tranny swap pre '94 1/2 4l60e
I picked up a '94 camaro z28 (dream car) well I blew my tranny it was gone when I bought it so I read a little about them well I guess idk **** I bought I '95 trans am tranny put it in an started it up won't move some converter lockout **** so I found a 4l60e it of a'94 buick raod master it says its has a lt1 with a 4l60e anyone no for a fact it will fit I just want to drive her I hate just siting in her lol
Re: tranny swap pre '94 1/2 4l60e
The fact that that 95 trans won't move is not because of the TCC difference. Something is wrong with that transmission or install. I am not sure the Buick is the same in 94, but it probably is. The difference is the 95 uses a PWM TCC solenoid and the 94 does not and there is an extra wire in the harness to the transmission for it.
Roadmaster/Imp SS/ Caprice/ 2WD truck 4L60E's are interchangeable... As long as the year is correct. Yes, you will have to change the tail housing, which is onlt 4 15 MM bolts. The reason the '95 unit didn't move may have been because of previous damage OR the converter wasn't installed completely in the front pump. If this happens, it will break the pump rotor. Did you have any issues bolting the trans up or turning the converter to put the bolts in?
Frank
Frank
Im sure he didnt, after using the bolts to draw the transmission into the engine. Once the rotor popped it went in smooth as butter I love when this happens, though it is unfortunate for him. I get at least 2-3 of these cases a year and i can never stress enough to ppl to MAKE SURE the converter is fully seated!
carguyshu
01-22-2017 11:19 AM
