How much air pressure to change springs?
Re: How much air pressure to change springs?
i've heard 50 or 60 pounds.
i did mine by just using the TDC method. that way the valves can't drop into the cylinder. they drop about an inch and hit the top of the piston.
worked great. just took alot of double checking to make sure i was actually AT tdc on the proper cylinder
95chwagon
Jan 13, 2015 09:19 PM
Jul 4, 2005 05:00 PM
