PDA
View Full Version : LS1 Based Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
  1. AC Freon released, my fault now what
  2. engine backfire
  3. Driving with nails in my tires
  4. is Loudmouth TOO loud?
  5. ls1
  6. poll
  7. Brakes
  8. LS1 tranny question...
  9. Do the C5 rotors warp as bad as the Fbodies?
  10. aftermarket Y-pipe questions
  11. Trans Am foglights on Camaro
  12. Magna Flow catback installed
  13. What to look for when buying and 98+?
  14. CARFAX report
  15. Z28 Value
  16. prestone coolant
  17. A/F ratio with longtubes?
  18. fog lights?
  19. SES Light?
  20. Z28 HP vs SS HP
  21. What's it worth?
  22. whats the best dextron 3 transmisson fluid to use?
  23. Should I get a Predator or U/D pulley?
  24. Need help with theft lock.
  25. Whine on the PS pump.
  26. Who's Up For Some Name Brand Suggestions?
  27. Help on Cylinder 3 Miss
  28. Dyno #'s
  29. Please don't delete, an informative post a non-board sponsor
  30. Plugs/wires/cutout add ons =110mph?
  31. quick question about warped rotors.
  32. help?! (brakes)
  33. Last track day of the year, New Best!
  34. Difference between OEM Hurst & "normal" shifter?
  35. mods
  36. Whats a good price for a DiabloSport Predator Flash Tuner?
  37. Programmers
  38. Anything change in ls1's between 98-02
  39. LS1 -- LS6 (or is the mechanic blowing smoke)
  40. Replaced Alternator.... Still Squeals!!!
  41. Firebird part numbers Please help
  42. Purchasing an LS1, does this price seem right for the damage?
  43. The real deal on underrated LS1 hp numbers?
  44. License plate frame
  45. Just installed my GMMG exhaust!!!
  46. service engine soon
  47. Cam and Rev Limit.
  48. Question from over the pond about my Z28
  49. LS1 service
  50. Bosch platinum 4 plugs???
  51. cut out
  52. what size cut out
  53. How Do I...
  54. z06 cam
  55. Proud new LS1 OWNER!
  56. What goes into "gutting the cat"?
  57. Why do the Good Year GS-C's suck??
  58. LS6 parts
  59. fuel tank
  60. Car Faster In The Morning??
  61. Parts required for LS6 cam swap
  62. LS1 Tuning and PCM Repair/Socketing available
  63. 400rwhp
  64. Search Search Search
  65. 300,000 Mile LS1
  66. Hypertech question?
  67. does a ram air kit affect an SS?
  68. Power Steering Draining.
  69. Help w/ list of SS modifications
  70. Clunk under car....
  71. Exhaust help/opinions please......
  72. Thinking about winter tires
  73. M.a.f.
  74. I'm Sure You've Seen This Post a Million Times Before Already.
  75. 2 Questions/#8 plug change/inop cruise
  76. Bauer throttle bodies are awesome! Great gains!!!
  77. wheel leak
  78. difference in headers from 98/99 to 00-02?
  79. Engine Dyno Simulation Software
  80. Tire Q?
  81. Shifter part number
  82. Is a Z06 cam really worth it???
  83. most mods and still decent gas mileage
  84. Bad gas mileage...
  85. Should I change my sparkplug wires too?
  86. parts shoppers, i have a question.
  87. TSP lid
  88. Hi can i have some pics of your cars?
  89. Installed a cutout
  90. Steel brake lines...
  91. 18x9.5" y2k's rubbing on inner fender wheel
  92. Stand by... The Black SS of Death is coming...
  93. Alignment
  94. brakes
  95. questions on slp package from factory?
  96. 160 thermo b4 fan mod?
  97. carfax report
  98. Slp fan switch alternative. Does one exist?
  99. tires poll
  100. The hump
  101. ac problem
  102. seat belt help
  103. True duals & Lowered cars. Do they exist?
  104. bent/broken push rods
  105. Ash Tray Light
  106. Duel Exhaust on an F-Body?
  107. rear hatch stuts
  108. Line Lock?
  109. teflon tape on knock sensor/stop KR
  110. power rack pinion
  111. Info on 01-02 Ls1 cam
  112. LS1 camaro vs vette tranys?
  113. Belt Squekin
  114. lS1 QUESTION
  115. Stroke out my LS1? Where, How much?
  116. ANy recommendations on CAGS bypass?
  117. what to do next????
  118. EGR Removal
  119. whistle noise when turn left
  120. Anybody have any ideas????
  121. TEA heads?
  122. stat install?
  123. arrrghh!! cant stop the squeak!
  124. mr gasket exhaust cutout how much to install
  125. GMMG and CORSA
  126. center mount exhaust question
  127. My New 2000 Z28!!!!!!!!!!!
  128. Front alignment
  129. rpo options
  130. 1le
  131. What you think of this custom exhaust?
  132. Corsa exhaust pics
  133. engine temp question
  134. 2002 SS - I need 380hp.
  135. Engine miss
  136. Which size QTP cutout should i get??
  137. Need a set of sharp looking fuel rails...
  138. B&m Or Trans-go??
  139. Cheapest place to buy an alternator?
  140. New 2002 SS owner here, need some advise please.
  141. 160* stat
  142. what conditions makes the ECM check the rear o2 sensors?
  143. Fuel Rail covers
  144. Installing Corvette Fuel Rail Covers
  145. routing for E-cutout wiring?
  146. Air lid
  147. cheapest online place to buy magnaflow
  148. Hi, new and have a question
  149. 00 SS
  150. Exhaust question? (opinions wanted)
  151. Best cam?
  152. cutout placement question
  153. C5 calipers on a 2000 SS?
  154. Heads/Cam advice??
  155. Dumb question. 9005 or 9006 4/lowbeam?
  156. one on the left?
  157. Slp's Lids...
  158. Who has done this mod?
  159. Clutch problem..Help!
  160. Slp's Phone Number
  161. 98 z28 price range
  162. How often do u change springs....
  163. New to Board
  164. Ready to mod
  165. true duals vs y-pipe and slp loudmouth?
  166. Cut out Q's
  167. How fast are Z28s?
  168. What Size Inlet/Outlet Pipes?
  169. How to take calipers off?
  170. LS1 Motor Mount Installation
  171. valvetrain knock
  172. Is this bad?
  173. Alternator swap out..why
  174. Skip shift is ***
  175. I need help
  176. Best SFC's, what do you think?
  177. Are aftermarket LS1 and LT1 catbacks compatible?
  178. Need help installing LCAs (Metco)
  179. Cold Air Induction
  180. PS pressure hose. How do you take off the reservoir?
  181. L/T's - Mac, Pacesetter, Hooker, etc. ???
  182. Are the gears and carrier compatible between 3rd and 4th gens?
  183. Speed Specialty: new sponsor for Super Sucker scoop for FTRA and SLP
  184. SLP underdrive pulley
  185. I feel dumb for asking this
  186. Weird measurement that I need
  187. Squeaking noise....
  188. SLP Dyno and tuning questions...
  189. What to do?
  190. Factory Alarm?
  191. great?!
  192. Programmer for a 98?
  193. Newbie LS1 questions
  194. cutouts
  195. should be in 12's
  196. LS1 Motor Mounts
  197. Look at this Price Difference!
  198. good price for seats???
  199. Which Shifter?
  200. Any good sealer for Power Steering?
  201. loudmouth in place of flowmaster
  202. sleeper.....
  203. Looking for a supercharger? Vortech and ATI info within
  204. Best bolt ons?
  205. How do I remove...
  206. Where to get dash Plaque
  207. question about loudmouth...
  208. Headers
  209. Got a weird question for you all
  210. Do all SS's have T-Tops?
  211. What is a lid?
  212. Anybody know what it costs to replace 30th anniversary WS6 wheel?
  213. install power window motor
  214. Anyone forsee any problems with a total AutoMeter gauge setup?
  215. Change GEAR BOX???
  216. oil
  217. Side View mirror
  218. People with B&M.......
  219. Had car dynoed
  220. Looking for a Muscle car need help....
  221. Help with part #'s
  222. MAF & SES, my arch enemies
  223. Need a new fuel pump....
  224. Are LS1 and 93-95 cat backs the same?
  225. Castrol Syntec
  226. predator tires
  227. SES light codes HELP
  228. Any problems with SLP Underdrive Pulley?
  229. Replacing fuel pump......
  230. M6 shifting guidlines
  231. how hard is taking out the AC?
  232. anybody have this problem
  233. Annoying rattle in my dash, ideas?
  234. Passkey Problem??
  235. Buy Pacesetter or QTP headers?
  236. Slipping clutch and ASR
  237. A4 or M6
  238. looking for tires
  239. how much should they be gapped?
  240. Traction Control
  241. Lighter Flywheel??
  242. Help on bleeding brakes!!
  243. Holy Oil change intervals, Batman ! (Synthetic Oil)
  244. Oil Change Light
  245. new ls6 valve springs
  246. Tires cracking...winter storage???
  247. Hood
  248. Tires and Rims 18/17
  249. TA cover
  250. New WS6 redlining?mods?
