After head swap, oil pressure gauge shows ZERO HELP
Old Jan 10, 2005 | 02:48 PM
pbjones81's Avatar
this was a head only swap, I did not swap the cam. Anyway, I followed the instructions word for word in the instructions on LS1howto.com What could cause this? Im not familiar with where the oil pressure sensor is or how it gets the signal to the instrument cluster, is it in the block or what? Is there a wiring harness behind the engine that I could have forgotten to hook back up? To remove any doubt, yes there is oil in the car. where do I start?
Old Jan 10, 2005 | 07:41 PM
AL SS590 M6's Avatar
Moderator
Re: After head swap, oil pressure gauge shows ZERO HELP
Originally Posted by robvas
You probably broke the sender. There's an orange cylinder that stands up in the back of the behind the intake manifold. It's plastic and very easy to break. You'll need an oil pressure sending unit socket to remove it.
Or you forgot to hook it up. It's pretty easy to forget it because of the tight location behind the intake and in the loop of the brake vacuum hose.
HectorM52
Jul 30, 2017 11:46 AM
97z28k&N
Jan 9, 2015 04:58 AM
Jessie4tin
Jan 7, 2015 08:53 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
