PDA
View Full Version : Drivetrain
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Abs inop
  2. differences in 6spd lt1 trans gearing 94-97
  3. 94 Z Automatic Trans question
  4. SPONSORS?? Need help finding a set of 3.73's!
  5. Drivetrain problem HELP!!!
  6. [B]Announcing the Count Down to Black Friday sale![/B]
  7. 700r4??????
  8. Possible clutch related trans problems?
  9. 95 z28 rattleing near dash?
  10. Our Article from Popular Hot Rodding and a Special Discount
  11. 4l60e install question
  12. T56 input shaft Rockwell hardness?
  13. t-56 swap questions about gear ratios
  14. question for speedo issue
  15. Important notice for storm victims!
  16. Clutch slave cyclinder ?
  17. Tranny conversion
  18. Where to get flywheel and clutch balanced?
  19. Problem with a 6 speed swap
  20. Flywheel and clutch assembly weights-LT1?
  21. guess my gearing?
  22. Transmission problem
  23. Local T56 rebuilder in Ga?
  24. Need quick help with tranny mount install
  25. Trans fluid in coolant
  26. T56 Shifter recommendations
  27. Posi unit grenaded!
  28. 3.42 Posi in a 3.8 car ?
  29. street slicks twisting bad
  30. Back again with clutch chatter
  31. Its Back The PerformaBuilt Yearly Holliday giveaway! GET IT FOR FREE!
  32. Three Rivers LT1/LS1 Aluminum Driveshaft
  33. 4L60e Hot mode?
  34. 95 z28 posi problems/confusion
  35. 4200 Stall. Good fit for my car?
  36. engine swap
  37. 94 t56 seals
  38. Specific Pinion Bearing Preload Question
  39. 1995 camaro z28 a4 wont shift into 3rd at wot after rebuild
  40. What is the bolt size that screws the clutch fork to the t56?
  41. Would the bolt being on the clutch fork t swivel thing cause the chattering i hear?
  42. transmission shift points
  43. Z28 A4 weird shifting issues... PCM?
  44. 3rd Gen to 2nd Gen Parts
  45. looking at new torque converter and installing.
  46. Axle hop and possible damage
  47. 94 LT1 tranny problems
  48. Ls1 trans mount much stronger than Lt1?
  49. trans in a 93
  50. No 3rd or 4th in LT1
  51. 1995 camaro 2.73 rear end question
  52. th350 in a LT1 buick olds pontiac...
  53. Time for a new transmission?
  54. 4L60e downshifting question/problem
  55. LT1 Clutch Suggestions
  56. 4l60E - year compatibility question.
  57. Flexplate to stay with 4l60e?
  58. some help would be nice
  59. Question about acceleration problem with 2000 Z28
  60. New street twin issues
  61. Lt-1 t-56 on a ls2
  62. 95 6-speed tranny problem
  63. real bad vibration after u joint install
  64. transmission question
  65. exact internal differances from 1994 to 1996 4l60e
  66. 4l60e for road racing?
  67. rear axle question
  68. 94 4L60E Clunking sound
  69. Stupid clutch problems
  70. Performabuilt Back to school sale see inside!
  71. 1998 Camaro v6 problems please help!!!
  72. Question
  73. Which converter in a 700r4
  74. Car will not move, 4L60E
  75. Axle shaft removal
  76. 4l60e Problem, NEED help!
  77. Trans swap questions!!!
  78. Quick question
  79. 4L60E Shifter Cable
  80. Can someone help?
  81. 4l60e Won't shift out of 2nd
  82. '94 Camaro LT1 Transmission Problem
  83. Clutch/Transmission Help
  84. need help with gm 10 bolt
  85. strange rear axle code
  86. whats a good **** kit..?
  87. 2001 SS rearend noise?
  88. Drivetrain noises
  89. Fluid Leak on 10 Bolt
  90. 98 z28 axle problem
  91. Anyone converted an LT1 M6 to 4L80E ?
  92. Got A/C fixed now trans overheating?
  93. Crankshaft reverse rotation
  94. Vigilante torque converter
  95. gears question
  96. complete corvette c5 drivetrain on camaro third gen
  97. rear end swap?
  98. 1994 z28 need help with clutch
  99. C5 Shifter?
  100. help with my 700r4
  101. Manual trans in a 78 Trans Am
  102. 8.8 Ford Rear Diff Swap Build Thread?
  103. Super Servo install
  104. HELP 4l60e transmission
  105. Rear end whining
  106. Clutch squeak
  107. clutch issue please help!!
  108. Tranny Mount
  109. dust shield for t56?
  110. t56 driveshaft is tough to put in the tail shaft
  111. Pro Built Automatics
  112. shifter question
  113. HELP!...t56
  114. Rear end Issue?
  115. Which gm rear is about the same dimensions
  116. Transmission differences 4l60e
  117. 1995 Z28 A4 Fluid Capacity
  118. Anyone get 4L60E back from CPT?
  119. 6 speed swap
  120. 94 z28 tranny problems, car running sluggish
  121. Clutch Experts...Re-use this clutch?
  122. Pilot Bushing or Throw out Bearing???
  123. Clutch issue
  124. 93 T56 Swap - Speedometer Issue
  125. Can anyone recommend a good builder of T-56 race transmissions?
  126. Gear tooth contact pattern question
  127. Manual valve body swap
  128. Is my tranny shot?
  129. 3.73 gears for 98z. What car or trucks use them
  130. Driveshaft length
  131. I may be screwed- clutch/flyweel issue
  132. 4L60E Rebuild, Input Drum?
  133. 02 S-series Rear-End into 96 Z28 M6??
  134. who builds the best 4L60E?
  135. 1979 camaro help
  136. Tranny Mount replacement
  137. driveshaft question?
  138. 94 camaro z28 problem!!
  139. need a 4l60e guru
  140. gears
  141. 93 T56 Swap Reverse Lockout Help
  142. Shifter idea
  143. Bent axle on 1998 Z28
  144. rearend swap
  145. T56 clip can You identify please!!!?
  146. Cannot speed shift 1st to 2nd without grinding.
  147. what is this spring?
  148. Help need to know clutch size!!!
  149. Driveshaft Problems, Choices?
  150. Clutch master cylinder u bolt
  151. Help!!!!!!!! very big problem
  152. T56 performance rebuild
  153. T56 Swap Grinding - 3rd to 4th / 4th to 3rd / 5th to 4th
  154. Transmission Shift Cable(Where to buy?)
  155. Torque Converter help
  156. swap an auto to a standard shift
  157. I want to buy a new shifter for my T56
  158. 9 inch swap into 93 z28
  159. LT1 T56 Inspection Cover
  160. Filling a t-56
  161. how much trans fluid
  162. Torque converter.What to buy?
  163. Cover on Bell Housing
  164. No 1st, 3rd, or reverse!!! Help!!!
  165. Pulling T56 for rebuild..Pull everything or leave bell housing?
  166. what clutch to go with?
  167. KTRE 12-bolt tips/advice welcome
  168. Rear End Noise
  169. 96 z28 m6 clutch very hard to push in occassionally
  170. 700r4/4l60e in a 9 second car?
  171. Certain steps to fill a rebuilt auto trans with fluid
  172. v6 trans replacement ???
  173. Need your guys help!
  174. swapping 4L60 in place of 4L60e
  175. 4l60E not shifting out of 1st at wot
  176. will this transmission work in my 1993 Z28
  177. Mcleod Street Twin Master Cyl Adjustment
  178. Gears
  179. 4l60 swap
  180. stand alone transmission controller
  181. Rear differential gear suggestions for milage in a V-6 manual transmission
  182. Which SFI LT1 bellhousing to buy.
  183. Did all torsen rears come with alluminum covers?
  184. Rear end suggestions for autocross?
  185. Doh! Clutch disk
  186. Stall
  187. Part number for T-bar for the clutch fork on a T-56?
  188. If its not one thing, good news/bad rearend build
  189. t56 problems
  190. rear axle bearings too deep
  191. Buying a drive shaft, is this a good deal?
  192. where can i get a 10 bolt rear spider gear thrust washer
  193. better axle materiel
  194. Rear end noise...
  195. C-clip retainer bolt torsen reverse threaded?
  196. transmission oil leak after oil change
  197. clutch
  198. Clutch & Flywheels?
  199. Transmission shaking help
  200. Best differential oil?
  201. 4L60e corvette servo?
  202. 4L60e vibration
  203. Will an lt1 T56 fit on a traditional sbc?
  204. 95 Z28 disc brake rear measurement needed
  205. rearend noise
  206. 4L60e questions
  207. gu2 vs gu5 please help
  208. Moser 12 bolt
  209. I'm close to breaking my thumb every morning.
  210. Kevlar vs. Organic LT1 clutch disk
  211. Need some input on a competition clutch
  212. Clutch recommendation
  213. T56 Lucas Transmission Fix Add
  214. t-5 reverse popping out
  215. noise and rear end shaking from axle play
  216. My speedometer is not accurate at all
  217. Clutch pedal lost pressure
  218. Boss Hog Converters are JUNK!!!
  219. I need help pt.2 (trans, rear ect.)
  220. I need build help
  221. Should I use washers on my differential ring gear bolts?
  222. tranny swap pre '94 1/2 4l60e
  223. so i think my clutch may be slipping
  224. grinding from rear end when turning
  225. Free truck 12 bolt.
  226. 4l60e vs 700r4
  227. 2nd-3rd shift problem
  228. torque arm broke and I believe my rear differential is bent
  229. Is it OK to drive with a broken torque arm?
  230. resting hand on shift knob bad?
  231. 1994 tranny problems
  232. Tranny problems in a 94 z28
  233. Rear pinion seal change out
  234. stock stall rpm on 93 Z28
  235. Need Help with Hurst Shifter Springs
  236. VERY confusing: TWO broken clutch release forks and THREE clutches in 6 months...
  237. clutch and flywheel question
  238. T5 Help needed
  239. T56 to a 305?
  240. 4l60e problem
  241. Fill plug fell into rear differential!!!
  242. question about fluid.
  243. auto trans problem
  244. 4L60E fluid pressure issues
  245. 97 4l60e issues
  246. 4l60e question
  247. Need help! Which rearend do i have ?
  248. What gears??
  249. t56 to a 305?
  250. T56 fork
