PDA
View Full Version : LS1 Based Engine Tech
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
  1. Help with cams
  2. Diagnostic steps for OBDII codes
  3. Make sure to keep your MAF clean!!
  4. Ticking Help
  5. power steering pressure line
  6. cleaning IAC?
  7. LS7 clutch kit
  8. Need help engine issues
  9. LS1 valley cover bolt size, what size?
  10. Dreaming Out Loud: Best Way to Make 600hp LSX
  11. Help w/ LS1Throttle Body Compatability
  12. LQX swap questions...
  13. Announcing a new LSx-based "How-to" Engine Manual:
  14. Looking at LS1s
  15. New Motor Leaking Oil From Rear Main Seal
  16. RPM drops and then stall at stop lights
  17. Is this Fuel Pump any good?
  18. WS6 electrical fire/smoke?
  19. loooking to swap out LS1 for truck based engine
  20. new to L series....questions
  21. ls1 or lt1?
  22. need help bad
  23. o2 sensor reading low voltage?
  24. ls1 Conversion?
  25. car wont start after motor swap
  26. Manifold Bolt Tightening Sequence 98 Z28 LS1 Camaro
  27. 5.3 heads budget build questions
  28. New to the ls1 need info and advice
  29. My car so far
  30. Need more power..
  31. Will be finishing my SS project....
  32. Life Expectancy of Cats?
  33. Wierd Noise ... Need advice
  34. New Z28 owner with questions
  35. Camaro SS 1998 code too lean
  36. Need some help
  37. header question
  38. Spark plug heat shields.
  39. Diesel Sound?
  40. Stroker Build Advice Needed
  41. help with building a 383 stroker
  42. Need a pic of the stock cats on a '98-'02 Z28, & will they fit an LT1?
  43. How much can you get out of a Cam before you begin to lose streetability?
  44. slp blackwing lid
  45. over heating!!!!
  46. LQ4 / LQ6 Information Requested...
  47. About to buy 2000 camaro V8
  48. HELP!!! Weird tapping noise.
  49. Wondering if anyone can lend me ATI Drill Pin Fixture
  50. Dex-cool
  51. Do I need to disable VATS?
  52. 98 F-Body turning over but no start... help needed.
  53. Car will not idle right with A/C Running. VIDEO INSIDE!!!
  54. Edelbrock CNC lingenfelter Head EDL61969 Heads, What's the Story?
  55. which cam should i use
  56. 160* stat
  57. Would a rod or bearing knock go away when warm ?
  58. just got a ls1
  59. Heads/Cam High Milage LS1?
  60. Nitrious Kits, are they all created equal?!
  61. 01 ram air ta
  62. First Car
  63. metal in oil pan
  64. BBK vs: LSX
  65. Cutting off at 6000 rpm
  66. Got questions about 2000 LS1
  67. Egn sensor fuse
  68. Exhaust Backfire issues
  69. Would you pay extra for an LE1 Z28?
  70. Z28, water leak..condensation, heater valve?
  71. Cam for Stage II's
  72. battery problem
  73. Question concerning 5.3 crank / connecting rods.....
  74. fuel trim sys lean
  75. Head Gasket or Piston Ring??
  76. idle dropping to 5oo rpm?
  77. What one is cylinder #5?
  78. Problems-Any solutions
  79. Buying a wrecked 98 z28
  80. Knock Sensor Throwing A Code
  81. Long Term Fuel Trim -99%
  82. Underdrive Pulley question
  83. LQ4 and a 6 speed?
  84. 99 z28
  85. Considering Buying
  86. Rear o2 Sensor ?
  87. cold air intake
  88. 5.3 to 6.0
  89. ALL of my rocker arms destroyed! If you have HS rockers, come in! DAMAGE PICS!
  90. Anyone have this intake?
  91. 2002 LS1 - Looking for info on Power Programmers
  92. ls1 swap from 1997 3800
  93. Blown engine? Tapping and squeaking after track.
  94. bad MAF and MAP
  95. Clunk
  96. how much hp can an ls1 handle?
  97. what to gett????
  98. general question about my 99 z28
  99. Muscle Shops in Fort Wayne,IN Area???
  100. Thermostat
  101. question
  102. Bottomed out on curb, now no start.
  103. Best place to buy an LS2?
  104. clutch and rack and pinion
  105. Looking at a 98 z28
  106. Is it true LS engines get quicker after a few thousand miles?
  107. car stalls when a/c on.....
  108. gauge lights not working 98 T/A
  109. Asr off abs inopt
  110. coolant smell
  111. TPS replacement
  112. A Mod in This Forum Now Has a Pansy Car.
  113. Misfire only hot??????????????
  114. What does this refer to?
  115. Cam finally installed! Question
  116. Couple of videos of my car.
  117. Pacesetter LT/ORY/GMMG - SS3600 Vid
  118. Poly motor mounts.
  119. Oil Pressure Switch
  120. 5.3 in a 94 Camaro
  121. car won't start, crank
  122. 799 5.3 heads
  123. Comp Pro Magnum 1.85 rocker install question
  124. Help!! Valve train question
  125. What does the PCV-Valve? And some other Problems :(
  126. Ls6/t56 swap in a 93-97 camaro z28!!!!
  127. Stock LS1 or stock 5.3 heads?
  128. 1998 Camaro Oil Pressure Gauge not reading???
  129. 92mm fast intake?
  130. 5.3 to LS2 Swap
  131. Whats wrong with this LS1??
  132. fast 92mm intake ?
  133. temp level sensor
  134. How much change will the stock program accept?
  135. opinions- ls2 heads and hot cam?
  136. asa cam swap
  137. Ignition coil testing?
  138. Needle bearings in oil?
  139. Please Help...Ls1 vs Lt1
  140. Why install an aftermarket maf sensor
  141. Dyno Fail
  142. Racetronics Fuel pump
  143. new setup.. new race car.
  144. car dies in rain and water
  145. Removing Oil Filler Neck
  146. Ls1 2 ls2 swap
  147. What is the pcv ground strap for
  148. Maff issues
  149. LS1 Assembly Torque Specs:
  150. Car hesitating to start Sometimes
  151. Power steering fluid leaking!
  152. My TR224 cammed car runs out of steam at 5000rpm!! Please help.
  153. Formal Introduction
  154. Help please!!!
  155. ss headers VS coated headers
  156. LS1 air pump question
  157. Knock sensor plug switch
  158. comp cams thumper camshaft
  159. 2002 Z28 M6 Random SES Light
  160. Vacuum diagram
  161. 98 Z28 138K miles
  162. Throttle body spacers, Any good?
  163. Check Your FAST 92 Bolts?
  164. cam size
  165. Car won't start intermittently - possible causes?
  166. Plugs & Wires
  167. Loud bang after engine knock. Now it won't turn over
  168. Battery questions
  169. Engine Sensor Fuse Keeps Blowing
  170. done
  171. yes another cam question
  172. Looking at air box mods/replacements
  173. knock at part throttle.
  174. rebuild info
  175. My 98 Z28 died today????
  176. 99 Camaro low coolant sensor comes on when it get warm??
  177. Crank sensor/ring?
  178. Fuel rail leak.... huge fuel leak..
  179. Lets see if you guys can fix this one
  180. Did any LS1 F-bodies receive LS6 components from the factory?
  181. Low oil pressure
  182. ls1 head swap
  183. LS1/LT1 engine swap.....help
  184. Antifreeze low
  185. Finally!
  186. cam sensor pigtail connector?
  187. po 343 code
  188. Runs rough, no codes
  189. Oil in my electric TB! Help
  190. Temp sensor Adapter
  191. Will I flood it?
  192. How do I remove this?? ? EGR BACK OF MANIFOLD
  193. yet another cam choice question, not too tough though
  194. Surge Tank Replacement on C5
  195. N20 on stock ls1
  196. Whats the Definition of a LSX?
  197. Won't stay running.
  198. O ring on the EGR tube
  199. 2000 T/A ider pulley
  200. Coil Relocation Brackets
  201. New Buy Basic's
  202. vacuum leak?
  203. dyno comparison: ls6 intake/ported TB vs FAST 90/90 ported
  204. Start up video of my car
  205. Whats This?
  206. Need help with a couple of ground wires.
  207. 5.3L into a 94 z28... help plz
  208. Cam and N20 ??
  209. Think ive been had...... Check it out.
  210. Good cam?
  211. looking for head and cam combo
  212. Heads and cam next week
  213. rev limiter?
  214. My car is making a weird sound. HELP inside please.
  215. diesal oil after build???
  216. Livernoid
  217. LS1 dyno tune
  218. Leaking Fuel Injector Symptoms?
  219. Ls6 swap in 2001 camaro ss
  220. Head search...LS2 casting 799 fit ls1????
  221. Hah. Stumbled onto an old vid of my old 408 Vette.
  222. Ls1 mass air flow question
  223. What's the biggest you can go with an LSX street motor?
  224. Broken seat!! What are the odds?
  225. Putting my LS1 back together... trying to figure out where a couple lines go
  226. Cam only automatics
  227. Lifter Guides
  228. Uh oh I broke something...
  229. Lifter valley cover, removal?
  230. serpentine belt
  231. 1/4 tuning
  232. power loss?
  233. How many broken cranks out there.
  234. Looking for an LS1
  235. ls6 head/ 224 cam install video
  236. Pre soaking lifters?
  237. LS1 Dyno Tune
  238. Needle bearings in oil
  239. 02 LS1 questions
  240. ls1 intake flip???
  241. Another H/C post!!
  242. What valve springs would I need?
  243. need info w/ engine swap>>>
  244. 4.8 or 5.3 LS engine 3rd gen swap questions
  245. Bottom end refresh
  246. Pulling the motor
  247. What should I replace/upgrade while I am ripping the engine apart? (also cam Q)
  248. 2000 Ram Air T/A Air filter
  249. Engine problem
  250. ls1 modified harness o2 sensor question
