunk noise when rolling over bumps
  243. Window wont roll down (not motor)
  244. Is this an ss or not
  245. Speaking of HPP3..
  246. Front suspension question
  247. setting for hpp3
  248. are ws6's lower than T/A's?
  249. Ls1 , LS6 now the LS2 ..whats the LS2 ?
  250. upgrades ?
