View Full Version : LS1 Based Engine Tech
- Need To Know Now 98Z28Camaro Rearend Specs
- Z28 cold weather mystery
- First project - almost done!
- heater hoses
- Ses
- Running too cold?
- Iron 408 in K20
- 2000 z28
- best cam and rocker arms?
- headers?
- z28 to ss
- Do I need to flycut my pistons
- I want to know if I have this straight
- LS1 Camaro/Firebird & Corvette dyno YouTube comp?
- Catback HP gain
- New uncomforting sound
- good for the Trans?
- Porting ls6 intake and tb
- Need Guidance
- Is there a lot of value in porting LS3/L92 heads??
- clutch swap problem
- LS6 intake swap
- thermostat bad/missing?
- thermostat
- New engine, lots of pics.
- which chip?
- engine swap!
- just picked up my new 02 Z need some advice
- Bogging out around 2500...
- throttle body 80 or 85?
- What Coolant to use
- TB size
- Car idling horribly and dies when revved.
- LS seies engine/tranny source
- What are the HP/TQ limits of a Gen 4 stock internals?
- Oil leak
- CCE or other Chambered Exhaust
- Squeaking after h/c/i
- dyno and tunning ? is it worth it? NJ
- Head stud goes into block too far.
- Need electrical HELP!
- SLP air Lid?
- Cant figure out this coolant leak
- F14 cam and Dart 225 Heads question
- LS1 basic mods
- po133,po153,po,704,p1134,p1154 codes need help
- ORY? Knocks sounds from a stop under the car HELP
- MS4 Cam
- off road y pipe NO CATS?
- Attention LS1 owners..... need a bit of feedback.
- Loud Mouth 1 or 2?
- Sand in radiator
- smooth bellow
- MAP sensor troubles
- Ebay Longtubes?
- American Racing Headers
- When to upgrade your fuel rail?
- dyno-1/4mile
- LS1 air box VS V6 BOX
- best time to go to the track
- Need Transmission bellhousing
- tach problem
- do i need to rebuild my motor
- Lid CAI or FIPK
- Do our Cars have trans coolers?
- Bad oil pressure reading.....
- Finally got a 4th gen
- What to do with my LS1 (HELP)
- I am looking for some help/directions/recommendations
- Short trips and battery drain....
- 400 HP on 87 Octane... 383 Stroker, is it worth it?
- Used LS6 engines?
- Whats everyone's opinion on higher mileage LS1's?
- 2002 Z28 Tachometer died
- pistons?
- ms4
- Is this to much?
- Injectors
- 6.0 build
- Couple codes...where to start
- LS1 Not starting.. Need help!!!
- What kind of Additives and Treatments do you Use?
- I am looking for the best setup for what i got
- Ms4 cam miss
- wanting to buy a 2002 Z, anthing to look for when inspecting it?
- Whats the best cam
- Is a 04 Corvette Convertible supposed to hestitate while idling?
- Please help i need a set up
- 2000 Camaro - LS1 and Blue Smoke
- Smoking black, up and down idle
- Fan Control and 160* Stat
- Quick Q about LS6 exhaust ports
- True Duals - A4 PT4000
- K&N Airfilter Question
- 98 z28 suddenly does not start, but cranks
- Coil Pack Harness Connector
- hey wat cam could fit my 98 camaro z28
- Ls1 overheating... Help
- Looking at a 98 Z28
- That's a truck?
- Engine whine after warm
- What transmissions will fit???'s
- Help! Keeps throwing P0327 code...driving me nuts
- Best Sounding Exhaust?? for a Ls1 Z
- What to upgrade with?
- Suggestions on TSP RUMBLER X WITH LTS
- Late build 2002 LS1 Z-28
- help with 98 camaro starting issues
- Putting a 6.0 truck motor in a 97 ta
- '99 Z28 having issues, Please help!!
- Desperately need info on the LS1...
- overheating problems!!!??!!?!?!?!
- flushing radiator?
- Fast intake
- difficultly/length of time manifold gasket
- Who ports ls1 heads (Correctly)
- LS1 (and LS6) diagnostic procedures
- Which injectors are right for me ?
- Specs to rebuild a 5.3...
- Same problem different day !
- What could be going wrong?
- I have coolant in my air intake and throttle body
- crank position sensor broke off
- FAST throttle body leak issue
- No start, replaced relay, starter is good, what next ??
- Rocker bolts, or studs?
- 91 camaro ls1 swap trans question
- cam ?
- Need to rebuild my engine
- Stepping Up, Suggestions?
- Best Tips & Tricks for factory LS1 Head gaskets removal ?
- O2s
- Egr?
- Turbo install serpentine belt ?
- reving normal or not
- Concern with "mystery" plug behind pilot bearing not sure what it is...pics inside
- time trial 2000 camaro ss with full slp package
- Bad Idler Pulley?
- What kind of cam do you have in your LS1?
- 1998 camaro performance axle?
- What is this ticking/tapping noise?
- 1999 Z28 Camaro solenoids.
- governor pressure sensor
- Seafoamed, now the car bogs a little
- engine removal
- 1998 Z28 with High idle
- What MAF am I?
- Patrick G Cams
- why would it be doing this????
- Oil on plug #3, hesitation, codes, and rough warm start....any ideas?
- water pump hose leaking
- injectors
- Why can L76 engines run 87 Octane yet LQ9's need 91 + make less power?
- next upgrade
- What is this part? Some kind of alternator bracket or what?
- switching exhuast
- looking for some easy mods
- Tb ?
- suped up camaro vs stock
- I broke it... what IS it?! Help!
- Need a shove in the right direction.
- Turbo 3.8 vs LSX / LQX swap.
- Engine Gasket?
- best modification gains
- horsepower??
- LS 1 7/8 primary header gaskets...what is best.
- any quiet 2 mufflers that fit right behind the headers?
- SeS light is on again
- camshaft input
- radiator light
- missing
- High flow waterpumps
- LS6 knock sensor replacement...
- worth the effort?
- No signal from Camshaft Position Sensor.
- low oil light, not low on oil?
- Shaky Oil Pressure Gauge??
- LS7 Intake-Will it fit on LS1
- OHHH Kraest
- Easy upgrades
- Working on LS1 vs LT1
- ls1 swap
- MS3 /TEA 5.3l Stage-2.5
- 5.3 swap q's
- Could i buy a 1998-2002 camaro z28 with 50,000 or less miles 6spd for $10,000 or less
- spudders under load
- help.
- heads cam 330 hp
- want to change my transmission from auto to a 6 speed
- Bell housing bolts and trans pump ?
- Trickflow cam
- Custom aluminum fabrication
- Low voltage when accesories on
- 408 & boost
- annoying problem
- Compare KOOKS 1 3/4" to TSP 1 7/8 Headers For Me
- Header Bolts
- 2009 Engine Masters' Competition
- LS Hotcam Base Circle diameter???
- cold morning strange noise
- Ls1 tap
- Need some advice !
- gas smell when idling
- '04 GTO heads?
- Need help with ticking problem
- Alternator?
- Spark plug wires problem
- Starting ???'s
- Norwalk, Ohio - Pinks All Out
- SS exhaust? Single in/Dual out?
- LS1 Block and Heads
- egr delete kit
- heddman!!
- 408 is using quite a bit of oil
- 6.0 swap
- Need South Bay Los Angeles Shop
- THROWING CODES! p0154 and p1153
- What is the best cam for a automatic trans camaro?
- Specific header question
- 1.7 Rockers
- Shorty header Street cam, besides CheaTR cam?
- Alternator Issues - Need Help Fast!
- what is this tube on the 4l60E? (pic)
- 6 speed sensor question
- missfire, then goes away!?
- ls1 help on parts fast....
- How does the oil pump work on an LS?
- Autometer Tach / LS1
- LT1/LS1 swap
- where to get LS1 windage tray?
- General Questions about a Transam
- 98 Trans am
- Extreme Battery Drain, Checked all fuses, please help!!!!!
- cats on 98 ss starting to smell
- What if..
- Headers and o2 codes
- Stock 2002 SS - Mods???
- LS1/6 swap into 95z28
- oil pressure question
- Buying a LS1
- Cat recommendations
- best bang for the buck
- Problems with my 2000 Camaro SS
- Is synthetic oil a MUST
- ls3 to 454
- slight misfires, driver side only
- Accessory Routing Questions.
- Do you have to replace Valve Springs every 20K Miles with a Futral F-14 Cam?
- P0135/p0300
