Tranny problems in a 94 z28
Old Dec 6, 2011 | 10:33 AM
iverson's Avatar
I have just recently bought a 94 z28. It runs hard and is alot of fun. But i dont know if something is wrong with the tranny or whats going on. It shifts really hard into second and running it through the quarter mile I have to let out of the throttle before it will shift. If someone could help me it would be greatly appreciated
Old Dec 6, 2011 | 01:07 PM
Joe Bellman's Avatar
Re: Tranny problems in a 94 z28
Fix to the problem could be as simple as flushing the fluid and putting a new filter in. Or the TV cable needs adjusted.
Do a search for "WOT shift" on here.
(WOT= wide open throttle)
Old Dec 6, 2011 | 03:15 PM
94s don't have a TV cable.
OP, it is hard to know what modifications might have been done to the transmission or programming since it is used. You might also scan for any transmission trouble codes. They don't normally light the check engine lamp.
Old Dec 6, 2011 | 06:30 PM
oh yeah. too used to my 700R4....
Old Dec 7, 2011 | 04:47 PM
OK... let's move this to the "Drivetrain" forum.
Old Dec 8, 2011 | 07:34 PM
12SCNDZ's Avatar
What condition is the fluid in? This could be a sign of the 2-4 band going.
Frank
Old Jan 23, 2012 | 10:26 AM
iverson's Avatar
The fluid dont look bad. It doesnt smell burnt or anything. Under a load with the cruise set like going up a good sized hill or something it will vibrate pretty bad too..im going to flush the fluid and change the filter and see what that does..I would like to just have it professionally re-done so that it could take 600hp but thats not in the budget right now
Old Jan 31, 2012 | 11:05 AM
iverson's Avatar
im thinking its in my torque converter..its only vibrating during lockup and coming out of lock up
Old Jan 31, 2012 | 11:39 AM
12SCNDZ's Avatar
The converter won't cause the problem you explained in your initial post.
Frank
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
nballisru
Dec 14, 2014 05:01 PM
mattszm6
Dec 14, 2014 07:09 AM
tds1213
Nov 27, 2014 12:55 PM
siguy
Nov 27, 2014 10:07 AM
