Rear end Issue?
Old May 19, 2012 | 05:37 PM
dan georgevic's Avatar
Exclamation Rear end Issue?
Guys I have a 1994 camaro z28 automatic with 80k . Last year I had the rear end rebuilt with the richmond 3.73 and shim and bearings after going to the track and making 4 passes..( yes I did break the gear in) I noticed a whinning noise from the rear off the car... today 3wks later I also noticed a puddle about a pint of oil on the ground in the garage floor from the back of the car .... and it was not tranny oil. The whinning noise only happens when coasting or slowing down so far. Any ideas on what my problem might be ? OR what I need to look for when I put it up on the ramp?
Last edited by dan georgevic; May 19, 2012 at 08:54 PM. Reason: misspelled words extra info
Old May 19, 2012 | 06:10 PM
Re: Rear end Issue?
The whining is probably a faulty gear setup, or a problem with the crush sleeve. The leak is typically the pinion seal. You have to get under there and see where the gear lube is coming from.
Old May 19, 2012 | 08:51 PM
Re: Rear end Issue?
When the rear end was swapped and rebuilt it had a sound the first time I drove it , I returned the car asap within less than a mile 2k miles with no issue till now I will isolate exactly where there leak is comming from thanks.
Old May 20, 2012 | 07:19 AM
Kevin Blown 95 TA's Avatar
Re: Rear end Issue?
Give the yoke a shake and make sure there's no movement. It shouldn't rattle around on there.
Old May 20, 2012 | 03:06 PM
Re: Rear end Issue?
Just got under the rear end I found the fluid leak from the front of the rear end by where the driveshaft hooks up to the rear end... ok let me hear the bads news everyone. The yoke isnt shaking driveshaft feels secure.
Old May 21, 2012 | 10:17 AM
RUDEDOG's Avatar
Re: Rear end Issue?
Bad pinion seal. You know you can't beat on 10 bolts and expect them to last very long.
Old May 21, 2012 | 05:07 PM
Re: Rear end Issue?
The pinion seal is a cheap replacement if you do it yourself, but to do it right, you need to measure the preload on the pinion, count the turns on the big nut when you take it off, and after replacing the seal make sure you tighten the nut correctly to it's original position, and maintain the original preload.
Add to that the whine on decel, and it may be indicating a gear contact problem. That would mean that the gears would have to be inspected by someone who knows what they are doing, to determine if there is a wear pattern that would confirm the source of the whine. The gears should be inspected before the pinion seal is replaced, since the gears may need to be replaced. I would have the shop that installed the 3.73's take a look.
Old May 22, 2012 | 12:46 AM
Re: Rear end Issue?
Thanks for all the info to everyone I WILL make sure my pockets are deep only bright spot is maybe I should get 4.10 put in? looking like the stall waits til next year will update all
Old May 22, 2012 | 08:30 AM
RUDEDOG's Avatar
Re: Rear end Issue?
I would not go 4.10 with A4.
Old May 22, 2012 | 09:34 AM
SROACH's Avatar
Re: Rear end Issue?
I have a Richmond 3.73 gear in my stock 10 bolt also and my pinion seal went also. Richmond gears whines anyway. Had my leak fixed at Drivetrain Specialist(1-800-521-0628) . I got lucky and won a $50.00 gift certificate from them at Camaro Superfest last summer. While I had the car there I had them install one of their TA aluminum covers. If you can,order one of those covers from them. They will ship it right to your house. Its a nice addition. Ask for Sandy or Claud. :0)
Old Jun 4, 2012 | 01:06 AM
Re: Rear end Issue? 3.73 or 4.10?
How much et would a swap to 4.10 give a a-4?
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
