View Full Version : LS1 Based Engine Tech
- Ssra.
- Tranny Mount and O2
- Intakes?
- Bent push rod test-
- Are there any cone filter kits for the LS1?
- Exhaust work
- exhaust too close to gas tank
- Lid?
- Direct-Flo Lid
- Why are my Passenger side plugs fouling?
- vinci/crane LSx shaft mount rocker spy photos
- temp gauge???
- electric cutout?
- which way for an A4!
- Y Pipe for Pacesetter LTs
- how much do cats for a 96 z28 run +labor?
- Another Cam question
- Best Headers?
- Electric Coutout?
- The Turbonator
- GMMG or Magnaflow/LTs
- LS1 Cam / ValveTrain Questions
- Illegal Exh??
- Exhaust Question?Undecided
- LS1 to LS6 conversion? Input plz
- gasoline
- headers
- Buying a 2000 camaro, Sketchy seller. plz read
- MAF question
- Taking crap off.. :)
- Exhaust question...
- Bolt ons
- What cam???
- what to do...
- Should I Go From A 78mm Intake/TB To A 90mm?
- Gutting a Cat. Converter
- Zero oil pressure, need some help
- ls6 intake.... not your normal question
- How much resistance (OHMS) variance is allowable?
- lt1 to ls1 - what parts are interchangable?
- MSD ignition
- SLP Exhaust Rattle
- spark plugs
- Lifters and Cam removal?
- Purpose of pin connector in alternator?
- magnaflow and z28 ground fx problem
- HELP tranny temp gauge installation problem
- Thermostat
- People with pacesetter headers
- Attention Misfire/Ignition wizards!!!!!
- Ugh! Lack of Power in 2000 WS6
- What's the avg cost for 02 ls1
- Please Help, Random Misfire/Lean Condition!
- Best exhaust/ Best airlid
- cheaTR or Comp 224 CAM?
- Have questions about Borla cat back
- How do you check to see if/where you have a vacuum leak?
- headers
- stalling when tipping into the gas??
- install kit for headers..
- Coil relocation brackets???
- Pics of engines???
- Intake Manifold?
- Does my camaro got a chip in it???
- High power A4 pt.2
- who has rebuilt their engine theirself?
- what to look for?
- Pacesetter LT/TSP True Duals with Cats???
- How much can HP change due to outside cond.?
- Check engine Light
- So What Next?
- 0W-40 Mobil One?
- best fit/install and performance exhaust
- LS2 Question
- LS1 "freescan" and ALDL cable
- Big power in an A4
- Cam Questions
- oil for piston slap
- SLP Dual/Dual and/or Spintech w/Mac's owners inside please...
- Got a 02 WS6
- car wont start
- Temp still says 210
- LS2 "Auto Vs Manual" Big diffrence?
- Low RPM hesitation
- need some opinions and advice.
- exhaust pictures please!!
- Installing a new Water Pump please help.
- Tornato thing
- 6.0 using oil.
- LS1 manifold question, interchangable by year 98-02??
- my friends 00 Z wont catch 2nd w/ TC off...
- Im getting an ls1 and selling my lt1. What do i need to know?
- IMPORTANT: 5.3l LS1?
- buying a 02 WS6..little help
- LS1 Exhaust Header Differences?
- Rhoads lifters
- This should be fun. Put these in order
- Anybody ever use Slick 50 in their LS1 ?
- missfiring ls6
- need opinion please
- belt squeak
- bank 1, is the drivers side right?
- OEM throttle body
- Hotcam Kit Question
- Anyone with TSP Duals...
- Xpiped True Duals......or keep the GMMG?
- Cam Swap on an LS1 style truck motor
- metalic ringing noise from front of engine when warm
- HELP overheat and now Knocking!
- rubber hose on 2002 intake
- UPDATE:Overheating problem because of P/S Cooler
- doing an ls1 swap
- Tensioner Noise - Question
- SLP loudmouth II OR HOOKER cat back??????????
- Intake manifold question
- What are good pads and rotors to switch to on 16" rims?
- WHY THE HELL does my belt keep trying to come off?
- Why is my car blowing the eng ctrl fuse?
- anything i need to know?
- SLP Headers, more power w/ w/o cats?
- break in?
- the little mods...how much do they really do?
- What else do i need to run with this 96 LT4?
- Power cut when I turn the car on.
- LS1 Throttlebody bolt pattern dimensions?
- different mods and fuel milage
- engine backfire...Please help me
- test drove a mustang gt, ha ha!!
- Head Porting for 02 LS1 heads in Ga?
- Can I look at an LS1 engine and determine what year car it is out of?
- Small & Large Hp Short Blocks Now Available!!!
- 2002 Camaro Among best for 3 year Dependability
- Advancing 02 LS6 cam
- Help wiring gauges
- Steering wheel shutter?
- FIPK by K&N?
- What are the best headers out there?
- stock cats with headers
- ls6 with headers
- Had headers installed?? check this out
- Ported T/B
- Questions about 2000-2002 Z-28's
- Thinking..
- Cylinder Mode Misfire Index(Counts)???
- GM Top engine cleaner, did the search but have questions
- Ported Heads and Stock Cam
- overheating ??
- ditch my borla?
- how much power?
- Help!!!!!
- PCM question
- Tune Up?
- brake problem
- Stock rear ratio.... pls don't flame
- LS1&LS6 engines
- My Dyno Numbers
- Rough idle...poor mpg....no codes
- Pacesetter LT Headers
- off road pipe
- Port and Polich yourself???
- Cam too big for daily driver?
- throwing around true duals ideas...
- 5.3 heads compression?
- Terrible screeching sound, can someone help me??
- Exhaust smells kind of sweet and tips are black around edges......HELP
- got new SLP center-mount exhaust tips in the mail today -have new bracket thing
- Why are my spark plugs like this! HELP!!
- in know this is stupid but help please
- ORY w/o simms...
- stroker benefits?
- When will I need to upgrade injectors???
- Where to improve?
- Brake help!!
- LS6 Intake hardware..???What do I need?
- Car sputters and pops what the hell!!??
- PCM tuning?
- fuel injectors
- 01 Z28 Tune-up ???'s
- TB bypass mod?
- Problem with headers
- Stock Z28 Exhaust Tip Question
- Sudden Power Burst @ WOT
- $ 5000 To Play With
- What Cam??
- help
- need help on a ls6 svalve springs
- '02 Z28 A4 LS1 stock injector question;
- High Idle of SS Camaro 6sp.
- 140mph limit???
- SLP Performance Pac's, has anyone ever used one?
- starter problems
- safe to use comp cam 522-529 lift on a stock springs
- Should I feel bad...?
- A question I've had for some time about Ultra Z hoods and SS Hoods
- thermostat?
- need help changing wiper motor
- LT headers...what all do I get?
- Stock vs SLP MAF???
- Flowmaster 70 series or 80series which is better overall?
- ls1 exhaust what brand should i look into
- Anyone know if the power steering pulley...
- help on selecting the right cam for my 98 Z28
- how much louder
- sspddmn
- K&N Filter question?
- just uploaded pics of various 35th anni SS things many of you may not have seen
- lsx intake question
- o2 sensor help??
- Dex Coolant/Every 5 Years?
- ls1 swap into 78 delta 88
- Hints, tips, suggestions...
- Mods: Need Advice
- thermostat questions
- Installed pro 5.0 today, forgot 1 thing. suggestions?
- Shock installation Info needed
- what to do with AIR and EGR with LT install, 2000 ws6
- sweet thunder
- Borla Adjustable Catback
- Dynatech Supermaxx Headers
- Disapointed With Track Times
- Gen III motor build up
- GM changed spark plug gap for ls1's!?!?!?
- Testing an Idle Air Control Valve
- Temp guage problem...
- Some Info on Precision Race Components Cylinder Heads!
- headers
- Ls1 spark plug change...
- Changing oil pump, what else?
- Guess My Dyno Numbers
- SES Light - Engine Hesitates...Lean?
- Ok guys, you're the experts. What is wrong with my car.
- TSP PRC Stage 2.5 Heads or Stock LS6 Heads ?
- Anyone else have center-mount SLP dual exhaust that is broken in half?
- dual flowmasters
- egr sims
- Ls1 Question
- Smooth Bellows
- Service Light HELP
- Driving..Oil Pressure Gauge Drops to 0!!!
- My LS1 traps 97...help!
- mac ory
- My ASP Pulley seperated! :(
- the right cam
- So I ordered an 18'' chambered muffler......
- Best Cam??
- Ls6?
- Finally got me an Ls1!
- Car Won't Start
- Intake Manifold
- Chip
