PDA
View Full Version : LS1 Based Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
  1. PCV valve
  2. Cam or exhaust question???
  3. Need opinions on these tires
  4. Electrical Silliness
  5. E-Cutout ,True Duals or cat-back
  6. what should my friends LS1 run?
  7. Water pump & Alternator removal & install write up needed.
  8. Can I hose off my LS1 engine?
  9. New intake available for our cars (sheetmetal)
  10. just some info
  11. Bad gas mileage...
  12. torque management
  13. Need some opinions
  14. LS1/LS6 intake dyno #'s
  15. header install
  16. Cai or ssra?
  17. QTP dyno numbers
  18. Ultimate set up
  19. Would you buy this car?
  20. Need your help before taking my car in to the dealer
  21. Cam
  22. Tires
  23. changed plugs, again...
  24. carfax request please! thanks!
  25. HELP, Jet-Hot LT install underway
  26. Weight
  27. spring pressure
  28. 315 on 9" rim??
  29. Power steering & Water Pump leak screwed alternator?
  30. Calling out help from all the ls1 owners
  31. 2000 SS rated hp???
  32. price of used LS1
  33. Year of the LS-1
  34. Da Biggest Bull$hit Ever Heard!!!
  35. brake install guide?
  36. SES question-catalyst inefficiency
  37. the new mustang
  38. How difficult to install an intake?
  39. Dynoed Cam
  40. Pacesetter, Jet Hot, or Flowtech headers
  41. Gutting cats?
  42. SLP "flo-pack"
  43. Look at this deal on pacesetters....Unbeatable ....
  44. Idling Problems after mods...help please
  45. Dying fuel pump
  46. fixing to buy camaro ss with ls6?
  47. Help Me Please!
  48. Blowing Fuses, Electronic Guys In Here!
  49. header question
  50. Y-pipe/Programer Question
  51. HELP!! Car wont start!
  52. Does fuel filter type make a difference?
  53. Are these shift lights any good?
  54. most quiet 4" muffler
  55. maf
  56. 2001 SS -- perfect!
  57. which air filter do you use?
  58. SS suspension question??
  59. 98-02 Fbody GM Repair Manuals
  60. Pacesetter Y Pipe?
  61. Blue Springs max lift? please help
  62. The perfect Air Fuel Ratio
  63. How many of you have mixed fuel - I.E. run the cheapie stuff ?
  64. Man, do flowmasters suck...
  65. hooker catback, tsp rumbler or loudmouth with chambered muffler pros& cons
  66. what is gmmg website?
  67. Those Of You That Have LT's and Loudmouth
  68. mandrel bent true duals vs non mandrel bent is it a big difference?
  69. SuperMaxx header package
  70. Cam and emissions
  71. NITTANYMARINE: What shop in pa does true duals you were talking about? jersey, md??
  72. SLP loudmouth on highway, how loud?
  73. Any one have the ASA cam 232/232 .525/.525?
  74. anyone running a 228/228 .581/.581 114 LSA
  75. DRL lens question
  76. dyno run
  77. LS1 Prices??
  78. Traction Control question
  79. i pipe diameter?
  80. changing plugs
  81. Want/need a free owners manual?
  82. bc smoothies with 285 tires
  83. No Power Steering????
  84. is running rich a bad thing?
  85. A/C aircon ...q?
  86. Fan Switch Worth It?
  87. does anyone who has jethot longtubes an y pipe not have the y pipe hitting floor pan
  88. want true duals but am afraid its much louder than loudmouth opinons please.
  89. how man o2 sensors does 00 ta have?
  90. Fords DOHC 32 Valve vs. LS1
  91. can i use cats and or true duals with jet hot longtubes?
  92. Cam install... Any help?
  93. OK, I got the tools and the time, how do I fix my EGR Valve?
  94. Some questions about WS6 hood and intake system
  95. any reason to NOT reuse stock manifold bolts?
  96. slp 85mm
  97. My TSP Rumbler Video Clip
  98. Another "what's next" question...
  99. 3.73 and Loudmouth.
  100. bought my wife an LS1
  101. thoughts of JET HOT longtube intstall...
  102. What type of headlight bulb?
  103. What's up w/the LQ4's low RPM horsepower peak?
  104. If GM won't do it, someone else will. (Getting new engine)
  105. New set-up loading up at idle and low rpms
  106. paging nittanymarine
  107. so basically if i want longtubes with y pipe and cats im gonna pay 1000+ :(
  108. Dyno Results
  109. LS1 Upgrade
  110. NEW Under Axle Pics are Here!!
  111. Should I change my plugs and wires?
  112. Can a Cam-Only LS1 run 10's?
  113. Please Help (after Cam Dyno)
  114. EGR/AIR trouble codes...$$$!?
  115. peeps on ls1 are saying volant adds 7 more hp than lid
  116. whats your oil pressure?
  117. Curious about my car vs a 97 z.
  118. Help with cams
  119. 5.3 heads on my LS1?
  120. 2001 camaro wheel offsets
  121. REAR susp. bottoming out at slow speeds?
  122. Wheels for my ride
  123. How Much
  124. Need new engine
  125. easy one - exhaust manifold bolt size
  126. brake change
  127. Jet-Hot LT Install - K-Member Modification?
  128. which longtubes that are decently priced will let me runs cats?
  129. do you gain any hp or reduce any et when you remove the air and egr?
  130. will slp y pipe work with other longtubes besides slp?
  131. has anyone gone 12s or better with slp loudmouth n/a without aftermarket converter
  132. Seafoam
  133. People who have installed long tube headers inside please
  134. 2000 Camaro SS stock HP?
  135. Couple of fuel questions
  136. C4 Vette vs SS...middle console cushion...why not?
  137. R/T Y-Pipe/High Flow Cats
  138. Custom Ram Air Intake
  139. Help! Pacesetter or Flowtech Headers? Which one? Need to know soon!
  140. Awesome Dyno Day!
  141. Dyno #'s from today...
  142. QTEC Question
  143. Brake Problem!!!
  144. need help with rear main seal
  145. ssra or ftra?
  146. does the slp lid come with everything i need to install air tube?
  147. LS6-C5R motor?
  148. Oil pressure drop at high rpm?
  149. Best Exhaust setup under $400? Best Lid?
  150. ac delco pf58 or pf 59
  151. OBD2 Scanner for $189. Worth it?
  152. Straightpipes, or keep my Borla??? Please help!
  153. Requesting sound clip LS1 idle under engine
  154. who has more HP
  155. TSP Rumbler Sounds Clips?
  156. Dual cutouts vs single cutout.
  157. i think i dynoed kind of low
  158. LS1 throttle body = Ram Jet throttle body?
  159. Racing fuel
  160. Did fan switch mod, SES light came on, please help!
  161. when i put the brakes on and am about ready to come to a stop i hear a slight clickin
  162. What kind of oil and capacity...
  163. ??? for Jason D
  164. Getting The Z Tuned?
  165. Corsa Installed 1st Impressions!
  166. 02 Sensors
  167. Cam ?????????
  168. ‘00 z28 no ASR ?!!
  169. What to do Next...?
  170. ABS Brake Modulator
  171. Machine Shops
  172. do you keep your ls1 in 3rd gear or d
  173. dual cutouts on a bolt on car? gains worth while?
  174. raspy sound from flowmaster???
  175. Need help asap
  176. Long Tubes with 3.73's?
  177. Magnaflow catback install
  178. Need a y-pipe for the TA, who sells them?
  179. stock gears replaced at 22,500 miles
  180. should i be making more hp?
  181. LS1 ScanMaster GP is going to end soon!
  182. Dash question
  183. Fuel on E?
  184. need a good pad for drilled and slotted powerstop rotors
  185. Curious about suspension...
  186. Radiator messed up??
  187. does slp have more than 1 y pipe for their longtubes and loudmouth?
  188. when getting slp longtubes should i get the ones with or w/o air and egr fittings
  189. Baer Brake Packages
  190. do i need crankcase breather for lid for 00 ta?
  191. aftermarket maf or not?
  192. Questions ASP pulley
  193. when doing longtubes and exhaust what cats should i go with
  194. pros and cons about slp 160* thermostat
  195. Underdrive pulleys
  196. LS1 T56 conversion
  197. Lower Control arms coming lose again?
  198. Interesting bit of trivia regarding the battery tray.
  199. how do I....
  200. LS1 fuel consumption
  201. fuel pump
  202. what next after exhaust?
  203. cutout pointless on a magnaflow?
  204. Z almost stalls
  205. slp cai,lid and ram air hood or ram air hood and ram air box?
  206. Help with sfc's
  207. ls1 header install question
  208. Problem with my LT1 A4 to M6 LS1 swap
  209. SS option on a 2000 Camaro?
  210. My planned mods
  211. Exhaust for 2002 Z28
  212. slp lid and 2000 ss hood
  213. Installed my Flowmasters!
  214. Loud Mouth Knock Off??
  215. Ls1 Cam
  216. Removing cats?!?!
  217. Suspension Advice
  218. alternative to O2 sims?
  219. Climate Control Fan
  220. what is the HP rating for LS1???
  221. brake squeak... new pads?
  222. M.A.S.C Performance Nitrous Oxide special!
  223. MASC performance Heads and cam packages now available!!
  224. Low Dyno? LT's,ORY, Cam
  225. Rotors on ebay
  226. tire size
  227. do tey still use dexcool in 00 ls1?
  228. True Duals
  229. QTP Longtube Headers
  230. To port MAF or not?
  231. Hooker long tube & y-pipe HP loss
  232. E-Cutouts going bad?
  233. air pump removal
  234. h/c or sc
  235. Fuel level!!
  236. Difference between SSs from 99-02 ?
  237. Best Catback for pricewise? Sound? Performance? Overall?
  238. Where to find some chrome ZO6 wheels????
  239. ive seen some guys saying k&n filter robs hp on ls1 is this true?
  240. please help guys will i get more hp from lid, cai, bellows or ram air induction?
  241. Dynomax bullet
  242. how much ground clearance with lanes tru duals?
  243. going to check out a LS1 tomorrow ... good or bad car?
  244. whats next
  245. is slp loudmouth good exhaust and does it have good hp gains?
  246. do all 00 trans ams have aluminum ds?
  247. is gu5 3.23 gears or 3.42? why does my a4 ta have 3,23 gears
  248. what year ls6 intake works on a 00 ls1 and what cars have them
  249. Flowmaster american thunder 3" for 00 ls1, yes or no? need 300-400.00 catback
  250. what free mods are there for 00 ls1?
