Fan Temps
Old Dec 9, 2004 | 05:20 PM
dav81z02ta's Avatar
Fan Temps
I just installed a 160* stat in my 02 TA so what temp should I set my fans to come on. I have a Predator programmer so I can set them to any temp. Also anyone who has a Predator what shift firmness are you set at, I want to firm mine up some. Thanks
Old Dec 10, 2004 | 04:54 AM
AL SS590 M6's Avatar
Moderator
Re: Fan Temps
You could try doing a search. The fan info has been posted before and I can't remember right of the top of my head.
On shift firmness you'll have to experiment. Each car seems to be a little different and the right shift feel is very subjective. Start small and work your way up. Caution: do not do this if you have any other pressure modifications to the trans.
Old Dec 10, 2004 | 06:30 AM
teke184's Avatar
Re: Fan Temps
i've always seen 185on/180off, not sure if you can do the secondary fan but that would probably be good at 210on/205off
Magenta_Hearts
Mar 29, 2017 08:54 PM
Zuvell
May 15, 2015 08:18 PM
Biggiebound
Apr 23, 2015 08:50 AM
Jul 4, 2005 05:00 PM
Camille
Jun 9, 2002 11:37 PM
