View Full Version : LS1 Based Engine Tech
- what does it take to get 650hp?
- Fra
- Does anyone have the site where...
- TR230 cam???
- Lifter noise
- Help out a friend
- 98 Camaro Z28 - Red Top Optima Battery ???
- 2001 V6/V8 Engine Swap
- ?? Jet Hot Header Installation
- Cam swap questions, *1998* specific,
- What Cam to use????
- c5r vs sb2.2
- LS-1 Stroker kit $4102.00?
- ls2 goat or 02 ws6
- Powersteering flush
- Why Futral Motorsports cams are the best ;)
- EGR block off question
- Difference between LS1 and LT1
- 5.3 or pp stage 2 ls6
- Quick water pump question
- Need some help- LSX carb conversion not getting spark with supplied ignition box
- Squeaking noise at Cold Start - Belt or Pulley?
- Need help, blowing the ign 50 maxi amp fuse all the time
- standard bolt ons
- Right y pipe for hooker LT's?
- O2 sensor question
- Lets talk Exhaust!
- dyno/track results from DART LS1 heads?
- Rebuild parts
- Why would my crank pulley wobble? HELP!
- I'm an idiot when it comes to cams...HELP!!!
- what does it take to beat a cobra?
- Couple questions on my 02WS6
- Cold Starting Problems.... need HELP asap!!!
- Anybody running a Cheatr or Old man cam?
- What companies sell souped-up LS1 engines?
- head and cam setup
- OHV PFI vs LS!
- Starting problem on my 2000 Z28
- Stock operating temps of LS1?
- ls1 forged cranks which to buy?
- Qtp Headers?
- Tell me if I'm right?
- Clear MTI Air Lid for LS1 - any good?
- Can you switch from conventional to synthetic oil
- Switch from conventional to synthetic oil
- Metal grinding noise comming from my engine!!!
- General question about the LS1
- LS1 fuel system swap
- y-pipe
- WS6 lid
- BBK vs. LS6 (Intake Manifold)
- Exhaust?
- ls2 headers
- Coolant/Leak-Adding "the stuff"
- Differences w the LS1 in the 1998 to 2002??
- if some one could give me advice
- aftermarket coil options
- SLP Question - First Post
- ? Patriot Heads
- exhaust question
- Cam Identification Help
- Cam Suggestions/Help
- Fuel Pressure Problem
- How long will LS1 run ?
- At what RWHP is it time to upgrade the injectors and/or fuel pump??
- Bought my '00 a week ago, now I think I may have a spun bearing!!
- LS2/ ecotec engine weight?
- changing plugs and wires
- putting in LS1 into 96 camaro
- casting #12562317 heads? Power?
- Clear Lids?
- New Lid Question
- Can I use a 3" Rubber Connector from a Hardware store for a Smoothe Bellow?
- SpinTech mufflers
- SES Light - AIR System Bank 2 code
- Whistling noise and crackling sounds....I hate my car
- Headers..
- Where can I get cheap LS6 springs from?
- 6.0 truck question
- LS1 cooling system
- noise
- With pure boltons, how much power can you obtain in a LS1?
- ls1 edelbrock carb kit help.
- If anyone needs LS* Info. Specs, P/N's, info.
- Quick Help
- what mod can get you 400rwhp
- Belt squeek on 2000 Z28 A4
- ls1 head flow #s
- Little help please
- What kind of gain from Z28 to WS6 exhaust?
- Is this bearing reuseable?
- 1/4 mile time?
- Ticking
- what does it take to get 375rwhp in a 98 ss?
- headers
- Finding the right place
- Rear Axle Code Gu5
- Broken pushrod I think... What to do?
- how much hp and torque with a4?
- LS1 Engine Break in
- advice on ls1 mods
- LS2 in a '77 Camaro
- EGR Question after installing LS6
- Budget estimate on 1st gen. Camaro LS1 swap
- Where can I go for help on converting a Gen I to LS1/T56?
- Need advice on plugs, wires, and seafoam
- How to install Headers?
- My Coolant smells like ****!
- head and cam pack thats smog legal
- Auto vs Manual
- 98 ls1 reluctor wheel?
- Gutted cats
- ls1 or not
- How Restrictive are High-Flow Cats vs. ORY?
- throttle cable too long??
- Ned some help, hesitation/misfire
- What Does It Take To Get An 02 Ss In 12's
- When to tune up LS1?
- Hypertech programmer
- broken bolt
- LS2 questions ...
- What next?
- Bad Idler Pulley
- Pulleys? FRA?
- Can anyone recommend a good LS-1 tuner in Northern VA
- Mods without voiding drivetrain warranty
- TB BYpass
- Shop Manual for 02
- Other mods with a TR224/224 114?
- Looking for a shop to do heads, cam and headders
- Egr
- car dying out in reverse
- Shorty Header Collector Leak???
- Installing cam bearings
- X1 (MTI) or TR230 cam (ThunderRacing)
- Lifter Noise at startup 97k on 99 LS1
- What would my car run?
- Fuel gauge stays on "empty"
- fuel smell inside my 01 t/a...
- Its falling apart
- ls6 intake manifold
- Dex Cool
- GMMG WEB address
- flashing SES after hurricane flooding
- Belt Whine
- LS1 lifespan
- Car stuck in gear after 12 bolt install... HELP!
- Katech's new project Street/Strip/Show car
- Is it worth the money?
- loudmouth pics?
- New driveline source
- Best Cold Air Intake for Z28's
- Need help!
- How to get in the 12 sec. class with stock LS1
- Engine Swap
- Need a picture
- what cam?
- Ls1 body control module help!
- Which Headers?
- center mount exhaust
- SLP Loudmouth too loud?
- ls6 intake pics?
- Bolt-on's
- Intresting delimna.....track times....dont add up!?
- K&N: Track Only
- low rpm misfire/bad gas mileage. no code?
- Loudest Exhaust Setup LS1
- Underdrive pully
- ls1 rebuild/mod all in one ?
- Valve covers
- Ls1 Verses Lt1
- Dual Loudmouth Setup????
- LS1 ECM issue?
- Bad Compression or Seals.......or am i just paranoid?
- Question about car.
- ORY for '02 with stock manifolds
- Cleaning the LS1? steamcleaning ok or a no no?
- HPTuners 2.0 Finally released!
- Really quick question
- 1997 LS1 vette numbers
- **Which** is better
- Update on 226/226/112 User...
- SES Codes: P0122 and P1133
- Cost of an LS7 swap?
- Bore/Stroke to a 440?
- ls1 true horspower rating?
- LS1 sounds
- engine whine at start up
- Where to buy LS1Edit?
- P0410: Where do I start?
- New to owning LS1
- Anyone had any luck bleeding an LS1 slave cylinder??
- ls1 specs/info
- Cam Question
- Just got myself an 01 LS1, Got questions...
- belts?
- Can A/C cause SES light?
- noisy belt system
- Stall Converter On Stroker
- water pump leaking, upgrade? LS2 better?
- Rebuilt LS1
- Good site for information
- Power band?
- Knock Sensor???
- Where to buy ans opinion
- Smoke coming from hood
- Spark plugs & wires
- Pacesetter headers
- Camaro SS M6..... Bogging
- Cam question
- Dart 225cc Head Pics
- Slp Headers on a Vert
- Bad water-related misfire need ideas please..
- Maf
- Change Oil Light
- Header install question
- HP guess for possible new vehicle
- going to buy 01 or 02 ws6 or ss!! woo wee!! pros and cons of both??
- Headers
- thinking about buying a ss
- Buying 02 Trans am? what to look for?
- What Do I Have
- '02 Lq9
- need help
- block difference
- no start problem
- surging at part throttle ?????
- Does anyone here run the 221/221 grind anymore?
- Gimme some advice here. Electrical issues
- Whats the purpose of switching to LS6 style PCV on LS1's?
- Buying
- P0300 after Trex install, i've check about everything!
- torque converter or cam?
- Scheduled injector cleaning?
- O2 Simulators For Catted Y-pipe
- 2001 trans am ws6 fuel/misfire problems???? need help
- RPM's dropping under load?!?!?! HELP
- Dash Lighting Up after hard shifting or bump
- Should I buy this MAF???
- LS1 Billet Fuel Rails
- Free mods and stuff??
- pulley setup
- Best book for LS1/LS6 rebuild info
- Ls1 Edit
- Quieter exhaust with performance?
- Oil pressure seems a little high after changing oil. Please help.
- Help w/throttle body and IAC
- Please help with crappy idle and surging
- My Personal Car/Motor Pics
