PDA
View Full Version : LS1 Based Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
  1. Pacesetters or Flowtech headers?
  2. motor mounts removal
  3. need your guys opinions please!!
  4. Professional cylinder head porting services
  5. Do I need the ALT UD pulley on an M6?
  6. TSP air lids
  7. Resistance with Longer Plug Wires??
  8. 160* thermostat and PCM program
  9. Mixing coolants
  10. 98 wont hold an idle on cold startup
  11. Not a recall but...
  12. Plug wires give H/P Gains?
  13. engine and tranny swap?
  14. What do ya think......
  15. What do I need to check?
  16. How many run stock timing chain with a cam?
  17. recall on 2001 catalytic convertors
  18. gears??
  19. engine knock?
  20. LS1 heads
  21. looking to make about 450 rwhp
  22. Attempting a tuneup - Whoa, This is going to be a PAIN!
  23. Heads ???
  24. LS1 normal running temp?
  25. car won't start
  26. which of these setups!
  27. maf question
  28. looking for a vendor for ported LS1 heads
  29. O2 simulator problem
  30. cam and springs install
  31. cam question
  32. anybody run the ASA cam? Video would be good
  33. Question about NGK Spark Plugs...
  34. Gas mileage loss after LT/ory install
  35. What are some common things that cause SES?
  36. Cut-To-Fit wires...
  37. LS1 Valve Springs
  38. horse power gains
  39. patriot 226 cam?
  40. LS1 Engine
  41. LS6 intake manifold
  42. SES on again
  43. Issue with fuel?
  44. Anyone running the CheaTR setup?
  45. Help!!! Emissions
  46. I need my car more quiet, please help!
  47. changed spark plugs, now hesitates
  48. keep or buy a new
  49. How to reach 450-500RWHP
  50. If I was to buy an ls7?
  51. egr delete
  52. New 160 Thermostat problem?
  53. iron block 6.0 swap
  54. Cam question...
  55. LS1 valve ajustment ???
  56. new guy/couple questions
  57. A question about my dyno results.
  58. Anyone heard of this intake? Any idea about it?
  59. My Car Sucked at the track....
  60. Automatic to 6 speed Swap
  61. Need advice about what to do with my money
  62. Getting all the coolant out
  63. head comparison
  64. 5-speed 1999 Trans Ams? Not made,correct?
  65. how much would you say this is worth
  66. HELP .. Engine problems started last night.
  67. Difference between SS & Trans Am??
  68. My car will not start, there is no spark
  69. Okay, dont bite my balls off, but, seriously, biggest cam for stock stall
  70. bbk
  71. PRC or Patriot Golds
  72. Upgrading H/C at high mileage?
  73. Help picking a cam.
  74. New to the ls1 crowd!
  75. rings damage the block?
  76. 10.85 in a Z06 stock with drag radials
  77. Hose Change Procedure
  78. New Best in Corvette :)
  79. good shop in pa
  80. Cut out?
  81. 500rwhp 408 iron block how hard?
  82. 98 z-28 vs 99 camaro ss
  83. New Cam (cam experts)
  84. How do I get taller install height?
  85. Need a reliable machine shop in New Jersey
  86. head stud fittment on ls6's?
  87. gm head bolts p/n??
  88. Car not starting :(
  89. tryin to ditch the blowmaster
  90. most of my valve springs are broken, Why
  91. First post, need some help, buying an SS!
  92. Torquer V.3 cam only numbers and some vids!!
  93. Anyone see this!! NUTS!
  94. Port and Polish...
  95. 160* thermostat???
  96. Help I have a strange Revving problem!
  97. Airbrushed Fbody Bottles
  98. Car's Hard To Start
  99. Installed a "Smoothe Bellow" for $5.99, I actually DO feel improvement...
  100. Cam Question
  101. cam installed and tune, do i need to drill the TB? Video
  102. '99 WS-6(Auto) Stock set-up hitting low 13's w/ 24k miles!
  103. Black smoke at WOT from light bolt-on 02' Z28
  104. ignition relay question
  105. Ram Air dyno question
  106. Exhaust...reason for low dyno #'s?
  107. New 383 Dyno Numbers
  108. Wierd problem... long story...
  109. valve slap
  110. The Black Widow #2
  111. intake and exhaust choice
  112. Got my dyno numbers!
  113. LS6 vs LS7?
  114. little confused on this intake...
  115. Once and for all, I have her back!
  116. Heads and Cam Help
  117. Dual remote oil filter kit...
  118. Low #s?
  119. Anyone know of a Shop that does it all?
  120. 350Z enthusiast in 5thgen section wants stock info
  121. slight wistle or whine after cam install
  122. Which Pulley Is This?(Pic)
  123. Nitrous Outlet Boooooorific Specials
  124. LS6 Intake Manifold on late 2002's
  125. Ls2 manual ?
  126. 2002 Camaro SS Heads and Cam Help
  127. stock ls1 head info...
  128. oxygen senors
  129. Seafoam on new plugs = bad idea?
  130. thanks for advice on cam install, video
  131. LOUDEST Exhuast
  132. ls1 boltons vs. ls2
  133. H/C install done, picts and video inside....
  134. Tapping from valvetrain - problem solved
  135. Help!!
  136. another ls1 cranks wont start question
  137. Full Tune up
  138. Port Throttle Body
  139. Got the 6.0L installed, BIG HP Ratings....
  140. Maf
  141. Maf
  142. Cat Converter question
  143. Bolt On LS1s
  144. will the 2000 ss exhaust fit my 91
  145. Is filter breather needed with whisper lid on '00 Z
  146. Help with deleting AIR
  147. Whining noise?
  148. best place to buy slp lid
  149. Anone interested in buying Pacesetter headers for a moderately cheap price?
  150. At what point does one need an engine girdle?
  151. water in power steering
  152. can the new Z06 handle 200 shot of nitrous?
  153. iron block 6.0 with ls6 heads
  154. K-member/engine cradel
  155. Head/Cam install this week....
  156. is it my water pump?
  157. High mileage thread.. Over 100,000
  158. TSP PRC head questions
  159. p1416: possible air check valve
  160. cam info needed
  161. have questions about water pump
  162. ok, I've made up my mind... What first...
  163. LS1 Engine Upgrade
  164. Front Seal Oil Leak-Bars Leak?
  165. code??
  166. Service Engine Soon Light
  167. Highway mileage with a cam.
  168. SLP 1.85 rocker arm packages
  169. $ burning a hole in my pocket!
  170. Hi all quick question
  171. Difference Between 98 through 02 Camaros?
  172. 6.0L Block in a 98Z??
  173. Misfire at idle
  174. Oil Problems!!!! Need Help Please!!
  175. NE1 Have Pics Of A LS1 Z28 Exhaust?
  176. another cam question(s)
  177. Fast intake & 1.7RR's
  178. random misfire
  179. what fuel additive do you put in a car that isn't driven much?
  180. Cam w/118K Too Much?
  181. how to get 400hp
  182. Much needed info.on Porting the LS1 TB
  183. Did some engine temp testing today....interesting..
  184. Anyone with Patriot stg II/f13 set up?
  185. 2001-2002 Intake Question
  186. wiring issues
  187. L92 with L76 intake
  188. Problems starting car when cold
  189. Will an LS6 throttle body...
  190. Motor Swap Help
  191. Question on ported TB
  192. code??
  193. cam tool, how does this thing work?
  194. K&N v/s Air Hog
  195. first mods
  196. VRE 1970 Camaro 427 LS1 Project
  197. what valve spring compressor to use?
  198. knock = fixed..
  199. Oxygen Sensor Reading
  200. anybody know the base circle on this cam?
  201. Is home-made ram air worth it?
  202. Need opinions on which block to choose
  203. ptv clearance questions
  204. What is casuing these noises?
  205. head/cam swap
  206. SES Codes P155 and P1153
  207. I need your help deciding....
  208. doing a rering job
  209. going to pull engine. need advice please
  210. bolt ons
  211. can't decide between two cams. HELP!
  212. Need a quick question answered.. please
  213. Comparing headers...
  214. Blown LS1 head gasket what chance block is okay?
  215. Cut off muffler make car quit?
  216. Lingfelter oil pumps...
  217. Engine swaps?/turbo's?
  218. Catalytic converter tuner
  219. Budget H/C setup.... But good...Recomends??
  220. Yo... help!
  221. emissions
  222. LS1 Dress Up Options
  223. Dig 6 on 01 TA
  224. Head Cam Package finalized.
  225. new roller rockers
  226. LS1 rough idle & hesitation
  227. DTC P0121 after FAST install....???
  228. fuel rail covers from a vett
  229. Error code, what does it mean?
  230. MAF question...
  231. Where does your temp gauge sit w/ the 160* stat?
  232. Scanned the DTC and 2 errors came up!
  233. Exhaust mods, good or bad effect on mileage ?
  234. Horsepower?????
  235. head/cam pairing
  236. valve spring help:
  237. ls1 engine covers
  238. tinkerbell oil filter makes me nervous...
  239. Volant CAI hybrid LT1 Roadmaster question
  240. LS1 to LS7. what upgrades can carry over?
  241. LS1 block Strength
  242. Vacuum Leak maybe?
  243. Vacuum Diagram or pics for LS1
  244. Engine noise
  245. Mac Mid Length Headers
  246. Katech belt tensioner?
  247. Z06 Maf
  248. Oil Filter Problem on LS1 in Germany
  249. Any one have Dyno #'s for MIdS vs LT's??
  250. Went to the track tonight.
