PDA
View Full Version : LS1 Based Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68
  1. Will a 99 SLP Y-Pipe ft my 02
  2. How much does your air filter stop?
  3. How To Remove Air Bags??????????
  4. how long did it take for your LS1 to start running strong?
  5. Almost dynomouth, but not!
  6. Will Torque Converter void warranty????
  7. KN Air Filter
  8. Fuel type for Z28
  9. loudmouth sound clips?? anyone
  10. DiabloSport Predator News!
  11. Exhaust Upgrade
  12. Build Number
  13. NE High Performance Clutch Spring? LOL
  14. 6speed swap to a 4L80 info needed
  15. POLL: Ice down at a strip.. do you do it?
  16. Possible low idle - may have a problem
  17. Why do my exhaust manifolds look like headers?
  18. MAF screen removal
  19. Looking to swap in LS1 got?
  20. Gear test with RPMs, how fast??
  21. brake squealing after 2700 mi
  22. That damn mod bug...
  23. 4.10s
  24. So what's my final gear?
  25. Eibach Pro-kit
  26. what is a good price for a 98 ss camaro?
  27. What about MTI?
  28. "Tail of the Dragon"
  29. What do you guys think of SLP?
  30. Pros and Cons of a Stroker LS1???
  31. Emissions in Chicago Area
  32. Installing MTI Carbon Fiber LID on my LS1??
  33. Normal running temp
  34. Pics of my newly Accented TA
  35. 98 Z28 Clutches
  36. What would be the best mods for an LS1 98-02 Camaro SS
  37. problem with power steering...
  38. Dyno a SS?
  39. Where to get a Tubular K-member cheap?
  40. Oil catch tank.
  41. $99 good for a SLP lid?
  42. A few "newbie" questions.
  43. Air Filter
  44. The Next Generation G-TECH/Pro Performance Meter
  45. Freaking vibration
  46. Matt Murphy package SS!?!?
  47. torque converter install?
  48. oops
  49. Air Induction on 94Z28 with LS1 Installed
  50. I need to sell my Z28!
  51. Ford 9" or Moser 12 Bolt??
  52. Are all SLP lids the same?
  53. Shooting nos on a LS1 compaired to an LT1
  54. Major 2nd gear grindage on SS
  55. SLP Loudmouth install yesterday
  56. crank pulley
  57. Part number for retractable antenna??
  58. What is the REAL change in HP in '01 LS1's?
  59. Exhaust Systems
  60. Twin Turbo LS1
  61. How do I adjust my shock sensor?
  62. SS vs. Z28
  63. My first time on the dyno, I am happy
  64. Some quick help please
  65. Why does my car run like an LT1 ?
  66. How do I reset the "Change Oil" light?
  67. SES light----Mac cat inefficient oper.
  68. 4L60E OD slip??
  69. wtf happened to my rear defroster?
  70. Looking to buy a new SS 2002?
  71. I have a 180* t-stat in my car, what if I use my HPP to make it think its a 160*?
  72. Help! Eratic idle after jump start!
  73. Corsa exhaust, yes or no?
  74. Sub Frame Connectors - weld or bolt?
  75. Opinion needed...
  76. what parts to get to covert a t/a to t/a with ws6 package
  77. how to instal bmr torque arm
  78. What is the difference between an LS1 engine and a LS6
  79. Just bought an SS
  80. SES light with MAF/lid??
  81. 2000 Trans Am LS1
  82. Should I get headers??????
  83. X pipe question
  84. Can I get enough traction with 9.5" rims?
  85. 3 Mufflers Later And Still Breakin
  86. Need help from the tech's
  87. cluster problem
  88. Granatelli Maf
  89. Generator that sounds like a Blow off Valve???
  90. LS1 A4 ---> M6 Swap Question
  91. Atlanta Speed Shops
  92. What are C5's dynoing at in the rear wheels, anybody have any numbers?
  93. what is the percentage difference between rear wheel hp and flywheel hp?
  94. Best Headers
  95. Looking for LS1 video clips
  96. Weight Reduction..????
  97. anyone have flow data on stock ls6 heads?
  98. HOLLY/lpe intake manifold
  99. Mti Carbon Fiber Air-lid???
  100. LS1 Engine Covers for Camaro SS
  101. Tire PSI, long tubes or short tube headers
  102. Did they make 4th gen ls1's without t-tops ?
  103. It is important the air pump, what is the real job?
  104. gmmg exhuast
  105. New LS1's times
  106. What are the best aftermarket tires to get?
  107. Taking the 3oth to the track for the first time
  108. How to change fog light?
  109. Where can I buy factory made C5 rims?
  110. Borla'a catback comes with
  111. my drivers side window was possessed this moring.
  112. will a vortech v1 supercharger fit ls1
  113. problem with my z28.. pelase help..
  114. How close to breaking into 12s am I?
  115. AutoTap EFILive V5
  116. LS1 to LS6 Swap Help with ?
  117. lift limit on stock LS1 springs?
  118. Advice on Next mod... Please post ALL opinions
  119. I'd really appreciate some opinions/feedback.
  120. rear wheel HP with a muffler
  121. Gteched a 2002 Z28 A4
  122. What Rear Gear would this have?
  123. power effects exhaust (tuneable)
  124. T56 advice please
  125. Friend wants me to buy a used LS-1 for 1500$
  126. What is cat back system?
  127. 12 Bolt/9 Inch
  128. Thinking of buying an LS1
  129. Building up an LS-1
  130. SLP lids...any1 have any problems
  131. First post on LS1 forum!!!
  132. LS1 Motorsports claims.....
  133. How to get my TA to sound Louder
  134. brakes: help me
  135. Question
  136. where can i get the camaro rear reflective sticker?
  137. 100 octane
  138. m6 1/4 mile junkies please help...
  139. New times with 02 z28
  140. ss vs z
  141. Just spoke to a flowmaster Tech..
  142. went to the track clucth pedal fell to the floor need help
  143. Where can I buy a Dynomouth?
  144. suspension installation...?
  145. what tool do you use for MAF ends??
  146. What is wrong with my clutch?
  147. Took your advice, and here are the results....
  148. Brake Life Expectancy
  149. Lid and catback exhaust
  150. New, got Traction control?
  151. Whats the difference between the LS6 intake manifold and mine?
  152. Anybody have pics of an SS with DMS springs installed?
  153. Front Turn Signal
  154. SLP fan switch
  155. Whats that laptop software to view LS1 Data?
  156. Opinions on this intake?
  157. Mod advice ...... '99 SS
  158. Anybody else have a hard time getting into 1st or Reverse?(M6)
  159. SLP Air Temp Module
  160. VIN Numbers and Product Number
  161. exhaust tips
  162. Anyone know torque specs for bellhousing bolts please....???
  163. How do I get the rubber boots off
  164. what is a trans mount and what does it do?
  165. Did I burn my clutch!?
  166. Question about M6 and porting MAF
  167. Honk, Honk at 12:30 and 5:00am, the alarm has a mind of it's own
  168. LT1 to LS1 swap
  169. Best headers for lowered car with head & cam?
  170. What Year In Stock Form Is Faster '01 or '02? What 1/4 Mile Time Slips?
  171. Cam Question????
  172. headers
  173. Factory seats weight
  174. where should i be?
  175. Stock Cam Specs
  176. oil cap
  177. Lowered with LTs?
  178. Link to the vette forum
  179. What should be next?
  180. Best rear end fluid/oil
  181. Looking for solid mid 12's
  182. came across a few more questions for my z28
  183. PCM or programmer
  184. A quick word of praise for DMS Springs...
  185. Does anyone have the SS style hood and have pics?
  186. LS1 to LS6 Questions
  187. torque converter ?'s
  188. Is The Ls1 Bulletproof???
  189. question about suspension or rear end
  190. Mobil 1 oil questions
  191. how much hp for intake,headers,and exhaust?
  192. my trans is bucking??
  193. What is the best head and cam combo for me?
  194. drag launch question...
  195. Electronic Shift Improvers Vs. Shift Kit
  196. Need part Number : Lower AirBox Assemply
  197. Did chevrolet...
  198. Newbie w/ question!!
  199. Groundeffects and exhaust
  200. guys with b&m shift plus
  201. Just bought an LS1 rear end and had a question?
  202. Cheap Modifications
  203. How much PSI in BFG DR's on Street/Track?
  204. turn signal
  205. Warranty vs LS1edit, powerprogrammer, etc etc?'s>>
  206. GMHTP Article Sep 2002 P.33 Center Line Tel Star Rims...Will they fit a 99??
  207. Exhaust Setup Question
  208. Aftermarket Electric Fans
  209. Need a new battery...any suggestions on which is the best one?
  210. Free Ram Air Mod
  211. QUICK!!! This is a good transmission mount??
  212. Long term sit...
  213. what type of abs system does the LS1 have
  214. Headers worth it?
  215. anyone in nc
  216. Need Opinions!!
  217. Build numbers for 1999
  218. how much does stock rear end weigh??
  219. Dynomouth info?
  220. want to get a lid but am hearing lots of problems with them not sealing
  221. 01 SS, 11K, asking $20K, should I jump on it?
  222. What now??
  223. 1998 Z28
  224. Going to look at an LS1 tomorrow
  225. Transgo + Hypertech
  226. pricing on a LS1
  227. longtubes, mids, or shorty headers
  228. 5.0 or LS1????
  229. anyone here have their LS1 supercharged?
  230. Price on an '99 T/A
  231. Auto guys with 3.73s, and a HPP = what did you program?
  232. New to new cars... Q's on CPU's
  233. Dyno test on a 2002 SS?
  234. ATR Catback?
  235. In your opinion, is it wort it....
  236. $3000+, What should I buy
  237. Getting my Magnaflow muffler tomarrow...
  238. Is the shark nozzle for N20 to close to throttle body
  239. Question about exhaust
  240. Horsepower and a 6# Supercharger
  241. Gm's Reason of Discounting the "Camaro"
  242. a few questions for the strip
  243. Part # needed
  244. ls1 HP +++++
  245. What does an 02 M6 Z28 weigh?
  246. long rubber piece for slp cai??
  247. how well does the ls1 engine hold up??
  248. Anybody have a sound file of a Magnaflow muffler on an LS1?
  249. LT's, need input, Please help!
  250. What do I need to beat a 97 Cobra?
