o2 sensor millivolt range....
Old Jan 17, 2005 | 12:53 PM
teke184's Avatar
been scanning my car, and i'm thinking my o2 sensors are getting bad.
but i don't want to replace them if they are not...i'm pretty tight on $$
watching the scanner it seems that my o2 reading jump all over the place when just sitting at idle.
i've watched the millivolt readings and each bank seems to jump around from 100mv up to 900mv and everywhere in between.
and it always seems that one bank is really high, while the other is low (in that range). but then a few seconds later it will reverse.
IS THIS NORMAL? for all i know this is the normal range.
thanks
Old Jan 18, 2005 | 08:54 PM
AL SS590 M6's Avatar
Moderator
Re: o2 sensor millivolt range....
thanks
normal, it's called switching.
Old Jan 18, 2005 | 08:58 PM
teke184's Avatar
ok...
so what is the actual range?
for all i know the normal range is 100 to 10,000 which is why it doesn't really make much difference having them "switch" a few hundred
thanks al
Old Jan 19, 2005 | 12:32 AM
silverZ98's Avatar
they will switch back and forth at idel only way to read then is wot and then they will stablelize.
Old Jan 19, 2005 | 01:05 AM
97bowtie's Avatar
They are cycling which is completely normal. 100 - 900mv is about the range.
Old Jan 19, 2005 | 06:49 AM
teke184's Avatar
thanks guys...
hmm...dont exactly want to sit at wot in my driveway...guess i'll try something else.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
