PDA
View Full Version : LS1 Based Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
  1. LS7 perhaps
  2. Valve guides
  3. O2 Sims
  4. Z06 Maf
  5. Stainless long tubes for $299 on Ebay
  6. Can I use ANY single prong Ignition Coil for my LS1?
  7. Valve Job angles?
  8. bought new heads have a ??
  9. Patriot Stage II LS1 Heads
  10. Uber tool against spark plug #8!
  11. ls6 fuel problems
  12. about to buy a crate ls1
  13. What are the differences between the 98-99-00-01-02 LS1's
  14. Just bought my LS1, questions on cam.
  15. SLP lid users, heads up.
  16. Difference between LS1 and 6.0 other than engine size
  17. How much HP do Z28's / SS's put out?
  18. 1998 LS1 Q's
  19. Power gone
  20. About to get my first LS1!
  21. A/C idler pulley
  22. Damnit, still overheating.
  23. odd blow off noise and cloud
  24. Stock heads
  25. z28 tags???
  26. Cracked cylinder wall
  27. Stock cam numbers
  28. How to convert
  29. Knock Retard
  30. TSP ls6 heads/ 228-230 cam, dyno results, mustang Dyno
  31. throttle body bypass need help
  32. Those of you that have replaced the alternator - how did you get it out ?
  33. shorty headers install
  34. Pic of hose for seafoam?
  35. LSx Blocks
  36. wat to look for?
  37. Aftermarket y pipe and headers
  38. Will they work?
  39. free mods
  40. Car starting problems and need help bad
  41. NOOB To the ls1
  42. LS1 and LS6 intakes
  43. LS6 manifold? casting #?
  44. Getting Married, $2500 in gift money...
  45. P0332, here's the story
  46. Maf
  47. Long Tubes: Flowtech vs Basani vs Hookers
  48. How much power is a PCM for less tune on a stock LS1 automatic car?
  49. Question HELP ME!! loud squeal, throwing belts!!!!
  50. Overheating issue
  51. Going from lt1 to ls1 is it that hard?
  52. People with headers...
  53. Pollution controll
  54. problem with 2000 Z28 wont go over 20 MPH
  55. Do you think this is a good deal?
  56. Squeak/Squeal from front of engine
  57. Comp lifters
  58. lid?
  59. stock 1998 A4 rwhp?
  60. humming/buzzing noise under hood
  61. Crank Shaft Sensor
  62. How are the LS2 coils grounded?
  63. Curious....
  64. 2.020/1.570 vlaves?
  65. Quick suggestion needed for a 2001 Vette
  66. PCV mod?
  67. Is 103 degrees Centigrade normal?
  68. Does an Iron Block 370 sound better for a turbo than a 408?
  69. Aftermarket LS2 Cams
  70. 02 sensors
  71. 02 sensors
  72. exhaust
  73. How to port a stock throttle body?
  74. What would a set of ls6 heads be worth in RWHP/RWTQ?
  75. Other parts with H/C instal?
  76. Warning SLP cold air kit
  77. gauges on LS1, hook ups
  78. Would a Volant CAI give me more HP over a LID?
  79. Gauges?
  80. where to get clear intake lid?
  81. When to change belts...
  82. Crane LS1 Gold Rockers
  83. Pulling engine
  84. Patriot Gold dual spring package
  85. which throttle body
  86. Large Vacume line on SLP lid
  87. Removing PS Pully
  88. Big Big Problem!!
  89. YET ANOTHER... Exhaust question!
  90. ls1 vs. ls6 intake
  91. Cam Shopping
  92. Ls-1 engine cover question??
  93. Stock 2001 Z-28 m6
  94. New Pacesetter LT's ??
  95. What did you run bone stock or with mild bolt ons?
  96. Long tubes
  97. TSP True Duals?
  98. New 99 Z28, where to start?
  99. Rod Or Clollapsed Lifter
  100. oil temp
  101. did I miss anything?
  102. LS1 Edit.... New Intake Manifold questions
  103. Fast Idle on my LS1
  104. Where to get vacuum for gauge?
  105. LS1 with LS2 heads cam and tb...
  106. stock exhaust tubing?
  107. Is the 2001 model LS1 transam a good year?
  108. 2000 Z28 engine replacement
  109. ls1 questions
  110. SES Light Question P0420
  111. Where can I get LS2 coil packs?
  112. THE PERFECT SOUND (vid inside)
  113. roller rockers
  114. porting the heads and throttle body
  115. new engine
  116. cam help
  117. oil catch cans
  118. Help:Changing Rod Bolts
  119. lumpy idle warm? smooth idle cold?!
  120. service engine soon light
  121. What's the weakest link to turn 6500?
  122. Crossed over to the dark side
  123. Tempramental LS1s
  124. Cold lifter ticks vs. more oil?
  125. What next?
  126. Changing 98 SS Stock Alarm Settings
  127. Oh where oh where did the Austin add-on go?...
  128. Tell me about my car!
  129. HELP: My car just turned itself off
  130. power gain
  131. Intakes: SSRA, Volant, K&N
  132. 98 SS Question
  133. T/A has a bad dead spot need help
  134. 01 headers on a 99?
  135. got a quick ?
  136. Do you guys have this problem???
  137. O2 Bypass for LS1
  138. Headers, long tube or short?
  139. HELP LS6 Intake Swap. Motor Reving High!
  140. bubbleing out of reservoir
  141. LS1 hot cam opinions?
  142. Are any years of the LS1 better then another?
  143. Least LSA cam on stock motor.
  144. 4.10 on A4 SS?
  145. Horsepower??
  146. Can I use the SLP FLow Pac kit and SSRA?
  147. Heads! Probaly a repeat but need help anyway
  148. is p0154 and p0134 rear only o2 codes?
  149. pushrods?
  150. s10 v6 to a ls1?
  151. Running like a 6cyl
  152. Exhaust pipe kinked, cant slide another section thru
  153. anyone done coil relocation
  154. Where to locate lower intake
  155. white smoke from below hood
  156. Adjustable fuel pressure regulator?
  157. Looking for Headers.
  158. Stiff accelerator pedal is normal?
  159. Cold Air Induction?
  160. LS1 H/C Numbers
  161. what modding steps to take?
  162. LS1 Mods
  163. Need Plug for SLP airlid
  164. LS1 Exhaust Question???
  165. Ported Heads with a stock cam?
  166. What Converter And Stall To Get On Stock Z
  167. ls2 intake on ls1 question
  168. 02 ss mods?
  169. LS1 running hot
  170. Where to check for Vacuum Leaks?
  171. How Much HP to the wheels will i get with this?
  172. Ls1 Vette vs ls1 f-body
  173. New Engine Pics
  174. Cam+Converter+California Question......
  175. whole in my ceramic LT's :(
  176. Best spark plugs for F14 cam
  177. question for the magic stick 3 guys
  178. What do you think?
  179. Average Gas Milege For Ls1
  180. Supporting vendors shipping to APO's
  181. heads and cam opinions
  182. Low maintenence Cam?
  183. how do I get better low end torque in my new WS6?
  184. felpro gasket part #.......?
  185. Is it beneficial to....
  186. stock throttle body size
  187. New to LS1's; what parts needed to handle major tq?
  188. Are there ANY prgmrs worth it, or do I need to LS1edit?
  189. 454 LS block
  190. Car starting problems!!!!! HELP
  191. Newbie Here
  192. Tick tick sound how to resolve ...!
  193. Final Selection and has anyone compared....
  194. Y pipes and headers?
  195. 98 Ls1???
  196. car heating even after new coolant
  197. Strange Noise When Starting Car
  198. Any one ever used......
  199. SSRA leading to overheating?
  200. 5.3 heads
  201. how much does an LS1 block weigh?
  202. 241 heads P&P
  203. Is traction control factory on all Z28?
  204. Quick Question
  205. Somebody give this guy a CLUE ?
  206. Cold ticking
  207. Head and cam package
  208. opinion on flowtech LT's?
  209. oil all over the underside of hood
  210. Which combo will work best?
  211. coolant controv...need advice
  212. Z06 Intake on LS1 Question
  213. Dart 205's and F14 Dyno Results In!!!!
  214. 400RWHP from BOLT-ON 06 C6 Z51
  215. Exhaust w/ performance catalytic converters question
  216. when to buy a cam?
  217. Is there really a big difference between....
  218. 205cc intake runner guys check in...
  219. ram air
  220. throttle body coolant passages?
  221. whats the best first 5 starting mods of the ls1 ?
  222. what long tubes would you reccomend for a 00 ws6 ?
  223. Ran my 2000 Z28 A4 at the track today
  224. 58K miles too much for a Cam..
  225. So how much do used LS6's go for now adays?
  226. P&P throttle body
  227. need advice
  228. Dynoed My 2000 Z28 A4 Today
  229. Low Oil Light
  230. exhaust popping?
  231. New mods for a 2000 SS
  232. Flywheel vs. Rearwheel?
  233. Dyno Numbers Soon!!
  234. 01 Camaro SS Engine codes keep popping up, Scanned, Help resolve....
  235. Need to clean LS1?
  236. no fuel
  237. Gmpp Head +cam Package
  238. Stock Head Casting numbers?
  239. Oil Pressure Guage Reading
  240. Snipertuning? looking for feedback
  241. Intake manifold / throttle body
  242. 6.0L pickup guy with interchange questions
  243. started to change coolant 01 ls1. need some help
  244. Back pressure and LS1's
  245. Stock TA's
  246. ? about ls1 normal performance
  247. ls1 Edit Problems, Bottom end bogging at stops, plz help
  248. rough idle
  249. How much trouble is it to swap catbacks?
  250. Bank 1, sensor 1 lasts longer??
