Transmission shaking help
i have 1995 Camaro BC4 Code and a 3-5 Split Axel 4.11 gears. I took it the machanic they moved my tranmission Cooler, the also fixed the leak in the transmission Pan.The rumbles Really Bad but if i let it sit for 1 or 2 minutes it stops. the gears Reveses and 2 gear are the worst. But if push my car and shift it manually it still grabs and takes off smoothy. it still leaking tranmission fluid and the machanic said fluid was black. wat should i do because i am gettin a Custom Built 383 should have brand new transmission built then or should i rebuild it now
Re: Transmission shaking help
how much would it cost for good a aftermarket tranmission will cost to pair it with my 383 do have aftermarket part sujestion i should buy so this never happen again for along time
