some help would be nice
Old Aug 21, 2012 | 07:26 PM
the collector's Avatar
ok so i have a 97 ss camaro just put new clutch and flywheel in changed to full sinthic luics oil in rear end at same time, but now my rear end is makeing a noise when i turn, and did the other day when backing up mostly sounds like a tire rubbing. Iv checked everything so i figured something in side the rear end. I tracked the noise to the rear end as i rolled it back and forthe on the lift i know about (back lash). So then took off my cover expecting to find some metal shaveing in there and there is nothing. Every one is saying its the locker and they gotta replace it (none servicable) is what iv been told. They want to do a compleat rear end build for like 1200 big ones and i dont got that right now, so any ideas I got the cove off still, o and btw car has less then 48,000 miles on it plz any help at all
thanks so much danny...
Old Aug 21, 2012 | 08:45 PM
Unhappy Re: some help would be nice
i know i put in there i just replaced the clutch and flywheel but i know some guys dont like it when u dont give all the info, its a manual 6 speed t56, when they did the clutch they said the trans looked fine. Could have doing any thing with that have messed it up
Old Aug 21, 2012 | 11:19 PM
rngilliland's Avatar
Since you narrowed the noise down to the rear, I would try some standard lube with the GM limited slip additive instead of synthetic.
Old Aug 22, 2012 | 10:27 AM
Which differential do you have? The stocker I believe was an Auburn disc type limited slip. On the SS SLP offered the Torsen unit as an option. Neither is a "locker" in the traditional sense.
The Torsen can suffer from what is described as a "rusty screw" noise, and GM recommended that the GM limited slip additive be used to quiet the noise.
Torsen General Frequently Asked Questions page
Old Aug 25, 2012 | 03:49 AM
huahuafood's Avatar
I love this thread already..
(HIDDEN SPAM LINKS REMOVED)
Old Aug 27, 2012 | 08:40 PM
Ok so i put it back together this weekend put plan old 80-90 weight in it, nothing eles and i took it back out on the road didnt hear one noise. Do i still need the additive or will that work? I gess im back to squair one drive it till i start hearing it again right ? im not gunna spend the time and money on doing stuff to it if nothing is wrong.
Old Aug 28, 2012 | 05:30 AM
Same question I already asked - Which type differential do you have - the Auburn or the Torsen?
David Dempsey
Mar 12, 2016 12:42 AM
Fatdog2
Sep 26, 2015 12:06 AM
Aug 17, 2015 09:50 AM
detroitmuscle
Jul 31, 2015 04:21 AM
cmsmith
Jul 5, 2015 07:23 PM
