Fluid Leak on 10 Bolt
During my T56 swap, I swapped a 3.42 rear end from a 99 Z28 into my 93. Once I put fluid in the diff, I noticed a strange oil leak. I snapped a pic and made a note of where the fluid appears to be leaking from. Has anyone experienced this type of leak? Is there an inner seal as well as an outer seal on this axle?
Re: Fluid Leak on 10 Bolt
No picture showing - copied and pasted link, got this:
403. That's an error.
Your client does not have permission to get URL /Xpqxkj7SUdk6U3dUps294fgS1o-_q-HHfN9HbPO36pcUVTWTLkalZfejG9UEAKD_wgvAf7196dU from this server. (Client IP address: xx.xx.xxx.xxx)
Forbidden That's all we know.
The leak is definitely a drip and not just a residue. That joint looks like a friction weld. Should I seal that with RTV before putting oil in the diff, or should the weld seal that?
RTV should stop the leaking, but I'd be a bit worried about WHY it's leaking. Maybe flexing too much there, abused by previous owner and now weakened? Welding sounds best.
kev93z28
Aug 19, 2002 12:48 AM
