decarboning engine
Old Jan 18, 2005 | 09:18 AM
nirvana91's Avatar
decarboning engine
what should i put in my car to clean it out? a couple people told me to use atf, should i use it and how much? thanks
Old Jan 18, 2005 | 09:40 AM
shouldaboughtthez's Avatar
Re: decarboning engine
I know back in the carberator days you could do that, as I have seen it. On a ls1 or lt1 I would think it would be a little harder, due to the throttle body sits in front of the engine and not on top. I just use a good throttle body cleaner while the engine is running at normal temp, then reset the computer to erase any codes that might have set.
Old Jan 18, 2005 | 11:31 AM
teke184's Avatar
do a search for "seafoam" and "deepcreep"
both are designed to be poured in the throttle body while running and clean out the engine.
worked on my lt1
Old Jan 18, 2005 | 11:35 AM
Knowklew's Avatar
toothbrush and throttlebody cleaner........the whole can, one of the small ones like the dealers use. just be aware that when you start it, it will smoke like crazy for a short while. after that you could always throw some fuel injector cleaner in.
Old Jan 18, 2005 | 07:38 PM
Greed4Speed's Avatar
ATF would kill the cats and O2s
I use seafoam.
Old Jan 18, 2005 | 08:59 PM
jay_lt4's Avatar
water works great for cleaning carbon out of an engine, get a container and suck it into the running engine with a small vacuum line
Old Jan 20, 2005 | 11:35 AM
Super Slow '97's Avatar
GM also makes a product call Top engine cleaner it works similar to Sea Foam. I used it and had no problems.
Old Jan 24, 2005 | 12:05 PM
gav'spurplez's Avatar
find someone who works at a dealer. my techs have a special pressurized tool that induces dacrab cleaner and if you want injector cleaner directly into the fuel rail and intake.
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
