No 3rd or 4th in LT1
I have no 3rd or 4th gear, I have done put 3 transmission in and its still doing the same thing. It all started after i put my new motor in, It didnt seem like it wanted to go into 4th, now there is no 3rd. So could this mean i have a wiring problem or could this be something wrong with my tune? Ive only had a base tune done. The first tune it didnt seem to want to go into 4th, and few days after it stopped going into 3rd. So i took my PCM and had re tune and still didn't help any. Had someone build a transmission and it's going into 3rd in 4th but at really HIGH rpm's.. What could be the problem ? Thanks everyone for the help, Very much needed..
Re: No 3rd or 4th in LT1
No, but i took it to a transmission shop and had them look at it and they said the transmission wasn't bad and that there was a few burnt wires which i fixed and still nothing. Also i tried to hook up my hand tuner to put hook up under the dash, and for some reason it wouldn't come on. I don't no if it was cause there is something wrong with my PCM making it not work, or maybe my tuner is F up.... Thanks for the reply by the way.
What year is your car.... it's almost impossible to offer reliable advice without that basic info? What you use to scan the car, and the reason for not connecting is dependant on the year.
Why not add a "Signature" with basic info about your car - year, model, engine, trans and any major mods. Helps people help you.
Sorry, Heres whats done
**CC306 Cam, Hooker LT Headers, Cold air intake, 3000 Stall, Pro MAF, 4:10 Gears, LT1 P/P Heads (valve springs, retainers, etc), Eagle Forged Pistons, 1.6 roller rockers, LT1 P/P Intake, Holly 58mm Throttle Body, 30lb SVO Injectors, Adjustable Fuel Pressure Regulator, Sealed Power Hellfire Piston Ring Set R-19100-35 4.030" Bore 1/16"/1/16"/3/16", JEGS Electric Billet Water Pump, NGK spark plugs, MSD Spark plug wires *
Also i was using the Hypertech tuner.
I dont give a ****, give up but you dont have to be a dick about it, it shows on my profile the year of my car.. if you get your hand outta your *** you coulda took 2 mins and looked at it... so give up on that one.
Jul 4, 2005 05:00 PM
stars1010
Jul 15, 2002 03:51 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
formula79
23
Jun 20, 2002 01:42 PM
