How well do you know your stuff? Valvetrain tech questions...
Old Jan 2, 2005 | 09:36 PM
Timberwolf's Avatar
What's the max installed height of ls1 valve springs? How deep can you cut the spring pockets? What is the maximum diameter for stock spring pockets? What is the max diameter spring (non beehive style) that will clear the rockers? In specific, comp cam pro magnums if it matters.
Old Jan 3, 2005 | 06:47 AM
teke184's Avatar
Re: How well do you know your stuff? Valvetrain tech questions...
um...
max lift is .525"
that's all i know
Old Jan 3, 2005 | 10:53 PM
muraoka's Avatar
you could get longer valves.and the keepers and retainers come in plus sizes too.i'm using +.05 keepers, ti retainers gained .03 and stock length valves to offset the seat locators on my lt1.you can do the same on the ls1 just got to know what you want. also you should always set your installed height by pressure rather than inches. time and time again springs out of the same box have slightly different pressures.
matt
HectorM52
Jul 30, 2017 11:46 AM
69z-28
Jan 29, 2016 10:46 PM
robyyzpapa
Jul 7, 2015 10:05 AM
PROJECT X
Apr 17, 2015 12:13 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
