View Full Version : LS1 Based Engine Tech
- has anyone changed the bulbs in the cluster to red in their camaro
- Trans Am Vs Trans Am Ws6?? Whats The Diff?
- Tranny/Clutch problem
- dyno!!
- GM OEM Parts
- Loudmouth exhaust question
- wrecked 2001 LS1 for parts only
- electric supercharger???
- Macs vs long tubes
- little mods?
- Aluminum Flywheels..what do you think?
- SFC's...tubular or boxed??
- New mods before dyno!!!!!
- GMMG exhaust install.
- Hey Guys, Please help me out...........
- Slp Header Install
- Dale Earnhardt Intimidator SS Camaro - 381hp? HOW?
- Opinions on this Ebay 'custom' shifter?
- Fipk ?
- Leave 2.73 car in 2nd (1/4 mile)?
- Does hypertech have a vin lock?
- Fixing to install Loudmouth... Couple of questions
- Check out my new 4" WS6 hood
- firestone dealer or tirerack?
- Firehawk sz50's or Nitto 555 extremes?
- Broken Transmission mount?
- Exhaust Problem?!?!
- Does this look good?
- Burnout Help!!!!!!!!!!!!!!!
- Anyone know the part #s for --->
- Dyno numbers on my SS
- New IBCM installed, now can't start car
- Anyone else have a hard time feeling the TORQUE of the LS1...
- How can I tell if the clutch is going out?
- 94 TA Upgrades
- Best set up for supercharger
- $3500 extra and its slower?
- hot cam in 2002 z28
- I have to know how Pontiac's are doing this with their taillights.
- Help, friend's 99 Z28 Won't shift right.
- cam for LS1 SS
- 17x11" Wheels on the Rear of my Camaro?
- HELP!!! Loud friction noise that vibrates through the frame
- Is QTEC cutout adjustable for how much open????>
- Anybody got info on "Ultra Z" hood?
- What tranny swap can I do for a 99TA Auto?
- What kind of power from TR224 Cam
- anyone running SLP loudmouth exhaust...please help
- sfi approved felxplate help
- Dynatech Headers?
- what month was production stopped on the f-body?
- Can CATS be cut off of LS1???
- CAM you help me?
- 1/4 Mile times for 02 SS Auto
- Drill Mod for Clutch Master Cylinder
- Heel and Toe and Double Clutching
- Hood Help
- Exhaust work = Better or Worse MPG?
- How to remove console?
- ya*ll
- ALL LS1 Fbodys defend yourself
- Cam/heads
- Brake pads for front brakes of my LS1.
- magnaflow exhaust!!!!!!!!!!
- Weight of HT cars vrs T-Top cars with same trans.?
- whats a torque converter?? ya im a idiot.
- Tires??
- Trans Am video
- really dumb question
- High tens??????
- Mac Headers w/ORY any problems?
- Towing with and Fbody?
- Looking for a product
- Help!!!flp Header Install Question
- What diameter for exhaust tips?
- turn singles fading out!
- Torque Convertor ?
- Oil Filter Change
- 2000 Red SS 6-speed
- LS6 or LS1 heads?
- What will my Ws6 run
- Corsa sound clips...anyone ?
- Best Deal on dynoing In Houston????
- oil question
- What mods next?
- eradispeeds or powerslots?
- LS1 header question on install
- Putting an LS1 in my GMC
- 1st time 1/4 runs...yea i suck :)
- or OEM SS hoods numbered???
- MAF screen... does anyone have the real facts on it's function?
- LT4 Impala? Please respond
- Supercharger just installed
- HPP3 resulted in a ticket
- Accessory Belt Squeal on LS1
- Weight and Line pressure
- Help me out !!
- Ballpark hp estimates from 216/220 cam?
- LS1 - LS6 port comparo
- Bought a 98 Z28, mods for 12's?
- Gas
- A4 LS1 times
- SFC's for vert, opinions or options?
- Trapped in 2.0+ 60' time
- Dyno'd my 2001 SS today for the first time...
- ..any pics of true duels with longtubes?
- driveshafts here driveshafts there
- Holley powershot filter
- Quick help, speaker covers.
- Replacement Gatorbelt part number.. ?
- will P285's fit on front??
- Clutch and brake or downshift??
- Will these parts work on my car?
- RPO code PBT?
- Cars doing some weird electrical stuff....help???
- pro 5.0 problem.. help!
- Heads for a ARE Stage 2
- It there any use in changing the exhaust on my WS6?
- cam for stock heads
- I need info on NOS
- Stall converters?
- Problem With Idle
- blinking SES?
- Are my heads ported???
- NE Emissions what's in it?
- Called SLP, got info on speedometer recalibrater
- ..do I need an edit if I go from 275 to a 285 tire?
- Cliff Hugging
- SS ram air
- Air Filters
- Torque Converter, should I get one?
- is all SS cars from SLP? look inside...vin # ?
- 2.73 or 3.23?
- Recall 96 to 98s.
- ground clearance
- RWHP gains from this exhaust??
- Which Exhaust(Cat-Back)
- Question about RPM
- My Dynomouth is louder than....
- oil light
- autoTap or an other?
- Who has the best aftermarket heads for a N/A car
- question for A4 LS1 people
- HPP3 Questions
- Good New For Southern California
- 6th gear
- Anyone got these dyno #s with just exhust?
- camaro hoods
- rich or lean...how do i check???
- How "smart" are our PCM's ?
- What does a stock LS1 put at the wheels?
- shift knobs
- Do i have as much power as an SS?
- Mobil 1 Synthetic users
- SES Code 1416
- Exaust question!!!!
- how low shuld i go?
- super syn mobil one
- Single turbo setup?
- How much is a new clutch going to set me back?
- speed rating
- FLP Header bolts...
- Z28 Vs SS
- 3rd gen 10 bolt 3.73's in 4th gen 10bolt, will it work??
- 315 rubber on 9.5" rim???
- center exhaust
- clanking from under car
- 2000 camaro
- Gotta replace my speakers.. need advice
- 94 rims on a 01
- how much r SS hoods?
- what rear end do I have
- security
- Slp shifter ???
- what spark plugs
- great run
- GMMG Equiped!!
- build numbers
- Do ls1s ever blow up on the dyno?
- LS1 oil consumption
- yellowing headlight lens
- Help with "drone" anyone??
- A4
- "17"x"10" in the back "17"x"8.5" in the front, will 275s fit
- Speed Inc stage II or FLP 4L60E?
- Nos
- gears in LS1
- high flow bellows
- ZO6 MAF in Place of LS1 MAf
- water leak
- drive shafts
- LS1 Fuel Rails
- Sound Deadening Materials
- Who knows about Air/Fuel mixtures ?
- Corsa cat-back, 3" or 3 1/2"
- Forget Blue Book! How much should I ask for my 02 SS. (Tons of pics at link)
- did another dyno saturday
- A4 LS1 racers
- 2.73 or 3.23
- 1st oil change... help!!
- I need your opinion on mods
- depreciation amount.. any ideas?
- Exhaust dump: good, bad??
- Clutch Replacement Which Brand?
- Help W/ No EGR LS6 intake on 98 Z !!!
- Gear shift method
- Getting headers will rear end hold?
- Using Headers in Maryland
- Has anyone sent out their F-body to Lingenfelter?
- Tire Brand?
- insurance for a 98 trans am!!!!
- Anyone have problems with pulleys??
- How do I convert quarter t\mile times to standard times based on temp. pressure and h
- New best N/A
- Whaddya think of this PCV solution???
- Slp 2 on the left?
- Are LS-1's reversed cooled?
- y-pipe
- Got some qtr mile times in the 2002, what do yall think
- Headlight replacement code for hyperwhites?
- 12.6@114.5
- O2 Sensor Problems after offroad y-pipe install
- leak
- slipping clutch
- Lighting upgrade question
- Hard shifting restriction fix! for M6s
- help!
- Proud new LS1 owner.
- check engine light
- GM part number for 17x9 SS 10 spokes?
- SLP Grille
- troublesome oil change
- Loudmouth aliitle annoying any help?
- Camaro's suck ass or do they???
- Slight problem with Pro 5.0, and not notchy
- New track times...bitter sweet!
- rear-end recomendation
- Cam for LS1
- Does my car have ASR?
- New 'ASR' or fog lamp switch
- QTP Cutout
- Drove through water...agh!
- '01 SS with 12K miles
- FLP headers
- noise when i slow down
- I want to install 4.10's, do I need to recal. speedo?
- 2001 SS Exhaust specs?
- weird noise, any ideas?
- rearends?
- Couldn't get into the 12's
