Tips for header install
Old Dec 27, 2004 | 09:19 PM
My00Camaroz28's Avatar
Well Im about to install Mac Mid Length headers on my 2000 Z28 and would like some tips/advice to make my install as easy and stress free as possible. Are there any things that you did that you wish you hadent? Please post here!
Old Dec 27, 2004 | 09:50 PM
teke184's Avatar
Re: Tips for header install
all the tips and tricks i have are on my install page for LTs...
page 11 of the website in my sig
the one HUGE suggestion....install poly motor mounts while everytihng is out! MUCH EASIER and will virtually eliminate clearance problems!
Old Dec 27, 2004 | 09:52 PM
UltraZLS1's Avatar
Lay a straight edge across them and make sure the mating surface is level.(where it bolts on to the exhaust ports)
I had this problem with my flowtechs and had to send them back. If yours are off too much they could leak. They are probably fine just check them.
I would also suggest going with long tubes. It is a lot easier and cheaper to install different types of exhaust systems on them compared to mid lengths. Such as a rumbler x true dual system which will bolt right up to pace setters and jet hot headers. Long tubes also produce better numbers and you will have no clearance issues unless you buy slp long tubes.
Old Dec 29, 2004 | 01:10 PM
One more question: If I install this and after I will be setting off the SES light, this wont affect anything at all right? The reason I say this is because a couple days or so after I will be sending in my pcm to get reprogramed.
Old Dec 29, 2004 | 03:59 PM
teke184's Avatar
removing the AIR and EGR and the cats will have no effect on the running condition of the car in any way (other than louder).
you'll be fine till the reprogram
alex5366
Exhaust System
Mar 8, 2015 11:28 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Jlo
Feb 23, 2015 12:20 PM
alex5366
Feb 17, 2015 09:07 AM
dmcdonald96
Jan 30, 2015 06:46 AM
