4l60e question
Old Nov 19, 2011 | 08:04 PM
twistedbowtie's Avatar
4l60e question
the 4l60e is shot in my 94 z28. what year f bodys have the same transmission that would fit in my 94?
ive heard the ls1 bell housing is different is that true, another question i have is the circle plug in on the 4l60es can it be changed easily?
thanks guys, Dustyn
Old Nov 20, 2011 | 01:22 PM
Ocala93TA's Avatar
Re: 4l60e question
Only 94 4l60e will work for your 94 , other yr. lt1 4l60e will bolt up but will not work . and yes a ls1 has a completely different bellhousing from a lt1
Old Nov 20, 2011 | 06:44 PM
Re: 4l60e question
will a 4l60e from a 94 vette work?
Old Nov 20, 2011 | 08:34 PM
Ocala93TA's Avatar
Re: 4l60e question
Yes but the tailshaft would have to be changed out
Old Nov 21, 2011 | 01:40 AM
Pro Built Automatics's Avatar
Re: 4l60e question
The 1993 & 1994 are the same. Changing the output shaft and the tail housing on the Corvette has to be done, but the Corvette will not have the transmission mount holes in the case. Check to make sure, otherwise it will not work without the transmission mount holes.
Old Nov 21, 2011 | 09:20 AM
Re: 4l60e question
Originally Posted by Pro Built Automatics
The 1993 & 1994 are the same. ...
Do you mean on a Corvette? The 93 f-body has a 4L60 and 94 has a 4L60E, which I know you know are not the same. Just trying to avoid confusion.
Old Nov 23, 2011 | 11:49 PM
Re: 4l60e question
Thanks guys. I will check for the mount holes. How hard is it to swap the output shaft and tail housing?
Old Nov 27, 2011 | 04:45 PM
12SCNDZ's Avatar
Re: 4l60e question
The transmission has to be partially disassembled to swap the output shat. '93 and '94 4L60E's are both non PWM, so those 2 years are interchangeable. They didn't use the 4L60E in the F-Bodies in '93, though, but a '93 truck 4L60E will work.
Frank
Old Dec 1, 2011 | 09:48 AM
Re: 4l60e question
If the tranny I'm looking at buying is from a 94 vette and my z28 is a 94 why would the output shaft be different? I don't understand. But thanks for the help
Old Dec 1, 2011 | 12:46 PM
12SCNDZ's Avatar
Re: 4l60e question
The Corvette output shaft is shorter...
Frank
Old Dec 1, 2011 | 04:50 PM
Re: 4l60e question
Frank
if i had a drive shaft made would it fit? or would the drive shaft out of the vette work?
thanks a lot
Old Dec 1, 2011 | 08:19 PM
12SCNDZ's Avatar
Re: 4l60e question
thanks a lot
The Vette driveshaft will definitely not work. You'll need the CORRECT length output shaft because you'll need to use your F-Body tail housing, so you have some place to bolt your torque arm. Please, take my advice... Do this the right way. Just have the F-Body transmission rebuilt.
Frank
Old Dec 3, 2011 | 12:34 AM
Re: 4l60e question
Okay man that all makes since . Your right I should just have mine rebuilt. Thanks for all the info
Noer
Feb 28, 2015 11:29 AM
PCLZ28
Parts Wanted
Feb 12, 2015 11:35 PM
Brake_L8
Jan 20, 2015 09:44 AM
Victory Racing
Sep 12, 2002 10:40 AM
ZZed
Sep 10, 2002 04:13 PM
