6.0 vs 5.3 heads?
Old Dec 27, 2004 | 08:24 AM
94droptopz's Avatar
6.0 vs 5.3 heads?
which set of heads is the best to be worked? im wanting to go with a heads cam set up and want some opinions on which heads i should buy to get worked. maybe pros cons on each. thanks
Old Dec 27, 2004 | 03:43 PM
Capn Pete's Avatar
Re: 6.0 vs 5.3 heads?
I hope you're not talking about doing 5.3 or 6.0L heads on your LT1???
From what I understand, the 5.3L heads have smaller chambers than any (or most? ) of the other 5.7L or 6.0L heads.....BUT, if you get the LS6 heads from the 5.7L LS6, or I believe it's the "LQ9" heads off the 6.0L truck engine (could be LQ4, but I'm sure it's LQ9 ) then they are the best "flowing" (the ports and chambers are the biggest, and will net the most HP). I think that the 5.3L heads flow similar to stock LS1 castings, but like I said before, they have smaller chambers, so they'll boost compression. The LQ9 truck heads, while they flow the same as LS6 heads, they have larger chambers and will reduce compression compared to LS6 heads.....they're probably the best bet for a forced-induction setup though. Somewhere in my "library" of magazines, I've got a really good article that breaks down ALL the Gen-III line of heads.....IIRC, the LS6 heads still stand as the best ones to get, while the LQ9 are probably "runner up" due to their good flow. And again, I'm pretty sure that 5.3L / LS1 heads flow similar, but you get more compression with 5.3L...
.....sorry for being long winded.....hope you got some answers there?!
Old Dec 28, 2004 | 07:21 AM
94droptopz's Avatar
actually that was a perfect answer oh and no its not for my 94 I think Im fixing to buy a 99 ss. I know a little about the lt1's but not much about the ls1's so im learning. thanks again for the help.
DirtyDaveW
Dec 1, 2016 05:37 PM
blac94Z
May 4, 2015 12:11 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
pimpss96
Feb 12, 2015 01:28 PM
skittlez87
Dec 29, 2014 03:23 PM
