700r4??????
Old Nov 18, 2012 | 02:17 PM
Hempy Tripp's Avatar
700r4??????
I see that their are mixed emotions about these transmissions. The 93 Z i just bought has 1 in it that was rebuilt with a 2500 stall. I feel like when it is going thru the gears under heavy throttle it is slipping out of gear and slipping into the next gear. I read that these transmission are mainly used for the O/D and fuel mileage. I did not buy this car for fuel mileage, so if that's how the shifting is going to be i'm taking it out! I'm looking for something that shifts now! could it be the stall that is causing the delay and rpm rise between shifts? car is currently putting 467hp with 507ft lbs of torque to the rear tires. needs new supercharger belt and tuning after new belt and sparkplugs.
Old Nov 19, 2012 | 01:02 PM
12SCNDZ's Avatar
Re: 700r4??????
A properly built 700R4 shouldn't shift that way. We have them running in the low 10's. If modified correctly, the shifts can be very impressive. The 700 has a few other benefits over other automatics. You've already mentioned the overdrive, but a 700/4L60E has a 3.06 first gear ratio. The lower ratio will usually enable the car to launch harder. A 700 also takes less HP to turn than a TH400, so the car will usually be quicker with a 700. Trying to swap anything else in can be expensive because you have to modify or replace other pieces, such as driveshaft, converter, crossmember, and torque arm mount.
Frank
Old Nov 20, 2012 | 10:19 PM
Re: 700r4??????
Frank
could it be the stall convertor making it shift bad? its a gradual shift vs shifting now!
Old Nov 21, 2012 | 08:52 AM
12SCNDZ's Avatar
Re: 700r4??????
2500 isn't alot of stall. Yes, the more stall you go with, the softer the shifts will be, but if the transmission is properly built, you can compensate for that. We have 700's with over 3500 stall that still chirp 2nd and 3rd.
Frank
Jake Bialke
Sep 24, 2015 11:31 AM
92_RS_305
Sep 8, 2015 07:47 PM
Cam's maro
Aug 11, 2015 07:45 AM
jimmybandana
Mar 22, 2015 07:44 PM
CaRParts102
Dec 6, 2014 08:45 AM
