Oil change light on during recent freeze
Old Jan 25, 2005 | 08:05 PM
z28_onyx's Avatar
Hi everyone,
I had recently serviced my 2002 Z28 (stock). I change the oil every 3000 miles.(always synthetic) This happened in early December. Haven't put more than 500 miles since then. The oil I used was Mobil synth. The folks who changed the oil pressed the oil reset button because i noticed that the trip was back to 0.00.
The past couple of days it's been freezing out here in CT. Temperatures stayed in the range of 8-15 F. When I start up the car now...the oil change light comes on.
Just wanted to ask you folks if anyone has experienced such a condition. Would this go away when the weather is warmer. I have a feeling that the system finds the oil to be thicker in winter and "reads" it as dirty oil.
As always thanks for the help.
Kind Regards
Aby
Old Jan 25, 2005 | 08:24 PM
shouldaboughtthez's Avatar
Re: Oil change light on during recent freeze
did they reset the light correctly?
cycle the key from the "ON" position (not start), back to the accessory. Do this 3 times then push and hold the trip reset button till the oil change light flashes.
Old Jan 25, 2005 | 09:38 PM
jm8881's Avatar
I always just turn the ignition to on, and then hold the trip button for about 10 secs and then the oil change light flashes and then everything is good.
Old Jan 25, 2005 | 10:02 PM
Plague's Avatar
They may not have dont it correctly when they reset it. I would reset it myself to make sure it was done correctly. Also, you should have problems using 10w30 in the winter. The engine will take either.
Old Jan 26, 2005 | 10:00 PM
z28_onyx's Avatar
Hi everyone,
Thanks so much for the replies. Well I'll just reset it myself and see how it goes. Can't believe that the oil change guys at a GM workshop wouldn't know how to reset it. Or maybe they just happened to miss it because that day they were quite busy.
I always used synthetic but i wasn't sure if they put in 10W30 or 5W30. I hope the 10W30 wouldn't hurt the engine in the winter.
Thanks again.
Kind Regards
Aby Philip
Old Jan 28, 2005 | 04:59 PM
It shouldn't. But then again you do live in a very cold climate.
PCLZ28
Dec 24, 2015 05:19 PM
jj71787
Jan 31, 2015 10:20 PM
Sandersen511
Jan 13, 2015 03:49 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Z28STYLE23
Aug 17, 2002 07:40 PM
