View Full Version : LS1 Based Engine Tech
- is the slp lid worth it?
- Service Engine Soon Light On ???"s
- My new 01 WS6 - First oil change
- New spark plugs
- Oil pan gasket leak 2002 Z28
- LS6 heads and cam on LS1, worth it?
- p0410 secondary air injection system
- Spark plugs
- Fuel pump cuts out even after replacement
- Bolt-on help
- Mods Advice, HELP!
- Tune up questions and Gears
- Turbo?
- Alternator Help Interchangable
- Torque Converter size - and Part Number?
- Need some help troubleshooting charging alt system
- 500 rwhp for $4000
- 1998 Camaro, Engine Build Up
- v6 to v8 swap
- Tune up Price Opinion
- 2000 Z-28 codes
- 1998 Camaro Z28 Engine Swap
- Need the sputtering to stop! please HELP
- 2000 Z-28 check engine light on
- Where can I find the specs for the 2012 Grand Sport motor?
- Just bought 99 Z28... Need help
- Rear Axle Shaft Ideas
- Front end noises, Very bad
- 600+ HP Rebuild
- LQ4 swap in. Any tips from previous users?
- LS1 head question
- Buying 98 Z28 Auto. What is required to convert to 6spd?
- intake
- Shift pressure
- Lid & Free Ram Mod
- Double win!
- What parts of my modded LS1 will Transfer to an LQ9?
- Need some input
- Bouncing oil pressure gauge at Idle when warm!
- Oil Pressure Rise
- can't find a good answer...
- bent pushrod on #4 cyl
- z28 Engine Blew, In desperate need of help
- 94 Camaro z28 Third Brake Light Wont Shut Off
- slight shaking at idle
- 241 head question
- Ls series motors
- Cam swap parts/ cost
- LS1 camshaft help
- y-pipe
- Stock injectors with cam?
- Performance chip
- ls6 heads
- Starting Problems
- What type of oil to use
- ls6 intake ???
- low oil light
- Ls1 coolent water coming out please help
- what tranny for lq9
- Anyone in the DFW area build transmissions?
- SEAFOAM How-to on an LS1
- Mail Order Tune
- Idle surging issue
- Ignition key gets "stuck"...
- SLP Cold Air Intake
- bent flexplate? need help
- Rattle coming from the front 01 z28
- purchasing 02 ss slp???
- 2002 camaro ls1 sputtering??????
- Getting ready for a cam swap
- Tapping noise AFTER the air pump shuts off.
- Anyone here ever swap an LS1 5.7 for a Truck 5.3L?
- SLP rocker arm's
- Low oil pressure and slight overheating
- 98 vs 99 LS1's
- Will an LT1 T56 work with an LS1?
- need ideas
- help is needed please!
- Problem Installing Prothane Poly Mounts on 2000/A4
- Rattle in rear of 2002 Z28
- new pulley options
- Wanting new exhaust...
- Polluter cam?
- turbocharging my 99 z28
- How to: hook up Deltran Battery Tender Plus to '98 to '02 f-body
- another "i want this much hp" thread...
- Diable sport progaam
- 1999 z 28 convertible
- Kooks header install problems.
- Fog Lights
- Please help me figure out my asr/abs problem
- Make me a believer
- Header burnt thru this wire, can you identify it? May be cause of ruff idle..
- Future LS for my IROC-Z28; 2012- Early 2013.
- Head swap, is this worth it?
- Adding cruise to non cruise car HALP!
- Good Stall? and other things.
- Rocker Arms to replace YT Ultra Lites, what do you recommend?
- engine seems to be flooding when i stomp on the gas.
- Clueless about codes 304 & 300
- Block protrusion question - picture attached
- starting a LS1 Trans am.... hasn't been started in 5 years! please help
- Help with Clutch Replacement
- '98 camaro 6spd I can't shift for crap!
- shift knob lowering
- Rebuilding LS1 Advise
- all most beat by a truck
- Squeaking noise after spec stage 3 install
- heads
- Buying car w/ 517hp LS2/L92 :D
- Guide to Replacing the Oil Pan Gasket on a LS1
- What header bolts to use?
- Stock air lid dimensions please help?
- Update on the ticking lifter/Rod knock
- Silver overlay put on
- Just Bought 98 z28 what should i do?
- 2001 SS Jerking/Hitching while cruising
- 98 Z28 Electrical Problem?
- 1999 trans am trans
- DTC P1416 - I think my AIR pipe might be bent. Show me yours!
- LS1 swap
- Holley LS Fest II - September 9, 10, 11, 2011!!
- Exhaust help..good suggestions?
- Head Bolt Options?
- 02 transmission help
- cold air intake advice
- Higher than usual idle? And maintenance...
- interminten stall
- Hard Knock under my center console ????
- LS1 mild fi build
- Car shuts off while driving, A/C quit working?
- Need some help with my 2000 Z28 running bad.
- Which longtubes?
- 2002 Z28 Rod knock? Lifters? See video below any info would help!
- Troublshooting a Pre-Ignition Detonation Problem (Engine Ping)
- Help with build, 02 ws6 $2000 to start
- LS3 heads Will they work
- Hard to start
- 1994 3.4 to 5.3 swap
- AC Condenser Dimensions
- Oil pump question
- 1998 Camaro Z28 with Oil Pressure Issues?
- 1998
- wires to close to headers
- I've Bypassed VATS, Replaced the Starter and Battery....Still has Starting Problems.
- 01' SS M6 electrical issues
- Amp swing
- Future purchase of cam/heads etc question...
- Catalytic Converter
- What do these connect to?
- O2 sensors ???'s
- 1998 Camaro Z28 slow coolant leak
- Advice/Opinions on Parts please
- Ls1 running a little hot...
- LS6 crankshaft oil gallery plug part number/size?
- Free Mods
- Car is stressing me out...
- Touble shooting help
- flat spot.....bog....need some help
- oil pressure?
- Ready For some POWER
- Whats the lowest an LS1 has dynoed?
- Hypertech Power ProgrammerIII & and BBk headers advice
- coolant cross over pipe
- 2002 camaro ss-rear-end slip/rub
- 2002 35th SS
- Rebuild question
- Which throttle bodie
- What will this run? RWHP?
- Rear oil pan bolt snapped
- Seaform Treatment Good or Bad? e3 plugs?
- So what do you guys think?
- oil pressure gauge tubing
- Oil Pressure problems, I got the solution
- high oil pressure?
- to be, or not to be?
- Transmission replacement help needed
- AC Compressor replacement
- Valve clatter??
- How to tell what kind of motor?
- L92 with f.a.s.t system need some help! Or some direction!! Thanks!
- Best TB for Quality and Reliability ?
- 2001 LS-1 z28 hardtop 6 speed 74,551
- Camaro will be down for a few days. Any ideas?
- l92 help
- Zero compression on #1 Cyl - 99 Z-28 - With lifter tapping
- spark plug help
- 2002 Z28 exhaust
- Will a intake Lid fit with a SS Hood?
- wanting to add hp.
- whistling noise from engine
- What this noise be?
- Oil light
- Why would my ASR turn off?
- Rainy weather causing a misfire?
- warped airbox lid seal
- I have 3 codes P0141, P0161, and P1416
- Clunking noise from rear end.
- 98-99 cam in 02
- 2002 z28 EGR?
- Question about powerband and redline on stock 01-02 LS1 cars
- Upgrade opinions and technical doohickies
- proform PRO-67605 valve spring tool
- 2002 shifter shaking
- ls1 in a lt1 body?
- 1998 ls1 152,xxx miles?
- mysterious noises. need some advice
- Clutch or Transmission
- Is this just a coolant leak, or should I be worried?
- Oil Pressure
- 1.85 Rockers, LS6 springs,and hardened push-rods
- rod bolts question
- ls1 into a 95 z28
- help please
- How long are LS1's known to last?
- TPIS 90mm lS6 intake is it still worth it?
- Octane
- heads for cam
- LS1 vs LT1
- I got codes...
- Ls motor into a 95 camaro
- Flashing check engine light/no codes set
- ASR/TCS question
- Air Intake
- help
- Cut out
- gear change + exhaust setup
- Optimum pre-load for LS7 lifters ?
- ls2 knock sens on ls6
- 1999 vs 2000 exhaust
- Service Engine Soon light is on
- P0410 - worth replacing the checks ?
- trouble starting: clicking & dry "grinding" noise...
- SeaFoam? your take?
- new alternator and now its squealing / squeaking like pigs
- Battery / alternator /starter issue? Check Gauges light is on too!
- need a programmer for my 98 camaro z28
- were is the remote start fuse or wire at on my camaro
- Possible water in oil??
- camaro LS1 stock fuel pressure ??
- Doing headers, Which o2 sensors and which plugs
- H/C to a Supercharger setup?
- LS3 cam in LS1
- so i bought a 2000 camaro z28 w/137k mi, first steps?
- TSP magic stick 3?
- oil under manifold
- exhaust questions for 01 SS
- y-pipe for my 98 z28?
- 4.125 bore questions
- Throttle body?
