View Full Version : LS1 Based Engine Tech
- What's the highest lift you can have on a Cam on stock pistons?
- Mechanical or electrical gauges???
- 115 mph Limiter on Z28?
- trany swap
- Can I make my fan come on sooner without programming?
- ...anyone have this set-up?
- i need a little help
- Z-28 Coil Springs
- Will truck intake manifold fit LS1?
- Convertible T/A, Weight? AutoX?
- where to get seat mounting brackets????
- what should my car be runnin????
- What's this "G2" ??
- Anyone done sidepipes?
- how long will the ls-1 be sold?
- Couple of questions about buying a used LS1
- Is the only diff In Power between '98-'02 Intake & Cam?
- Need serious help please
- Help!!!how to remove drivers seat...
- MSD box on an LS1?
- wtb 12 bolt or 9" rearend that will bolt up to 2001 Z28
- SLP Loudmouth Exhaust
- Rear end Oil
- 6-speed question
- Wot About Od
- LS1 verts inside please..
- how much can my stock rear end handle???
- whats a ta cover???
- HELP!!!!Engine Misfiring...HELP!!!!!
- Removing or Gutting the "Cats"
- Suspension "Thump" Anyone?
- Clutch experts in here for simple question!
- Bone stock LS1
- GM ground effects on a Camaro?
- will 2k headers work on 2k1 car???
- caliper covers?
- Can i run Hypertech without reset?
- Factory Warranty Question
- Cam/ Heads & Cam install $'s - what are some average prices ?
- True Duals
- Help!!!!!install Of Rksport Power Antenna
- HP limits of LS1 block with turbos
- 9'' FORD 12 bolt rear end vs. the competition
- Ls1 running too rich when cold
- Special on MTI lids-$79, worth it?
- bolt on ls1 runs low 11
- BMR Tubular SFC's, are they any good?
- Need some advice on storing my car!!!
- All you FTRA owners
- High Flow CAT's...opinions
- Spohn Adj.Torq Arm Installed
- Heater making buzzing noise
- Using HYPERTECH
- z28 Torque
- For new jacks. Exhaust headers
- rear end?
- Rear End
- Keyless remote ??? yup another one
- Ceramic Stage 3 clutch price
- Problem with my 2002 Z28
- anyone sick of chevy?
- Interior Lights?
- What do these SES (service engine soon) Codes mean?
- Blackened exhaust tip
- automatic headlights
- Headers?
- Need some help
- Getting 98 Z- What first?
- WS6 Air Box on SS
- Good Mods?
- Fuel Problem Help Asap
- A4s Beware!
- Gas Mileage
- dropping an LS1 in a 93 camaro
- Need advice on aftermarket lower control arms
- I Am Rhinosvt
- Noisy LS1 Cold Starts, anyone else?
- Which header length is best?
- How much louder is gutted cats?
- Need LS1 info
- need quick answer! gear lube ?!
- Exhaust question for new LS1 owner
- Can someone run a carfax?
- Headers which ones do I buy?
- Garage mechanic damages left fender connection points while lifting LS1
- Air/fuel Gauge Hook-up Question?
- Tranny Question????
- Gave up my dream of reaching 11s ...
- anyone who bought a 99' LS1 6 speed f body from dealer come in a sec.
- motorless
- quick help with oil press problem?
- bump-stop mod help!!
- Silver Face Gauges
- Difference in HP in LS1's
- 70K Miles
- Home made GMMG...sort of.....
- Lid or K&N FIPK???
- Whisper Lids
- Modded Stock Air Box Lid Or Aftermarket...
- Approx. Cost for cutout install
- Does any LS1 compcams or gm hot cams have a carb eo # legal for CA??
- where can i get the speedo dash bulbs?
- looked at 98 ls1 t/a, question on gears!...
- Y-pipe
- Tire life
- what CAM first
- Converting an '01 LS1
- axles in play
- SLP Aftermarket Intake Lid
- will my 700r4 tranny work in my buddys 01 ls1
- Pics After Ram-Air Hood and Silver Accent Install
- biggest rotor 98-02 z28 will take w/ 16" wheel
- F1 limits on the 1/4?
- V6 Suspension/Brakes VS V8 Suspension/Brakes
- Looking for LS1 are '98-'02 M6 O.K.
- TB Bumpstop Grind mod
- HotCam or Comp Cam?
- California Emissions
- HElP!!! Car stuck in 4th gear......
- please help with my delema
- Which SFC's do you have?
- tranny swap
- Just Back From The Track
- Trans Am owners
- Cutting springs.....
- Headlight motor is grinding.. How can I fix?
- Diablosport Predator Dyno Results...
- Spun out Z28, possible damage to rear
- Insurance rates in ATL
- Lt Headers Decision: Which Would You Go With?
- 1/8 mile #'s
- Where can I find an "SS" grille insert
- Why don't I have a rear defogger?
- drive car, put in garage and smells like rotten eggs
- Omg Cat Flp Cat On Fire!!!!help Now!!!!
- Baker hose for K & N FIPK system.
- Anyone running a Whisper lid beware!
- Ultra Z hood....
- That annoying Low coolant light
- What is the ballpark estimate of getting dynoed?
- Wheel well rubbing
- Help me lower my car
- If I remove the catalytic converter.....
- If I lower do I need Lower Control Arms?
- LS1 Cam Question ?
- What do i need for a 98 SS a4 tranny service?
- Whatcha Think?
- does 98 SS have a stock transcooler?
- Does an 01 LS1 Z28 Monsoon Radio have a seperate amp?
- Quick Oil question
- 2000 ss braking help[calipers,rotors]
- Anyone using TRAK-PAK????
- throttle body
- Whatcha think of this?
- How to install shift light?
- 410 Gears...
- vibration while braking.
- sites
- Track Results
- Anyone use 15" Drag Radials?
- Quick response! Car in parts. What wires are the positive and negative on the...
- HELP car wont start..99 M6
- need help buying new T/A
- Help!
- best spark plugs?
- Help W/ Gauges
- How can I make my DRL's white instead of amber?
- 2-yr and 30,000 miles...do the brakes need attention?
- something is rubbing?????? help!
- Is it normal, while braking, for the wheels to majorly turn left or right?
- second oil change.. this time im not payin $55.00
- 2002 SS Brakes, 4 piston?
- whats the best way to add HP?
- Putting car in garage, and hints?
- Porting The Stock Mass Air Is It Worth It????
- 1/4 Times
- LS1-edit to disable torque management
- Stroking an LS1
- Taylor Spark Plug Wires
- 2000 SS dyno numbers?
- 2001 SS question
- Question about SLP Fan Switch...
- 3.73s and 4.10s
- Custom Short Stick
- SLP or HOOKER long tube headers? + Hotchkis SFC???
- ASR on or off when racing???
- DMS Springs review
- SLP Quad exhaust
- I Did It!
- tachometer
- % hp lost to Rear wheels?
- headers
- LS1 trans question
- Ported/Polished Throttle Body
- AWD on a ls1???
- B4C Police Package any power difference from typical Z-28?
- where's my flasher at??
- Check engine light
- Corvette things?
- Anyone ever had their car damaged by a tow truck?
- whats the deal with my burn out?
- Are My ASP Pulleys OK???
- Air lid question
- Electronic Cutout (QTEC)
- Metal flakes in oil?
- HPP3 vs LS1 Edit
- BEST mod going
- EGR mod question
- is it possible to unhook the milelage gauge?
- b4 i install my STB...
- Clutch Slipping at 3500 Miles!
- headlight conversion (from LT1 to LS1)
- LS1motorsports lid FS
- SFC's
- WS6 owners inside please....
- Torq-Thrust II
- '99 Camaro SS Shifting Problem
- What does LS-1 stand for?
- Need help, Camaro problem
- slave cylinder
- A4
- I need help with superchargers and turbos
- got my 02 dynoed, figured i would tell
- Bent Push Rods?
- 4.10 vs 3.73
- where to buy interior molding??
- SS Ram Air And FTRA
- Push rods
- Direct Flo Lid
- exhaust thread
- Nos?
- HELP! Please....car is dead!
- o2 sensor or simulator
- OIL PAN BOLT STRIPPED!!help
- 315 on SS rims
- 'Notchy/Sporadic' Throttle Response
- Someone Please come here. You all have confused me bigtime!
- Tq. Management
- Electric Cutout Questions
- Oil filter change
- New Dyno #'s!!!!!!!
- Need help with lowering springs--
- 6-Speed Transmission Problems 99 Z28?
- Turn Signal, dumb question:
- Power Windows dying! Ideas?
- Guages reset???
- Installed Loudmouth.. A few things to say about it
- HPP3 help
- ls1fuel rail covers
