View Full Version : LS1 Based Engine Tech
- Will cutting my cats out and fabbing a y-pipe be worth it?
- Skip-Shift Eliminator
- PPC headers and off road Y-pipe- go with stock cats or high flow?
- tranny rebuild time, please read...
- You guys ever seen one of these?
- Times with JetHot Lt's and duals
- air conditioning shutting off and heater turns on
- tb bypass any good??
- X Pipe with stock Headers
- do i need limited slip additive?
- lca brackets w/ strange rearend
- gears in my 98 z28
- Mac Header Install Tips
- Hotcam + Mac mids + MAF translator
- Bolt Ons Good Ones Bad Ones
- 4L60E Won't shift past 2
- Anyone Here Have Eibach Drag Launch Springs On Their Cars?
- Rear End Troubles
- 2000 SS ? Price ?
- which induction?
- Suspension Needs!!
- Quick Help: Okay to do !MAF and De-Screen Mod???
- Need to know size of hex bolt on Strut tower
- Cut the crap, is Header coating really worth it?
- Lower Et's
- What brake pads should I get?
- Oil Filter Question
- extended warranty
- Question on changing rearend gears??
- how much hp can the t-56 take???
- service engine soon light
- Magnaflow is awesome!
- pics of the window washer bottle, shroud removed for FIPK
- Pontiac Firebird trans am whats the DEAL!!!
- rear end questions...
- question regarding subframe connectors
- Brake Repair
- New M6 quarter time
- More power from a stop?
- Brake Job by the numbers.
- What can I get for ported heads and a LS6 intake?
- How much hp can a A4 handle?
- Does the Super Sucker come with provisions to seal the airbox?
- Need Help
- whos had A4 tranny problems?
- Cutting stock 99SS springs to lower car.
- GMMG Exhaust: How Loud is it?
- GM Warranty Question
- Dynomouth Exhaust
- SES light came on
- got money what to buy
- is it ok to jack the car up on the subframe connector?
- WFT,I have an oil leak.
- Need Help Now Please!!!!!!
- Fog Light
- eibach or H&R
- stripes
- a4 shift firmness
- Questions About Stall Converter and Rear End
- Injector noise?
- maf sencor help on my ls1
- Transmission problem found?
- 2000 SS owners in here!
- I Got a New LS1
- Piggyback PCM for LS1 Engines
- Exhaust manifold removal?
- Coolant Change Procedure
- Where to find????
- changing transmissions
- Ls6 intake noise
- 5.3L heads and ZO6 cam
- high end 3rd noise
- The Replacement's Mods?
- ss hood or supersucker/ftra?
- 80mm TB or Ported stock TB?
- custom exhaust cutout question
- New
- Cold air kits good, but beware of hydrolock!
- oil pressure guage sticking
- cut out installed y pipe?
- Difference between T/A and z28?
- Which electric cutout?
- How much HP should I have?
- cat-back
- Y pipe made by an exhaust shop?
- Flat Tire
- What gains can I expect from getting a whisper lid?
- Problems with SLP 85mm MAF?
- new ss
- Best intake manifold for 02 Camaro
- What next
- gauge installation
- 3X3 fernco or the smooth bellow
- Inline Fuel Pump
- 02 ported and polished Z06 heads and cam
- suspension testing
- slp lid + free ram air hp gains ?
- Help!!! DTC P0121 Error ???
- SLP Y-Pipe
- overheat need help please
- Creak Creak Creak
- idle adjustment screw?
- SES light and 6th gear
- PPC headers
- HPP problem
- Advice on gears, what is needed?
- 18 inch C5 wheels, what size tires?
- Borla Sound Clips
- sorry to bring this up again...
- short belt
- Help(23 pounds ft-lb is ?? in.-ibs)
- New Dyno #`s
- Transmision question for the m6 guys
- Track Results
- To SuperChip or not, that is the question.
- Replaced tranny mount w/a poly unit...now lots of noise?
- ls6 cam swap
- Car dies... HELP!
- BF Goodrich G-Force??
- need header help
- Difference between ticks
- New track numbers
- mechanic bad mouths cutout
- What distinguishes a regular 2002 Z28 from a 35th anniversary one?
- Any one else get HOT?
- What is this smell???
- Does computer tuning make the HPP obsolete?
- I need sheet scanned from the owners manual please!
- looing for a part
- Turbo ?
- how can you tell if...
- SSRA vs. Fast toys ram air kit
- MAFT questions...
- Gear ratio question
- slp vs kooks vs jet hots
- A question about sound...
- autolite 605?
- SSRA-go for it
- LS6 Intake and TNT Nitrous Kit
- Battery or Altenator?
- Is Corsa worth the price?
- SES light - anyone know this code?
- brake light
- best headers...need all suggestions
- passenger side ???
- Repetitive thumping noise during hard acceleration? PART 2
- Suspension, where to start?
- tick tick tick
- Ok, I changed my mind. I hate my 2.73s.
- Question for Local's, San Jose, CA (cams)
- camaro chip
- Stock '02 T/A times??
- tire pressure
- Top end not getting oil
- What is this noise???
- is this the shock ?
- Can you??
- Passenger side directional; burnt???!!!
- basic cam questions
- I am thinking on painting my car yellow!!! 02 z28
- Switching to Synthetic Question
- 1st time at track-3rd gear
- More LS1 dummy ?s
- clunking sound?
- Put in the bottle :)
- New car owners LSI- mileage when you start racing/ dragging
- Rubber meets the road
- Need Electrical Help Fast!
- Bigger RIms, do I need to do this.....
- Motor Oil
- What's the most horsepower out of an LS1 N/A?
- NITTO 555r tire psi for the street?
- 450HP w/o NOS???
- Transmission Surging....?
- Is there something wrong with my car?
- T/A A4 1320 question from a 5.0 guy....
- BMR sfc, torque arm, and tunnel brace
- how hard is to put on a hood on the camaro?
- can u feel a differance with a torqe converter
- Looks like im getting the adjustable Borla system! Happy with yours?
- Help...Strange Noise Neer Red Line
- Whisper lid separating from MAF d/t torque?
- LS1 info Please
- Who makes the best LCA's??
- SES P1416 ??
- ls1 underrated?
- Redline Water Wetter compatible/beneficial with DexCool?
- 1/4 mile times need help
- cutout & muffler or cutout & catback?
- door bezel switch help!!
- Commercial (corrected)
- PPC Spark Plug Wires?
- Color Code needed
- Good deal on a 99 SS??
- 6-speed problems
- Throwing belts and chirping noise
- as homer simpson would say...
- Got about a thousand to spend
- 15-16 MPG, is this normal gas mileage :confused:
- Ordered the Magnaflow muffler for my 98 Camaro!
- Spark plug gap
- Clutch question?
- Slave cylinders on LS1's
- Who would be the one to tell you you voided your warranty?
- Whats the deal with porting your Mass air maeter??
- cross country
- True dual exhaust?
- track time questions need help
- 2002 WS6 wheels
- Stock Compression Ratio???
- Where are the Grease Fittings?
- Cam, headers, and stock exhaust - ultimate sleeper??
- 3pt. Kenny Brown STB
- Buy an LS-1
- Newbie Q about SS exhaust
- Brakes
- ls1/ls6 exhaust manifolds
- torque strap
- FS: 1999 Camaro Z28
- Cowl Induction for LS1, any benefits?
- lets hear some good exhaust sounds
- where is the sponsors and LS1 inc pages
- another question on my last thread the ls6 intake for ls1
- I need some advice
- help...manual trans. question
- Spectacle finally has their website back up
- Combo?
- First Mods for SS
- need some help on tranny
- tsp or mti.. what lid to get
- How to upgrade rear on 1998 Z28??
- Trying to find a squeek and a grind
- Ws6
- Would this be posing???
- Who knew bad O2 sensors could really give you bad gas mileage...
- LS6 intake for an LS1
- Oil change light came on at 1200 miles???
- Tips on changing spark plugs
- Programming a 98 LS1
- Can the Tazzo VPC work on more than one vehicle??
- Super Sucker?
- SES Light and no Apparent Cause
- mileage gone downhill all of sudden
- GM LS6 heads CNC ported
- Replacing front blinker...
- Repair manuals for our cars??????
- Header Question
- power ant mod!!
