View Full Version : LS1 Based Engine Tech
- weird noise
- drop in oil pressure
- gas mileage reduced
- oil pressure/engine temperature problem...help please!!!!!
- impala 303hp?
- 42hp & 26 ft/lbs tq gain
- New to this so please help me
- DART'S New Head For The LS1
- Tsp Cat-y-pipe?
- SSRA and water
- Harder to work on, LS1 Vette or LS1 F-body?
- Help me please.....I need answers!
- Cats??
- Exhaust ?
- I want to be fast (Swap)
- Loudmouth vs. Flowmaster
- Probably a Dumb question... ls1 vs lsX
- Is having a new tranny a bad sign in a car?
- 89,000 mi too many?
- 851hp Camaro SS
- SLP Quad Exhuast
- LS1 dyno graph?
- Looking for Ceramic Coated LT Pacesetter Headers
- what cam to go with?
- TSP Rumbler
- head/cam/stall..need opinions on future setup
- Texas Speed & Performance LS2 402 cid Short-Block Special!
- Ls1 Cui
- Another "How much HP" Question
- What's the benefit to.....
- Where to get restoration parts cheap...?
- ignition lock cylinder
- LS2 into a 94Z28 questions
- Need suggestions for ps/alt replacemement
- Need Information about exhaust systems
- Help! Metal piece broke out of Taylor wire
- Rattling Borla
- How much power can a full bolt on LS1 make?
- ignition coil pins of death?
- SSRA replacement
- How much power?
- Kooks Y-pipe
- What is the C.R. of the stock LS6?
- NGK TR55 "V-Plug"?
- FlowTech Headers
- Looking for LT Pacesetters Headers for '99 LS-1
- LS6 Cam?????
- Tell me this guy is wrong
- Thinkin about a Cam...Got a few ?'s
- Noises over 5,000 RPM
- Header Install guide?
- guess on e.t./mph for this setup?
- stroker motor installe, serious prob I cant find the prob.
- PCMforless or Dyno Tuning
- Are these reusable????
- EGR AIR Blockoff Plates?
- Ls1 swaps
- where can I get theses from asap!!!!
- gears for my 02 ss
- Undecided On Cb
- Worth it?
- best place to buy 2 new knock sensors?
- What is the best wide band o2 sensor for
- Looking for a locking gas cap for the TA. This pisses me off!
- quick question
- Is it worth my time to......
- Dyno tune expectations
- RPM problems in my 98 ls1
- Dissapointment?! DYNO #'S
- Slp Maf
- Got new urethane mounts today!
- What I'm Really Looking For.
- Qtp Headers?
- to buy or not to buy?
- Thoughts on f-15
- Put water in my intake [while running] to get the carbon out?
- Got my Loudmouth and Lid today!!!
- What to look for when looking to buy.
- Problems - o2's, cats, worse?
- Why doesn't anyone use these???
- lsx engine covers
- How do you disable VATS? (Passkey)
- Maximum Lift Stock Springs can Handle?!
- Driving Impression
- I got a P0405 Code?!?!?!
- Cam Swap Complete
- Fly wheel?
- Reliablity
- So let's review.
- LS6 Intake Installation
- Underhood Dress Up
- digital gauges (trans and water) in ac vent
- What do u guys get for MPG?
- SS vs Z28
- Looking for a good LS1
- Coil pack mount
- LS1 - Thermostat?
- Any numbers w/PP stg2 per. bolt
- Did previous owner install a pulley? What is diameter of stock one?
- rocker arms?
- GM part# 22720375 -- correct locking gas cap?
- LS6 Intake vs. LS2 Intake
- Isn't the LS6 a bigger block than the LS1?
- SES light with two codes (P0113/P0332)
- Will a '04 GTO clutch fit a 98 camaro?
- anyone have a carfax account? (my Z28 is broken!)
- Underdrive pullies
- LM and ORYP
- Ported Tb?
- how to get 390rwhp with bolt ons?
- Which one has a better history
- question about supposed, weak rear end...
- Question about Cam Sensor and Cranksensor?
- Engine Package For You Mileage LS1 Guys
- question: catalityc converter
- Problems starting
- Which one is unbearable
- Oil and 02 sensor question
- How much rwhp can stock LS1 Fuel pumps support?
- Spun bearings...
- How much of a difference.....
- where is the main sensor fuse? (other probs. as well)
- Cam swap with NO reprogram.
- Granatelli MAF
- what cam do you guys recommend
- Stock bolts in headers......VOL I
- How long did your NGK TR55's last?
- Install Help
- Pics of my Loudmouth installed
- Hey You Man!
- Help scanning 02WS6
- Air?
- 1 quick, dumb Q.
- fuseable links off the alternator?
- Steering Fluid Leak?
- Will these LS6 springs work with the B1 cam?
- 120mph 6-speed cars? n/a
- failed nj emmisions for engine codes =x
- Revs don't always fall off like they should
- How To Quite Down My Noise 2002 LS1
- Need some help
- Exact differences as to why the LS6 intake makes more power.
- IAT sensor p/n
- 13.0 Flat?
- buying ls1 6spd
- Emmissions equipment
- catted y-pipe on longtube headers, how much HP loss and sound quality?
- Tbb?
- Hey YOu!
- a (non specific question) cam ques
- another question about cutouts...
- which heads??
- whats this? pic
- How is this for first rd
- is it easy and how much would i expect to gain....
- Which cat-back for my setup?
- How hard is it too.....
- 1.7roller rockers...worth it?
- sputtering at low RPM's
- Stock Torque
- Real Quick Question....
- Little help on bad case of piston slap
- Wow!
- Time for a tune up. Best plugs and wires???
- QTP exhaust cutout
- Heater hose
- Need Help Now!!!!!!
- think a buddies got problems... what should this setup be running?
- Engine might be shot
- mac headers
- cmotorsports heads?
- where did you get your LS6 intake manifold and for how much?
- maybe a dumb question about cutout...
- SLP Perfomance Pac
- starter problem??
- Opinions on upgrading to an LS2?
- Anyone ever used these?
- Any Ls1 Airbox smart people here? which airboxes are similar?
- swapping gauge cluster 01' and 02' z28's
- Which mod?
- how to get to low 12's?
- Can anyone give me an estimate of how much hp i am making at the rear wheels ?
- Gauging Interest In Fall LS1/LS2 Shortblock Sale
- Rocker Arms
- Y-pipe ?
- oil pressure
- So What's Going On with Precision Race Components?
- Winter Projects....I know its early but....
- Thoughts on the Loudmouth 2
- LS6 intake vs. 4.10's
- Throttle Position Sensor Replacement??
- 2002 stock exhaust
- Headers for a lowered Camaro
- Injector help?
- Engine Cradle
- LS1 Buyers guide
- I'm "Pinging"
- Want to tune out codes,BUT?
- Tunning question...
- How Much Quicker Will My Car Be By Adjusting Shift Points & AF Ratio
- Where can I get a STOCK MAF? p/n???
- Trap 104mph
- How much Hp will this make and how much does it cost?
- Alternator whine
- o2 Sensor
- Which one works the best
- Lt Headers.
- Firing order
- too much engine heat?
- Engine Trouble
- power steering pump?
- spark plugs?
- This may be a stupid question...
- New Cam and Headers Wed.
- bassani exhaust
- my very first run on the dyno =)
- Stroker Kit Sale
- Yet another overheating problem
- Things ive noticed since i bought my 02 WS6
- brake fluid leak where master cyl meets brake booster...but...
- O2 Sensor Codes
- last min tips?header install
- Running too lean?
- Help need some real brain power in here
- Little help
- oil drain bolt
- LS1 to LS2 Conversion Harnesses
- Where to get stock exhaust tips from a Trans Am
- kinda picky WTB question....
- Free Ram Air?
- SS vs. Vette
- Is my rear/tranny about to go?
- clutch and trans questions
- Lifter noise.....any cures?
- you can jack on the rearend...can you...
- Soon to be LS1 owner
- check this out
- Building my SS
- Descreening the MAFS?
- Bank 1
- How Hp?
- looking for ls1 or ls2 engine
- HELP! List your dyno #'s and 1/4 times.
- kn breather filter?
- How much are a brand new complete pair of 5.3L heads worth?
- Help w/ removing stripped wheel stud
- LS1 problem areas?
- Paper Filters?
- heat shield rattle?
- Starting problem!?!?
