PDA
View Full Version : LS1 Based Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
  1. Real Gains with Predator
  2. anyone ever heard of "diablo" programmer?
  3. cam selection
  4. C6 427 Engine in a 98 Firebird
  5. T-stat question
  6. Nitro,Supercharger,Turbo
  7. Please help a Z28 owner in the UK
  8. Help! Car won't start
  9. Aluminum driveshaft in stock '98 LS1?
  10. Weird one... oil leak... but not what you think
  11. Headers for my 02 SS
  12. Hpp Iii
  13. Will the FIPK work with aftermarket MAF?
  14. MAF questions???
  15. Speedo Recalibration with Hypertech after LS1 Edit?
  16. Sparkplug questions?
  17. Is $4000.00 a good price?
  18. part number of LS1 and LS6 intakes...
  19. who has the best price for the TCI torque converter for the LS1?
  20. Re-Useable Filter vs Paper Filter
  21. 1.85 roller rockers and a supercharger?
  22. z06 MAf in LS1
  23. whats to gain from a hypertech programmer
  24. Damn they were tight
  25. CAGS vs Me
  26. oil pump gets starved during super hard braking procedures
  27. Problem with stock air filter and SLP lid
  28. 6.0L LS1 in Escalade
  29. Curious LT1 owner: how hard to make LS1 500 rwhp NA?
  30. Putting $2000 into car let me know if this setup looks good
  31. newbie LS1 question
  32. Anyone have the powerflo exhaust from SLP?
  33. whoops! broke a wire....
  34. 98-02 K&N FIPK
  35. Electric radiator fans
  36. Factory Exhaust? Skip Shift?
  37. good headers and y-pipe?
  38. Whisper Motorsports cold air system
  39. few easy specs q's need answer fairly quick if you please
  40. My Tires Rub
  41. intake manifolds?
  42. Talkin Aftermarket Suspension...
  43. Random Multiple Cylinder Missfire
  44. Emissions + These mods = pass? and power?
  45. Has my LT1 gotten the better of me?
  46. LS1 and th400
  47. What to do after header install?
  48. can someone help with this TB question
  49. How many miles should I get on a full tank?
  50. Please Help, Wont Go Into PE Mode (Detailed)
  51. fuel pump won't work... i'm about to give up
  52. Please help, where is a good place to buy headers cheap?
  53. stock or not?
  54. 1st Mod
  55. magnaflow exhaust
  56. ls1 intake from corvette that doesn't have EGR..
  57. Do Jet Hot Headers need wielding.
  58. Smoking exhaust - oil too thin?
  59. compression test.....
  60. at how many miles should an o2 sensor be changed
  61. Front driver side o2 sensor...help!
  62. 98 Ss Just Starting To Mod Any Suggestions?
  63. MSD coils...
  64. RPM limiter
  65. spark plug swap
  66. What size socket?????
  67. Pacesetter LT's Pic's
  68. switching LS-1 to carb?
  69. programmers?
  70. ASR light
  71. 510hp LS1?
  72. Is this Torque Management?
  73. What Camaro?
  74. is removing the torque management a good thing to do?
  75. Opinons?
  76. New website
  77. one cylinder missing...update on old problem
  78. code p1416....getting mixed info
  79. Best Gauges for N/A Car
  80. Dynatech Header System
  81. 1.7 Roller Rockers
  82. horsepower tv: LS-gun...... lol
  83. Gettin a cam.....what else do i need?
  84. Cost of new header gaskets installed
  85. whats the best quiet performance torque arm for the LS1 f bodies?
  86. Ok... i know EVERYONE person here will call this BS... but....
  87. c5 Vette HUD
  88. c5 Vette hp= to z06?
  89. Power Steering Pump
  90. wet tires give bad dyno reads?
  91. Which year is the best for an LS1
  92. What Should This T/A Run?
  93. tell me what to buy first for 99 z28
  94. 1.6 rocker arm question
  95. what kind of gas milleage?????
  96. LS1 Valve Timing Needed
  97. Security system diagram
  98. difference between zo6 and fbody slave?
  99. ws6 air box vs stock air box
  100. Damaged Jet Hot Headers?
  101. Possible Fuel Gauge Problem
  102. Sound clip of my duals
  103. LS7 Head Flow Data
  104. Location of PCV valve on 98 T/A??
  105. SLP Loud Mouth 2
  106. o2 simms install help
  107. FM14 Cam Results. True Cam Only.
  108. ticking sound when shift out of park to D
  109. Replace Belt Tensioner / water entering scoop?
  110. which Headers?
  111. catback exhaust
  112. Gasket??
  113. cam question
  114. air lid VS K+N FIPK
  115. Just bought SLP Loudmouth exhaust have question
  116. Other Mods?
  117. Edelbrock exhaust vs Flowmaster
  118. Any interior resonance/drone with Rumbler catback?
  119. Computer Programmer
  120. Question on SLP Loudmouth exhaust
  121. Can i see some pics of a FIPKII ?
  122. Charging problems
  123. free mods?
  124. 3.73 or 4.10s??
  125. check engine light
  126. How difficult is it to swap heads ?
  127. Any tips for changing spark plugs?
  128. Car has 65K miles on, what should I replace?
  129. NEW 38 lb/hr injector sale
  130. New Cam..Does this Sound Right?
  131. Series I Dominator cam
  132. FIPK vs Volant vs Lid + CAI
  133. Spohn Solid Engine Mounts !!!
  134. V6 Supercharge or V8 Engine Swap?
  135. Cam: what do yall think of this one??
  136. What gears do i have??
  137. will a borla exhaust off a 95 lt1 fit my 02 ls1 trans am? please help
  138. Best 1/4 Wheels/Tires
  139. Catback??
  140. TSP Rumbler Help! please..
  141. Starting to Mod for the Spring
  142. Injectors Clean?
  143. heads & cam
  144. How hard would this true dual system be to fix? (pics)
  145. track numberd on stock SS
  146. LS6 Really 405hp? Or over rated?
  147. Don't waste your money with bbk
  148. Y- Pipe removal= HP????
  149. Exhaust ???
  150. Check Engine Light?
  151. Want to buy AC Delco rapidfires have a question
  152. headers??
  153. EEC # for 2001 SS?????????
  154. what to do next?
  155. piston slap ?
  156. ASP Underdrive Pulley??
  157. 408 Short Block Buildup (I need Suggestions)
  158. converter or exhaust
  159. Engine belt Q
  160. Patriot 226/226 585/585 112 Cam? $279?
  161. ls1 borla on lt1
  162. Dumb question about thermostats
  163. Installing Flowmaster muffler...
  164. 1LE VIN check...
  165. 2001 z28 egr system
  166. Am I missing anything?
  167. Intake Manifold
  168. 02 OEM flywheel question
  169. what are the suspension differences from regular trans ams and ws6 trans ams?
  170. Horsepower
  171. skip shift light comming on...
  172. Help Identify an LS-1
  173. What gears do i have??
  174. Afr 205 Vs. Stage 2 Ls1
  175. pro 5.0 shifter too tall....
  176. What next?
  177. This dont sound right.....
  178. How high can stock LS1's rev to?
  179. Intake hose?
  180. Anyone have the new SLP Loudmouth II muffler
  181. QTP help???
  182. *WARNING* Cat-back melting the gas tank...Found when putting on the true duals.
  183. internal engine cleanser?
  184. How long for pacesetters install?
  185. What you guys think??
  186. Charging system ?...
  187. Finding the Perfect Cam and Headers
  188. Magnaflow opinions??
  189. RWHP Gain fro a Cat-Back
  190. Jerking at low Rpms
  191. First Mods but now I have stalling??!!
  192. Race Gas worth it?
  193. Need some quick info on a few parts.
  194. Rod Length Question
  195. Pacesetter ORY fit LM Intermediate?
  196. 8.1L in an F-Body
  197. What first Nitto's or bolt on's?
  198. Borla XR-1
  199. building up a stock 01 SS
  200. Wrong slp lid
  201. right direction?
  202. Car cover quiestion
  203. LS6 intake
  204. Whats next?
  205. engine ping and SES light
  206. cam question
  207. 9.6 sec stock engine ?
  208. help need stroker engine
  209. EGR removal
  210. Help....what cam to use....
  211. ?? for those with 5.3 heads on their LS1..
  212. ( Pocket PC ) OBDII Scanners / Data Loggers requested – recommendations?
  213. What to do with $2500?
  214. How loud & smelly are cat-less long tubes?
  215. Headers....
  216. Automatic Headlights....again
  217. Is the bellow going to the TB really that restrictive?
  218. Induction Upgrades
  219. Switch oil grades 5W30 to 10W30 after 90k?
  220. WS6 Stock Air Box Lid
  221. SLP Loudmouth vs SLP Loudmouth II
  222. Whats the price range?
  223. cause of noisy engine
  224. Who is running Flo-Pro twisters
  225. Metal buzzing sound under the car, 2000 trans am
  226. Just put my SLP lid on had a question
  227. Amsoil? anyone used it
  228. internal difference 98-02
  229. Have you enjoyed your pacesetters?
  230. torque-eee cam help
  231. SLP Blocks
  232. What numbers do a 6.0L LS1 Iron Block Engine Make?
  233. Misfire help!
  234. over the axle heat shield for exhaust.
  235. what is the diff between an LS1 and LT1
  236. i just changed from synthetic oil to regular..
  237. Good Transmission shops in NNJ
  238. Y-pipe hits bottom of car...
  239. Will O2 simulators fix Check Engine light???
  240. SLP Headers but which ones?
  241. ecm year question
  242. 93 lt1 fbody hypertech thermomaster chips for sale
  243. SES light with Long headers
  244. New SLP Throttle Body
  245. Is there just one belt on our LS1s or is there 2?
  246. Cut-out and O2 sensor location
  247. How many quarts of differntial fluid will i need?
  248. Should i change my belt?
  249. Jet Hot's or Not?
  250. cam help
