PDA
View Full Version : LS1 Based Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
  1. Help me install a kill switch (2000 Z28)
  2. Loud clank when going over bumps. 98 TA Cause?
  3. Rear end grinding noise
  4. MAF Questions
  5. Can I get 35th Aniv SS wheels?
  6. Delco Batterys
  7. Where are the best speed shops around Detroit???
  8. If you could do it over again
  9. Does PCM retard timing?
  10. free ram air mod question.
  11. New to the LS1
  12. Cam Package
  13. SHOCK TOWER BRACE will it fit?
  14. Rear hatch sensor
  15. headlight grinding, are they rebuildable?
  16. 60 or 90 degree engine
  17. stock y-pipe questions
  18. what oil weight do u guys use?
  19. Squeaky screeching brakes
  20. Tranny clunks very often
  21. Do our rear brakes warp like the front?
  22. Broken auto trans
  23. Koni shocks on slp package
  24. power steering bypass
  25. expected 1/4 mile time for a 99
  26. My friend told me that there is only 2 cams for LS1's, an F1 and a LG, is that true?
  27. fast toys ram air
  28. DMS Subframes
  29. 6 speed transmission clanking
  30. BMR Bolt-in LCA Relocation Brackets
  31. Gtech Competition HP/TQ
  32. Will a 94 rear end bolt up to a 99?
  33. True Dual Exhaust
  34. LS6 to LS1 intake manifold swap...
  35. Performance Mods List
  36. Aftermarket engine mounts...
  37. cubic inches?
  38. Whats with our horns???
  39. Question for someone with a MAFT
  40. watch out for this
  41. Are the Granatelli MAFs really worth it?
  42. Subframes beneficial or not?? Do i need them - please help
  43. gear whine?
  44. SS Camaros & SLP Options
  45. Best short throw??
  46. gas
  47. Best C5 catback?
  48. gear change cost
  49. Poly mount! Ya'll were right about em lol
  50. traction button in 98 LS1 Z28? is that true?
  51. non Z-Rated Tires
  52. Car will be back today!!!
  53. To Lean
  54. SES Light and misfiring
  55. Strange problems developing
  56. Does the Supersucker setup really work that well?
  57. Longtubes on a C5
  58. Damn thats loud!!
  59. Need help changing my tranny fluid.
  60. 275 vs 315's...much diffrence?
  61. Off Road Exhaust for ls1
  62. Does anyone make white face gauges for an LS1?
  63. What do you see missing from this bay?
  64. Help with low dyno on '98 Z
  65. Dyno'd the CETA on Saturday, ABS INOP light remains on...
  66. Best Cat-Back/Header combo
  67. 17's or 18's RIMS help please which ones??====>
  68. Why does my Throttle body have 2 cables going to it?
  69. B4C Camaro Question
  70. ss camaro and ws6 firebird???
  71. Anyone else's TC's make their car stall? :)
  72. Launching from 2nd gear
  73. New muffler on stock center exhaust?
  74. Fipk?
  75. wheel offset
  76. SLP suspension...whats does it come with?
  77. Howdy..
  78. 4" Mufflex and SLP LTs??
  79. Autotap Crap ???
  80. LT1-LS1 Shoot-out canceled! If you were attending you need to read this!
  81. Engine Noise, Please Help
  82. quick question on cam install.
  83. Where to run wires for electronic fuel gauge
  84. New Ls1 Lid?
  85. HELP...BMR Bolt In LCA RELOCATION....
  86. Lid vs. Stealth?
  87. LS1 swap into v6 bird or camaro. How hard?
  88. Mobile 1 or K&N oil filter number
  89. Rev limiter comes too soon
  90. Best brake pads to get?
  91. Thinking about a cam??? Your opinions please!!!!!!!!
  92. Opinpions on shock absorber upgrade
  93. Where can I get an official SLP Lid?
  94. 3.42 or 3.73 Gears
  95. polishing....
  96. Possible colapsed lifter!!!!
  97. SLP loudmouth....
  98. Loud squeak during shift?
  99. My Brakes make a grinding noise!
  100. Oil pump problems
  101. Lower control arm relocation bracket question
  102. Cutout
  103. Torque Convertor + Subframes = :-)
  104. My car shifts waaaay past redline!
  105. Used Cam
  106. Reseting ECU
  107. So, how screwed am I if.............
  108. Lid & Ftra Results
  109. "Boxed" suspension parts?
  110. finaly droped some ca$h...on the corsa!!
  111. Ok I think its time to mod the 30th
  112. Dyno numbers?
  113. Question about LCA's ?????
  114. differances between 98-02
  115. Electric Exhaust Bypass?
  116. Question about 35th Anniversary parts
  117. Is this possible???
  118. Removing resonator from SLP exaust
  119. Best place to get Loudmouth right now?
  120. My dyno #'s are low....:(
  121. Casting differences between LS1 and LS6 heads
  122. How to change DRL?
  123. Where is the hole in the firewall?
  124. My turn signal is acting weird!
  125. Cutouts
  126. Ls1.com
  127. Pro 5.0 or B&M Ripper
  128. For anyone who has 3.73 or 4.10 gears
  129. Good suspension...help me!
  130. where can i buy the ac delco pcv valve?
  131. Z-28 suspension vs. C5 suspension
  132. Pics of the new Supersucker "track" lower airbox
  133. Why $900 For A Torque Converter
  134. Extra ram air mod....why not?
  135. engine degreaser
  136. Engine Terms
  137. rear end and suspension question
  138. How much off is my speedo w/ new gears?
  139. Would i beat a Lightning?
  140. SLP 1.85 Rocker Package?
  141. Stock air assembly Mod, CAI
  142. 'Oil Change' light ??
  143. Mod question
  144. Energy Suspension Tranny Mount??
  145. Moser 12 bolt finally in!
  146. Dex-Cool: Who thinks it really lasts 150k?
  147. Oil Change
  148. Z28 bolt ons.
  149. Questions on Skip Shift Eliminator
  150. Suspension Help!!!
  151. Helicoil in oil pan drain normal?
  152. Small Block Crate Engine
  153. Y-pipe
  154. time to buy new tires
  155. Ftra?
  156. 2000-'02 Hooker long tubes now available!
  157. I love my Qwik Stick
  158. question about types of LCA's
  159. 1LE Trans Mount ???
  160. Jet hot brand Long tubes
  161. LS6 Heads/Cam or Hot Cam/ported LS1 Heads
  162. Porting ls1 heads...
  163. deleting the AC system..how to?
  164. Very First Mod
  165. How many qrts of tranny fluid does a ls1 hold?
  166. pinion angle?
  167. Exhaust Tips- how close?
  168. need help with a slight skip????????? 99z
  169. 2002 SS auto 1/4 mile?
  170. Quiet Hi-Flow exhaust?
  171. How hard is it to fix...
  172. 02 Z28 questions.
  173. My SS feels sluggish :(
  174. Air deflector Panel removed is okay?
  175. C5 or '02 SS?
  176. Got a question for you guys?
  177. Faulty Window Under Warantee
  178. Disaster at the strip.. Possible bent pushrods...
  179. why are LS1 heads so cheap on ebay?
  180. If you have Lou's Short Stick, please come in.
  181. What Is Wrong With My Car
  182. Brake Control Module
  183. head porting, newbie questions
  184. Rear End
  185. which Y-pip BORLA or MUFFLEX
  186. Stealth airbox VS Lid RESULTS
  187. Tire/Wheel Change
  188. camaro foglights
  189. HPP3 Tuning Question?
  190. Headers Vs Slp Loudmouth How Well Will They Work Together
  191. Gas Mileage
  192. Vortec and LS1 Similarities
  193. good cam?
  194. Jet Stage II Module on 98z M6 - worth it?
  195. How do you LS1 guys like your Monsoon stereos???
  196. How much to paint hood?
  197. Will a 97 gauge cluster fir in a 98-02
  198. ls6 intake w/o egr?
  199. ls1 #'s to an ls6?
  200. suncoast intake?
  201. What should I run with this combo?
  202. Should i do this??? HELP ME OUT
  203. Cut out or No Cut Out that is the question!
  204. Light It Up
  205. Guys, I need help with this Stealth airbox.
  206. cant start car, Security light comes on
  207. EGR Mod?? what does it do?
  208. How do i make flames shoot out of the tail pipes???
  209. Belt Squeak
  210. Need advice on Auto Security Devices
  211. Air Pump Removal
  212. Cam Sensor????
  213. 1.5" drop with ET Streets/BMR Boxed SFC's?
  214. Dynoed car today
  215. Need help with buddies shift lite
  216. Clutch sticking on 99
  217. Mods, Mods, OH and Mods
  218. car droops to the right...what the heck???
  219. How hard is it to.....
  220. Best best deal for LS1 strokers?
  221. Shop Manual
  222. Getting SS What exhaust should i GET!!!
  223. LS6 block in some F bodies
  224. Need Help....valve spring, retainer, keepers!
  225. Rear rotor size
  226. Results from TCI 3800 torque converter, 200-4R conversion, and stage II heads!
  227. Please help, CAI, pain in the butt!
  228. 2000 Ss's?
  229. Help SES and Code P0118
  230. How to find # on ss
  231. CORSA Exhaust ????
  232. front brake pad difference in 1999 vs 2001?
  233. How to use SeaFoam?
  234. JC Whitney or Auto Zone rotors?
  235. Question About Door Windows ??
  236. LS1 k-member install..
  237. LS1 Z71??
  238. Lou's Short Stick!! Good or NOT?
  239. LS6 Intake,Cam,MAF or a "Real" cam only
  240. siren sound at rear??????
  241. Stock LS1 w/75 wet shot vs 95 5.0 w/H-C shorties & 6psi charger
  242. Best Exhaust Setup
  243. stupid question
  244. whats wrong with my transmission? HELP
  245. air conditioner compressor won't shut off
  246. LS6 swap
  247. Edelbrock Headers
  248. Will certain trans's fluid's help fix sycro's
  249. URGENT HELP NEEDED!! -- Lower Control Arms
  250. Problem Starting Car
