View Full Version : LS1 Based Engine Tech
- should i not buy LS1 cause of piston slap??
- started ticking/knocking all of a sudden...100miles from home HELP
- Will an MAF from a '02 work/fit fine in my '00?
- header question
- Going to test drive an LS1. What to look/listen for?
- Help with 98 SS that's for sale
- Question about LE1/427
- stock ls1 dyno
- Accel Digital Fuel Injection System???
- Header retrofit question?
- 98 f bodies have more problems/less reliable than 99 and up?
- what is the going rate on stock heads?
- The Infamous Piston Slap
- does an ls6 intake off a 02 ss have air and egr fittings?
- 01-02 SS SLP Exhaust Tip Inlet Size?
- asp crank and alt pulleys? best place to get them and should i?
- tell me this isnt godo right ????
- Help!!!
- Long Tubes On ... New muffler search
- Throttle body coolant hose size?
- Do I have dual cats or single?
- Weird Noise..
- SLP LS6 Intake Manifold worth it?
- Flowtech header install guide....
- Which one???
- Draining a gas tank
- Anyone have a loudmouth sound bite?
- Vavletrain Question for People w/T1 and Ported Heads
- whirring sound on startup?
- LSI 345HP boost package?
- 160 thermostat kit worth it?
- 1500 Budget
- Installing LS6 Intake QUICK QUESTION.NEED SOON
- LS1 Stage 1 Heads by FFHP
- Step-by-Step Flowtech header Install guide w/ pics
- what could it be? Starter?
- maf
- Cam Install
- Jet Hot Y-pipe
- Smooth Bellow BBK Compatible?
- Just Bought 01 Ram Air
- Flowtech header install - one person method
- z28 vs ss vs dual/dual mufflers
- Loudmouth too LOUD?
- the 98 LS1..iron or aluminum
- installing headers....help
- TSP rumbler VS Flowmasters
- where can i buy the lid for ramair ?
- Motor Noise
- Headers??
- Anyone using the Austin scoop?
- proper plug gap and larger oil filter #
- Corsa Exhaust Should i Get?
- TSP Rumbler tips
- Synthetic oil
- Royal Purple...does it make a difference???
- What else can I do to get more power?
- Oil change
- voiding warranty question
- if these cars have piston slap from factory why isnt there a recall?
- Is my ls1 gonna blow up
- Where did you install your catch can?
- Whole new exhaust if I get headers?
- Header leak questions
- slp cold air induction any good?
- A comment and a question (got flowtech lt's today)
- burning oil??
- Recommended Cam Setups?
- what is maft
- Installed Plugs.. more problems!
- Stroker
- My planned set up 2
- ls6 intake block off
- Help! My new crank bolt slides into the crank of my used built block
- Need quick response: MSD or Taylor wires
- Service engine soon light
- HOT CAM KIT vs... LS6 Conversion..
- High milage ls1
- What should I expect to pay for a cam swap?
- air pump question
- LT1 Destroying LS1
- what next?
- is my trans am really a formula? did the dealer lie?
- will ls6 intake be a direct swap with my regualr intake, what year ls1 have these?
- is the hooker aerochamber a chambered muffler like gmmg?
- gas gauge pegged
- Replaced horn and fixed yellow headlight this weekend
- Now should I........
- fuel rails
- GMMG Thread
- What's the best LS1 F-body year (1998-2002)?
- gasket
- I need a mentor.
- is this a good ls1 cam?
- Replace oil pressure sender without removing intake...
- Pulleys?
- Fan switch question?
- running rich
- recalls...don't know where else to throw this thread
- Whos got the link to the custom y-pipe with dual cutouts?
- will loudmouth sound good with hooker muffler in resonators place?
- is a tune necessary after longtube install?
- New gaskets....hard to do?
- Warranty Question
- lid
- C2vs.TR 220-224
- what were all the exhaust options for an SS 98-02
- what other y pipe will work with pacesetter longtubes on a 00?
- where to get pacesetter coated longtubes for 370.00 shipped? hows the y pipe
- Help,no spark.
- cam measurements
- Acting funny after header install!!!
- Need help BIG time, limp mode? MAF/O2?
- stage 2 patriot heads
- Installing a Walbro 255LPH in a 98 Z28
- locking gas cap for 1999 camaro SS?
- Bassani header install
- 2001 6-speed z28
- Flowtech Headers=badass
- Installed Headers and lost topend!
- Exhaust Opinion.
- any real dyno numbers going from stock y pipe to slp y pipe?
- will jethot catted y pipe fit on hooker longtubes?
- Is this a good deal?
- Bassani cat-back
- '98 Z28 Individual Coil Packs
- Odd question...how often do BOTH fans kick on during normal driving?
- Cam Swap Help!!!
- LS1 dos & don't article ?
- headers, y pipe, cats
- Throttle Cam, anyone swap one ?
- cammed LS1 HORRIBLE HORRIBLE RESULTS
- wiring harness
- cats not flowing properly?
- Emissions and pacesetters?
- Just want to make sure about ses code before I take it to chevy.
- Trex Cam
- question about throttle body bypass mod
- Breather for my '01 Lid?
- Thermostat ?
- touble with sister car
- LS1 intake assembly height?
- How to remove Convertible top?
- 2002 SS specs
- y pipe and headers Q
- How do I remove a headlight?
- Wheel spacers on a Trans Am
- K Intake Question
- An intake question???
- Another "Whats it worth" question
- Header Install question
- Is this really an LS1?
- some cheap deal on pacesetter headers??
- Ssra
- velocity stack
- Exhaust question
- LS1 brakes abutment brackets part number???
- no start
- test drove a 01 Ws6 have a guestion about engine noise
- Block the EGR or LS6 Intake?
- Question About Exhaust and Headers
- Dealer Services (Engine Cleaning)
- tires "ozone cracking " ??
- Quick exhaust question (muffler)
- cooling system question
- Removing rotor stud in 99TA..help?!
- Torque Converters. Help.
- Warranty ?
- How much better is the Bilstein HP option?
- About to buy an LS1....
- K&N filter oil inside the manifold....
- Rim Question
- what do rear spring insulators do for the rear end?
- Help needed
- header question
- Need Muffler Part #
- A mod that I might not know I have...?
- how about this 99 SS?
- Replacing fuel pump
- Your Input on this 99
- lM to loud
- Dumb question but it's bothering the s@#% out of me!!!
- My 99 A4 LS1 dyno numbers..
- Power Steering pump removal info needed.
- EFIlive 5.26.1 build`440
- Carfax please!
- Anyone have this problem?
- Getting car dyno tuned monday, few ?'s
- FRONT BRAKE ?s
- Which Is Better Ssra Or Ssra2?
- Am I hitting the rev limiter?
- Service Engine Light
- Flowtech headers and Y
- Not sure if this has been done or not
- LS1/LS6 book?
- All Borla owners in here please
- 2000 Z28 with NO power options
- Stupid question?
- dualing hp
- Dyno full exhaust
- HP for Hooker shorties?
- Exhaust problem?
- Flow Tech or Pace setter
- fans wont come on
- Starter problems?
- car running SLOWER after headers installed
- will hooker y pipe work with flowtech headers?
- Help me with some HEADERS
- Thermostat
- question
- SLP Take-Off Shocks
- Cam Packages...
- Getting car dyno tuned, should I upgrade injectors?
- Alternator battery line will not come off.
- The power plates finally arrived..
- What about this Air Temp Module or whatever its called
- List Some Inexpensive Mods
- mac longtubes and catted y pipe pros and cons, is it as good as jethot lt?
- does the holley powershot make you lose hp like the k&n filter?
- "new" 98 z28 - what to do first...newbie help
- Dirt Going Down into intake Valley.
- People who have done TB bypass
- Rumbler is gonna get me in trouble.. HELP!
- cam installed now i have no reverse
- Whos got Pacesetter Longtubes?
- Head and Cam install
- need some opinions on these mods and also have u guys ever heard of this?
- will this setup pass emmissions
- PCM tune really required after headers?
- My new over the axle dual exhaust
- ?? on cam install...
- LT's Installed, Front O2's not hooked up yet
- BMR front A-Arms for '00 SS
- P.V.C. question
- sterring sound
- What is this weirdness with Magnaflow....
- where can i get a manual sterring rack and pinion ready to go
- SLP cold air induction
- Smog legal headers
- LS-1 or LS-6 Intake?
- Sound Clips Page
- Any thoughts on this cam ... 212/218 115lsa
- Longtubes worth it on a stock ls1?
- Dyno after Heads/Cam
- TO those with long tube headers
- How often do you replace your clutch?
- SLP Airlid Question
- Average cost of long tube install?
- Need Help Asap
- Re- Wiring
