View Full Version : LS1 Based Engine Tech
- easiest way to get out ls1 and t56
- Too many miles?
- M6 fluid change...questions
- Whats the current dealer holdback from GM for Camaros? Buying Monday!
- What can LS1 Edit do?
- New '02 Z28 convert w/ 6 speed
- 1/4 mile times
- Is this normal?
- New Dyno with N20
- Maryland Camaro clubs?
- Stock LS1 head chamber volume
- I Need A Vin Interpretation Fast!!!
- What's the stock limiter set at for the LS1??
- Will a after market muffler drasticly decrease the future value of my car?
- quick fix for chirpin belt????
- Newbie question about cams...
- electric cut out
- Is This Safe?
- Looking for new Z28, finder fee paid! Post the deals you got!
- My LS1 camaro must go! check out this price!
- To change or not to change...
- BEWARE 35th Anniversary Owners!!!
- Aftermarket Rear Question
- What Converter should i get to go along with my mods?
- What do I need to change my 200 watt Monsoon to the 500wat T/A Monsoon???
- So 2001+ Camaros Have The LS6 Intake Manifold?
- Headlamp pigtails
- N/A Tuning....I got cost, need suggestions...
- gas mileage
- Oil Change = Metal ? ?
- Gears or Lid?
- Bigger fuel injectors...
- 93 or 94 octane, what do you use?
- Stupid question but.....
- chirpin belt
- new guy needs help w/ rear axle
- Some cool videos of my 02 M6 Z28 (dyno, roll-ons, NOS, elec cut-out...)
- First Track Time on 99SS
- Question about 2000 year LS1s...help?
- went to the track bone stock....
- 2002 Camaro SS Johnny Lightning
- flip up lights
- Dash/Body computer
- Best Short Tube Headers?
- How is LS1 Timed?
- Buying FLP Headers soon...
- Choosing an air compressor........
- Mods that can be done under warranty?
- Cam Selection
- Break in
- Theft Deterrent
- Head / Cam Combo
- Pro 5.o Vs. Hurst
- What is the average life of a LS1?
- Choosing a Cam
- Who's got a good, clean picture of their car??
- What is under the stock grille piece?
- FLP vs SLP who makes better headers
- Me 2000 m6 Z...Him 2002 m5 GT...I beat him by a car?
- N/A vs. Forced Induction
- aunthetic ramair or fake?
- billet grill
- 2003 mustang cobra vs Ls1 camaro
- How much and what to get done on a tuneup?
- 200-230 Miles with 1/4 Tank Left?
- Newbie
- Best LS1 cam?
- Hurst Shifter
- Free mods?
- FlowTech of Eddlebrock TES Emissions Headers??
- Seeking tire suggestions...
- Does your LS1 ever bacfire?
- Camaro SS vs Supra with a T04
- Mufflex 4" vs. "True" Duals...
- What does an LS1 need to run mid 12's?? coming from a Supra guy ;)
- slave AND master cylinder?
- chirping noise from up front...
- LS1 problems/perks, Looking to buy one
- DriveTrain loss, is this true??
- Roller Rocker Problem on All LS1 Engines...
- True Duals?
- Exhaust maybe?
- Nu-Tek motors
- 98 up parking brake adjustment
- ? on AIR and EGR Blockoff's
- T-56 is the same tranny as....
- Torque Thrust Ii's??
- Piston Slap Questions
- buying a new z28
- Where to get mods done
- Next power mods? hotcam/heads?
- GRR Tire Rack Need Quick Sanity Check!
- Cheap octane booster???
- I figured out what gears I have in my car....now that they are broken!
- Runnin like crap...bad plugs???
- Hooker Long tube headers bad? good?
- Exhausts sounds.. My opinions...
- Which are the best headers for my 99 SS
- Which would look better?
- What to do with +-$1000?
- Airbox Help!!!
- For those who have kept track of MPG<--
- What Rear
- is anyone here using the slp mass air flow sensor?
- Grille Insert
- FTRA vs FT high flow air box
- Next mod??
- Breaking in a New Z28
- Which whisper lid is the best?
- Which wisper lid is the best?
- FINALLY got my car on the dyno!
- Ls1problems?
- Will an LS1 fit??
- What's the difference between Firebird/Camaro Monsoon systems?
- Cost 'O 427
- WHAT DID I JUST DO TO MY CLUTCH?!?!?!
- Intake restiction on '00 SS
- Vette rail cobers on 02' SS????
- SES Code meaning ? P1870
- Direct-Flo lid, mine doesn't fit!
- Anyone know how to reset gauges once you remove the needles?
- Hard question about O2 sensor simulators
- HELP!!! Trans trouble??
- Avg LS1 track times
- Oil in PCV
- thinkin about gettin a cutout...pros VS cons
- porting maf ends
- Pros & Cons of Suspension Lowering
- Underdrive pulleys and water pump
- Help me out with Brake Pads
- Please post all exhaust clips on LS1s.
- Is this an SLP lid, or what?
- Who will win?
- 99SS vs 02SS READ THIS!
- Cat-back vs. muffler
- Cam Question
- I have some ?s about this airbox setup...
- Leg pipes
- 2001 Z28 Traction Control
- will a WS6 airbox fit??
- wts is a lid?
- should I get WRX or Z28
- cheepest place to Buy LS1 EDIT ?
- Exhaust idea.
- Used Ls1 or supercharged Lt1
- Price for Factory Z28 Muffler
- QUESTION ABOUT LIFTTERS
- Who sells the cheapest electric cutout?
- Sound from new cats
- Slp center mount exhaust
- WOOHOO A CLUNK
- Common problems????
- Looking at getting a vette in the future, how much is my SS worth?
- Would I see gains on a Hooker catback over WS6 exhaust?
- Stock axle strength?
- Anyone put cruise control on a car?
- MAFT Tuning - need help/input
- read this......
- Worth Buying this Borla kit?
- SWEET NOS SYSTEM
- TR220 or TR224 on a 114 center
- Transmission question
- T-TOP FLEW OFF
- Rear diff fluid change
- SLP order
- Lid isnt sealing!
- Throttle Position?!
- LS1 Super sucker
- IS $20K A CHEAP PRICE FOR MY MODDED 02'?
- TQ Question!
- Help with coolant light......
- Intake Manifold question
- P.O.S. OEM battery ! Anybody ever replaced a positive battery cable ?
- New 02 SS Dyno #'s
- intake install question.. with pics
- Check out my dyno with FLP LT's, looking for opinions
- K&N Kit?
- Power steering fluid going...going...gone
- Optimum shift point?
- Camaro V6 Ls1 swap
- >>Anyone know where I can get a rearend for $2000???
- 383 Stroker...
- One step colder on spark plugs --- Pros? Cons?
- SS color choices
- anybody have any CARTEK packages on your car?
- WOT -- audible detonation above 4,500 RPM
- Subframe connectors - can someone tell me about these?
- Need help with clutch install.
- Hooker catback or SLP Loudmouth?
- Date of Production
- LS1 clutch line drill mod....work for LT1?
- Ever get tired of 6 spd?
- Subframe welding...
- Question about manual tranny shifters
- Looking for a welder in North Alabama
- Questions about buying a car...
- Pulley question
- How dumb would this look?
- 20hp mod for $20?
- Corsa Catback Exhaust
- Heater core Question... I can hear leaves in my air vents! How do I.....
- I have $2,200...help me spend it on mods
- 2002 air lid
- Tazzo Motorsports computer
- I am now muffler free!!!
- What kind of intake is this, and does it work well?
- Difference between 40 series flowmasters. Street or street and strip?!
- Suncoast creations SS Hood and Filter?
- lower temp thermo...worse KR?
- Want to hear a GMMG Camaro
- LS1 Computer
- LT1 to LS1 swap
- Advice on brake pads
- Need advice
- Shopping for a Z28
- Some advice......
- Whats the difference between 9 and a 11 compression ratio? I'm lost on this......
- Do LS1's have bleeder valves for cooling system?
- spark plug part # hell... wtf??
- Some engine noise like bad gasoline
- Where can I find good, cheap wires?
- Someone school me on Autotap. Why is it better then a HPP?
- Tubular exhaust manifolds?
- I think I just melted my clutch!
- NX or NOS
- Air intake question
- Magnaflow Cat-Back System?
- Newbie Exhuast Question
- help with new Z transmission problems
- Dyno Testing
- New LS1 Super Spydar Intake Manifold
- Fasttoys Z28 Exhaust tips
- New 02 SS Questions
- flowmasters or not???
- N2O Question
- Shorter drive belt mod????
- What is the true story behind the 160' thermo??
- what kind of oil is in our cars from the factory?
- WHERE TO BUY NX WET KIT FAST AND CHEAP?
- Can a Turbo 350/400 Tranny bolt up To LS1 ??
- SES Diagnosis - PLEASE HELP!
- You LS1 guys gotta check this out!, Prepare to drool.......
- gear swap question
- Best Replacment Shocks?
- '98 LS1, A4 with GU2 rearend(2.73). What series carrier is back there?
- SLP SS/WS6 Take-off exhaust
- can rock chips be fix from the windshield glass?
- Thinking about switching 2 a pony
- NOS system vs. Supercharger
- Here are finally some pictures of my car!!!
