Car Starts, The Dies, Then Wont Start
Old Dec 8, 2004 | 01:02 PM
99TransAmWS6's Avatar
Went out to start my car this morning..and it fired right up..but died off right away. I tried again..and it would just crank..but not fire..i waited a couple mins..tried again..shes started and i gave her some gas...then she died again. I did notice that when i gave it gas..my RPM gauge did not move. What could be the problem??
Old Dec 8, 2004 | 01:40 PM
SSCamaro99_3's Avatar
Re: Car Starts, The Dies, Then Wont Start
Anywhere in the fuel system is a good possibility. It could be a simple as a filter.
Old Dec 8, 2004 | 01:45 PM
teke184's Avatar
actually i had a very similar thing happen to my 96z with a bad MAF sensor. would start and barely run, die on me...and only move if i really gave it gas.
on a blinde notion i unplugged the MAF and it purred like a kitten. installed the original MAF (had a recalibrated ZO6) and it has run great since.
try unplugging it, that causes it into limp home mode and will tell you if it's the maf or possibly another sensor.
Old Dec 8, 2004 | 02:34 PM
Teke the reason why i dont think its the maf..is the car starts..and immediatly dies..doesnt even bog.
I think its the fuel pump..Tell me if im wrong..but when you put the key to ACC position..you can usually hear the fuel pump prime correct? I dont hear it...and my gas gauge doesnt move at all which is weird... But why when i revved it up the 2nd time i got it to start...the tach gauge didnt move?
Old Dec 8, 2004 | 02:53 PM
teke184's Avatar
possible..
but it takes 30 seconds to pop the hood and unplug the maf...
Old Dec 8, 2004 | 03:09 PM
yea i unplugged it..still nothing
I put a screw driver in the fuel rail on the drivers side..where it has that stem in it..alittle bit of fuel came out..so i tried to start the car again...nothing..i pushed the stem in again..and no fuel came out..so im assuming my pumps shot. Cuz its not getting any fuel up to the fuel rail. And like i said..i dont here the fuel pump priming.
Old Dec 8, 2004 | 05:28 PM
teke184's Avatar
pull the fuel filter see what happens
Old Dec 8, 2004 | 06:08 PM
fast81's Avatar
first u need to turn the key to the run position and have someone listen at the gas tank with the cap off for it to run. then check your fuse and relay. my personal opinion is get it to a shop, someone that knows there way around gm cars. u guys might flame me but take it to a dealer it will be cheaper in the long run. and yes i do work at a gm dealer. does your key have the resistor in it? if it does do u have a security light and is it blinking when the key is turned on?
Old Dec 8, 2004 | 06:40 PM
no the its not the that VATS system...no security light..the car actually cranks..but dosent turn. Again as i said before..when you turn your go to the run position..you usually hear the pump prime the system..well i dont hear anything..and no fuel is coming outta the scrader valve when i release it.
Old Dec 8, 2004 | 08:49 PM
fast81's Avatar
well check the fuses and the relay first, or just pull the wires to the fuel pump at the tank connector and test for power with the relay jumpered
Old Dec 8, 2004 | 09:51 PM
i checked the fuel pump fuse..its fine....
Old Dec 9, 2004 | 01:07 PM
stone4779's Avatar
Sounds like the fuel pump but thats not exactly common on our cars....
Change the filter and see if it at least gets better....
It is firing at all? If not maybe the alt. went out at the same time as the battery? Happened to me before.....It would crank but not fire, then after a minutre it would crank some more, but never fire.
If its firing forget the alt & battery.
Old Dec 10, 2004 | 04:58 AM
AL SS590 M6's Avatar
Moderator
Fuel pump failure is very common on LS1 f-bodies that the owners let run real low an gas all of the time. The pumps are cooled by the gas in the tank. No gas = hot burned up pump.
Old Dec 10, 2004 | 06:14 AM
stone4779's Avatar
Oh Sorry I didnt realize it...Dont wanna confuse anybody.....Heck I never let mine get on E...full tank 'o premium 24-7.
Noenav
Mar 1, 2019 07:38 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
