PDA
View Full Version : LS1 Based Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
  1. "Guess-timates" on 1/4 mile times with 3.73's?
  2. Got my car Dyno'd
  3. Whats the standarded wheel size
  4. All power to one tire?
  5. Formula vs T/A whats different?
  6. just got back from the track.
  7. has anyone got their slp y pipe installed and their exhaust rattles?
  8. How to patch aluminum
  9. Faint 'Grumbling' sound when driving/turning slowly
  10. dead stock ta with a few miles, will i need 4th?
  11. Volant VS K&N
  12. Callaway Commemorative C8 #2 Nears Completion
  13. Getting the Ultra Z hood and not having the SS style airbox for it???
  14. Volant VS K&N
  15. Meziere's LS1 electric water pump questions?
  16. Got my first dyno this morning...
  17. Clutch Replacement, Need Advice
  18. Removing front sway bar
  19. Predator owners, what do you think about logging?
  20. SLP Smooth High Flow Bellows Kit
  21. Cut-out
  22. Shorty Headers?
  23. Qtec cutout
  24. what is the best thing to do
  25. Current Drain
  26. CarFax
  27. f-body prices in your area?
  28. Daiblo Predator + Pace MAF = problems?
  29. piston slap?
  30. Does your LS1 burn oil?
  31. O2 Sensor Heater Circuit Malfunction
  32. 2001-2002 F-Body Owners...
  33. Loudmouth diameter
  34. lifters
  35. help with finding out about TSBs
  36. hurst shifter
  37. Synthetic vs. petroleum base oil
  38. Which clutch should I get?
  39. DRL on '99 Camaro???
  40. LS1 and T56 price question
  41. True Dual Exhaust Question...
  42. Switching between ORP and cats out
  43. LS1 Out The Bottom.
  44. Need to replace fuel pump............
  45. Spec Stage 3 Carbon
  46. Need advise/feedback on shifters
  47. Magnaflow vs. Hooker Catback?
  48. AIR Pump Wires... (this is a quickie)
  49. Just got my LS1 =)
  50. Do I have a whisper lid?
  51. LS1 edit
  52. yellow ss?
  53. help me please
  54. website for salvage camaro parts
  55. Got pulled over. What Now?
  56. G5X2 cam, 425RWHP/411TQ, stock heads
  57. custom gmmg!!!!
  58. Replacement pushrods??
  59. SLP LTs and damn light again
  60. Spohn tq arm with SLP longtubes...?
  61. There's parakeets under my hood!
  62. LS1 won't start
  63. ? about gutted cats
  64. 35th aniversary SS
  65. Flowmaster catback???
  66. Changin the Tranny Oil
  67. Yank SS3600 converter is.....
  68. a-pillar gage pods and gages
  69. Just picked up a 2000 T/A what mods to do
  70. Any reviews of the new LS1 performance book?
  71. LS1 Repair manual problems finding the right one
  72. OIL pressure at 40psi ok?
  73. Need a little assistance
  74. Hey guys help me out-->Tranny Problem.
  75. will 02 or 03 zo6 rims fit the 2000 camaro z28?
  76. Finally Did a Gtech 1/4 mile!
  77. Where to start with my Maf Translator
  78. Rearend Question
  79. ls1 bellhousing ?s
  80. Line lock....?
  81. what are the common ls1 problems?
  82. Got some predator stats, they good or bad?
  83. differences between 99 and newer?
  84. to all u users & abusers of 315's
  85. Fog light switch interchange?
  86. Part# Help
  87. 315/35/18
  88. Funtional ram air?
  89. SLP's new "FlowPac"???
  90. Raising Compresion
  91. Top speed on nitto drag radials??
  92. Spark plug diagnosis
  93. Converter Lockup Questions - please help educate me !
  94. HELP Racign the M6 for the first time!
  95. new intake
  96. I feel retarded
  97. Braided steel exhaust
  98. Question on SFC's
  99. Heads Up Display on a Camaro?
  100. Missed the shift need some help
  101. who has had problems with the stock LS1 oil pump?
  102. SLP Loudmouth
  103. LT1 vs. LS1
  104. Lowering F-bodies
  105. More low end torque out of an LS1
  106. bent pushrod???
  107. Headers?
  108. Z06 injectors ?'s
  109. Question about gearing.
  110. cutout location?
  111. where can i buy a power antenna for my camaro?
  112. Best intake setup for a Firehawk
  113. pinion angle question
  114. Which Lid?
  115. Is a Chip Worth it?
  116. Fan Temps, When should I turn them on and off?
  117. '02 SS - First time dyno numbers!
  118. Modding a Firehawk
  119. Compared my LS1 to a stock LS1, found differences
  120. Rear End Bolts, how many Ft-Lbs?
  121. Swap?
  122. oil change-urgent
  123. A4 shifter problem?
  124. Absolute Speed heads + 215/220 old man cam = :-) ?
  125. Question about ARE Head/Cam package
  126. CNC LS6 heads + CC 216/220 cam = ??
  127. Will 99 firebird v6 rims fit a 94 formula?
  128. How to replace striped lugnut bolts ?
  129. 28# injectors reprogram or not
  130. AHH...need advice
  131. were all 98 & newer supposed to have aluminum driveshaft?
  132. 12,000 mile maintenance?
  133. spotting an LS6 manifold...
  134. End link bushings
  135. Power Windows
  136. ls1 verts and speed limiters...
  137. just curious how many here use there LS1 as daily drivers?
  138. New header install rough idle?
  139. My suspension feels horrible!
  140. Performance chip for advancement of timing?
  141. ASR Button Light
  142. Which Heads?
  143. Need help with header/y-pipe/center exhaust
  144. I'm new and thought ya'll might be able to help me (Insurance questions)
  145. 315/35/17's tires
  146. Can someone help? What gears do i have?
  147. Stock headers?
  148. car shakes real bad when braking
  149. Lug Nuts, How Many Ft-Lbs???
  150. Is it possible for the flasher to cause just the right side to blink and not the left
  151. Whisper Lid
  152. Which battery should I buy?
  153. Should I get a Y-Pipe?
  154. How do the clips work on the brakes
  155. How much would you pay for gutted cats?
  156. any ever hear of mac lowering springs??
  157. Ls1 Top Speed?
  158. Manual Shifting an A4
  159. dyno #'s and 1/4 time..
  160. Where to get a Clear LID ???
  161. LS1's Braking into 12's STOCK?
  162. anyone have this?....
  163. any ls1 magazines out there
  164. holley lingenfelter intake or ls6 intake
  165. Experienced electric cutout users inside please.
  166. Hurst T handle
  167. relocation brackets
  168. 17" - tire sizes
  169. what the hell is a LM exhaust
  170. WTF are traction bars?
  171. what does m6 mean and ? on long tube headers
  172. Vig 3600 convertor FS:
  173. chambered or loudmouth?
  174. Spark Plug Part Number Help!!
  175. Gmhtp Shootout Participants Picked
  176. Installation
  177. 1/4 time estimates??
  178. Intake question
  179. new dyno results!!
  180. Best place to get the Predator???
  181. what mod is worth it?
  182. Open element air cleaner?
  183. exhaust movie clip....
  184. 99 dyno numbers?
  185. Carsound Cats
  186. Long tube header
  187. LCA relocation brackets
  188. What kind of Headers.......
  189. MAC43098 Exhaust
  190. GTP racing or TEA heads?
  191. Removing stock cat back
  192. Wheel Widening
  193. Coated headers or not?
  194. HELP: What tire size do I need?
  195. How to Bleed Brakes...
  196. Whats the stock timing at idle for a 2001 ls1???
  197. New clutch for my 2000
  198. tracklink system...does it work?
  199. Next mod
  200. Expensive 02 simulators other alternatives
  201. Pulleys
  202. All 2002 Z28 Owners Question ?
  203. Hpp3
  204. Gear install
  205. Cats
  206. Front License Plate
  207. mods to 35th ss?
  208. My Bro is Giving me 2k to make his 99 push 380hp!
  209. Under-Dash wiring harness
  210. M6 or A4... which one to choose
  211. underated ls1
  212. $1000...what to buy???
  213. Flp Long tubes
  214. zz409 cam
  215. SES light
  216. Want SS Grille!!!
  217. thud at my feet
  218. Installed New Cam.. Now I have questions?
  219. New Carrier for 3.73's????
  220. Berger Black rear Tail Light Panel
  221. Gains from hooker LTs
  222. Power steering fluid
  223. 2001-2002 LS1s with LS6 intake manifolds from the factory?
  224. Dos anyone hav 98-02 with a LS6 in it? have some questions
  225. How much do used LS1 engines go for?
  226. LS1 and nos.. How much is max???
  227. Cooling fan mod
  228. back pressure and the LS1....
  229. Chicago-land emissions.......
  230. A4 SS VS. T56 TA - Who Will win top end?
  231. Going price for 99 TA WS6?
  232. What is the correct gap on my SPARK PLUGS for my LS1 Trans Am?
  233. Help! how to change fan settings to 180
  234. What cluch would be the best?
  235. whats up your tailpipe?
  236. How much does an all option 00 ss wiegh?
  237. Cam Install???
  238. Y-pipe
  239. Just bought a SS!!
  240. 2002 Cam is different?
  241. 1998 z28 cam help????
  242. Question on Lid
  243. Concerned about my Brakes
  244. Ls1/ls6
  245. Something wrong with my dyno #s?
  246. Quick power add on
  247. 98 Z28 BONE STOCK dyno #s
  248. 440+ rwhp, NA, stock block
  249. spun bearings and oiling problems with heads/cam
  250. T/A headlight problem....
